Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Mar 22, 2020 at 12:46 PM
    #1981
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    35x12.5x20
    KMC FMJ 10 wides (-18)
    Bora 1.5" spacers
    Kumho Road Venture MT
    J&ATundra, Prostar 190 and 2010bigdog like this.
  2. Mar 23, 2020 at 9:05 AM
    #1982
    robcast52465
    robcast52465 New Member
    Robert
    2007 Toyota Tundra Limited 5.7 V8
    Where is the M60 gun turret option?
    texasrho83 likes this.
  3. Mar 27, 2020 at 6:27 AM
    #1983
    07tacoswb
    07tacoswb New Member
    2016 Super White Tundra Crewmax XSP-X
    Hostile Alpha 20x10 -19 in Asphalt with 33x12.5r20 Nitto Ridgegrapplers. I have a 3" Eibach coilover lift up front with Toytec Boss shocks in the rear with a 2" block.
  4. Mar 28, 2020 at 1:04 PM
    #1984
    mghtyducks93
    mghtyducks93 Bubble Head
    Southern California
    2015 White Double Cab
    2.5 inch level up front, 1.25 inch spidertrax spacers, 285/75/r18 Nitto Ridge Grapplers on stock wheels. Happy with the look! Minor rub at full turn on bumper liner.IMG_6230.jpg IMG_6244.jpg IMG_6226 2.jpg IMG_6241 2.jpg
  5. Mar 28, 2020 at 1:54 PM
    #1985
    glowblue
    glowblue From time to time
    VA
    Poor mans TRD Pro
    Prostar 190 and equin like this.
  6. Mar 29, 2020 at 5:59 PM
    #1986
    SR520
    SR520 Lay it tight
    Robert
    Evergreen
    2020 SR5
    Leveled by Toytec: Boss Aluma 2.5 adj coilovers/ UCA
    I just noticed a couple weeks ago a slight rub when at the left limit. Measured and my passenger side wheel looks to be about ¼ inch forward of the other.
    Didn't notice this before.... Wonder if there was some travel after the installation of the new setup. Been meaning to call the boys @Toytec Lifts , see what they say. With these UCA the wheel has alot of adjustability...
  7. Apr 7, 2020 at 7:21 AM
    #1987
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    What is your offset?
  8. Apr 7, 2020 at 7:22 AM
    #1988
    zachzap361
    Zach
    San Antonio
    DemoTex likes this.
  9. Apr 7, 2020 at 7:35 AM
    #1989
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    +25 (SCS SR8 18x9 w/ 35x12.5x18)
  10. Apr 12, 2020 at 4:15 AM
    #1990
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    Trying to figure out the offset without taking off the wheels. Any guesses? 20x9 LT295/55/20 they are either +20 or +120200411_174956.jpg
    Prostar 190 and jeremyd like this.
  11. Apr 12, 2020 at 5:21 AM
    #1991
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I currently have 20x9+20 now but getting new ones and I would like to know too
  12. Apr 12, 2020 at 6:58 AM
    #1992
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    looks like a 0 or negative to me. Here is a -11
  13. Apr 13, 2020 at 11:37 AM
    #1993
    linwozzle
    Linden
    Confirmed that they are +1
    2010bigdog and jeremyd like this.
  14. Apr 17, 2020 at 8:05 AM
    #1994
    Stig
    Stig New Member
    As far as how much work is needed to fit 295/70/18 on +25, is there a big enough difference between 1.9 lift plus 2 shims driver and 1 passenger, versus 2.5 with just one shim driver?
    Trying to decide 6112 setting. I don't mind having to do some work on the plastics or skid plate. Just wondering if I can expect about the same amount of work for these two options or if that extra .3 inches would make it way easier.
  15. Apr 17, 2020 at 10:35 AM
    #1995
    Harrison917
    Harrison917 New Member
    2015 White Tundra RWD DC
    2015 TUNDRA RWD DC
    FRONT: 5100's - 2"
    REAR: TOYTEC SHACKLES - 1"
    285/70R17 COOPER AT3 XLT
  16. Apr 17, 2020 at 8:06 PM
    #1996
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Looks good- Love the offset! Any trimming?
  17. Apr 17, 2020 at 9:31 PM
    #1997
    Harrison917
    Thanks! No trimming, but used a heat gun to soften and slightly push the front of the fender liner in.
    It rubbed a bit while reversing at full lock.
  18. Apr 17, 2020 at 10:43 PM
    #1998
    NICKDILL
    NICKDILL New Member
    I got a a mud tire with 265/70/17, and was wandering what negative offset I needed to make my tire stick outside the fenders?
  19. Apr 17, 2020 at 11:16 PM
    #1999
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    Just got these dirty life iron man 9300 20×9 +18
    offset wheels
    Tires are
    NITTO RIDGE GRAPPLER LT275/60R20 (33.2X11)
  20. Apr 18, 2020 at 12:40 AM
    #2000
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    35 x 12.5 x 18 Nitto Trail Grapplers tires on 18 x 9.5
    Black Rhino Armory Desert Sand wheels, offset +6, backspacing 5.5, center bore 110.1
    7" BDS Fox coil-over suspension lift & uca s.
    The only modification done with this setup was to remove the stock front mud flaps, and install bump stops.
    [​IMG] [​IMG]
  21. Apr 20, 2020 at 7:16 PM
    #2001
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    6112s set at 2.5" with 1 @BOSS4x4s shim on drivers side.
    5160s with @BOSS4x4s shackles set at 1.5"
    20x9 Fuel Vectors +20 offset with Nitto Terra Grappler G2 35"
    SPC UCAs
  22. Apr 21, 2020 at 11:50 AM
    #2002
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I found a set of Fuel Vapor 560 18x9 with -12 offset. I like these but I have no clue about offset, lift or anything like that. My truck is stock for now. I would like to go with a 3/1 or 4/2 leveling kit. I would probably put my stock tires on the Fuels for now until I decide on the lift/leveling kit. Any advice would be greatly appreciated. Thanks!
  23. Apr 21, 2020 at 7:38 PM
    #2003
    SeabeeTundra
    SeabeeTundra New Member
    Rick
    2014 Tundra Limited
    I have a 14 Tundra with a 4” lift. I’m currently running the stock 18” TRD off-road wheels with the original Michelin 275/65 tires. I’m getting ready to buy new wheels and tires and I’m looking at a set of 20X9 +12 wheels with 35X12.5 tires. My question is, will it work?
  24. Apr 21, 2020 at 11:57 PM
    #2004
    jwatt
    jwatt I heart men
    Jack
    Oregon
    When I started looking for new larger wheels and tires I didn t realize how complicated it can get. After choosing a lift my options became much smaller because my backspacing could be no more than 5.5. I went to a d iscount tire store and talked to one of the attendants there. He pulled up an offset calculator program on his computer, and made it a lot easier for me. I could choose a wheel, and he would plug it into the program and it would tell me if it would work or not. I think some lifts are not as bad as others though.
    SeabeeTundra[QUOTED] likes this.
  25. Apr 22, 2020 at 12:16 PM
    #2005
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    3/1 lift, 20x8.5 XD Rockstars (don't know the offset either +10 or +35) with 35x11.50 Ridge Grapplers. No cutting, rubbing, etc.
    IMG_20200421_113713839_HDR.jpg IMG_20200421_113725225_HDR.jpg IMG_20200421_113830112.jpg
    ManoTundra and silverstreak16 like this.
  26. Apr 26, 2020 at 5:31 PM
    #2006
    Cryer
    Cryer New Member
    Joel
    ‘18 TSS DC
    So I see all the info on what will fit with a stock lift. Is it possible to fit 35s on the stock 20”tss wheels? With aftermarket bumper and cab mount chop? With no lift. Or very little lift
    DaniB likes this.
  27. Apr 27, 2020 at 3:05 PM
    #2007
    Stig
    Stig New Member
    Just how bad is the power loss on the highway (70-80 and overtaking) when going from the stock P rated 32" to E rated 34"? Actually more interested in the difference between E rated 275/70 and 295/70 since those are the two sizes I'm considering.
    I'm planning on gears and supercharger much later on but need to replace the stock tires now. I installed +2.3" front and 1" rear already.
    I don't want a sluggish ride down the highway for the next 3 years until I go with gears and SC, but of the difference between those two sizes isn't too big I might just go with the bigger size for now.
  28. Apr 30, 2020 at 2:36 PM
    #2008
    TONKA TUNDRA
    TONKA TUNDRA HULK SMASH!!
    KY
    2014 DC Magnetic Grey
    Posted this in the 3rd Gen but wanted to share here as well.
    Wheels: Icon 17" Vector 5
    +25 offset
    Tires: BFG KO2 285/75/17
    Bilstein 5100 on top setting in front. 5100 in rear with no lift. Waiting to see how much it will settle before adding anything to the rear. I like a little bit of rake so I'll end up adding something in the near future as its roughly 1/2" high in the front now.
    J&ATundra, TRDblvd, Trabs00 and 7 others like this.
  29. May 3, 2020 at 1:13 AM
    #2009
    Jemz808
    Jemz808 New Member
    Maui, Hi
    2018 SR5 Offroad
    35x12.5r18 Nitto Trail Grappler M/T tires on stock off road rims
  30. May 5, 2020 at 12:50 AM
    #2010
    Psquancher
    Psquancher New Member
    Jeff
    Atlanta area
    2018 Tundra CM 4X4
    aFe intake and dual exhaust. ADD Stealth front bumper with Rigid light Bar and Smittybuilt winch, ADD Stealth rear bumpers and ADD Stealth steps. Bilstein 6112 @2.3” Bilstein 5160s with Toytech shackles at 1.5". Fuel Contra 20x10 -18 with Ridge Grappler 285/65 with custom BMC. Monster system with Infinity Kappa components JL HD750/1 and JL HD600/4 amps JL Stealthbox and Alpine avic8400NEX hu and full Kilmat sound dampening.
    Looking for some insight please. I have a set of 285/65 20 RG on the dealer added 20s with Spydertech 1 1/4 spacers. I’m looking at 20x9 or 20x10 -20 wheels. Tirerack etc keeps putting me in 20x9 I’d prefer 20x10 so I can have more options on my next tire change. Current setup 6110s 1.9” 5160s stock rear height. ADD Stealth bumper up front so clearance shouldn’t be an issue. Anyone else already fought this battle? Thanks all
