wheel spacers and rear blocks
Discussion in 'Wheels & Tires' started by ausei, Jan 19, 2015.
  1. Jan 19, 2015 at 8:49 AM
    ausei
    ausei [OP] New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i am about to put a 3.5" spindle lift in addition to my 3" leveling kit. having a hard time finding wheel spacers because the spindle lift will offset the wheels one inch on each side. also looking for some cheap blocks to make the rear sit level. the kit comes with 2" just not sure if its going to balance out. any advice?
  2. Jan 23, 2015 at 11:09 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I assume you have a 2WD because of the stacking of lifts. This would kill front CVs in a 4WD.
    A good brand of wheel spacers is spidertrax.com. I have them on my truck, 1.25".
    2" might be close but I'm guessing you will prob need around 2.5" -3". Look at the change in shackles. There are several guys that went that route, I almost did. Might have to do a 1" block with the extended shackles. The fabricator could tell you. Hopefully some one will chime in on the mfg???
