4.5" or 7" lift?
Discussion in 'Suspension' started by Bluedevils4life, Apr 9, 2020.
  1. Apr 9, 2020 at 7:20 AM
    Bluedevils4life
    Bluedevils4life [OP] New Member
    Jeff
    2020 Toyota Tundra
    RBP Running Boards, 20% Window Tint, TRD Exhaust
    I am new to the forum but wanted to get some input on lifts kits for the Tundra. I have been doing some research but am stuck between with a BDS 4.5 inch or 7inch lift. I have looked at ReadyLift but would rather stick with the Fox Coilovers. I would like to stay with a size 18 inch wheel. I have been leaning towards some Method 312 or Mesh wheels. What is your opinion about what size lift I should go with? Do you think I will need an upper control arm too? I appreciate all the input!
  2. Apr 9, 2020 at 7:35 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    https://www.tundras.com/threads/guide-different-types-of-lifts.546/
    Anything over 3 inches increases complexity....get a good complete lift. Yes on UCA. With the size tire you would likely run with that much lift wheel offset becomes critical, probably also need fender well trimming and attention to body mount. There are forums here specifically for wheels/tire and suspension....so you have reading to do. Lots of good info.
  3. Apr 9, 2020 at 6:22 PM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    Thanks for the help, I just simply can't decide but with this COVID crap going on right now. I have time to think about what lift , wheels and tires I want make an investment on for the truck.
  4. Apr 9, 2020 at 8:09 PM
    A 7 inch will kill your mpgs because you will be running some rather large tires.
  5. Apr 9, 2020 at 11:44 PM
    AZBoatHauler
    So.Arizona
    No experience with big lifts but going up that high you’ll want to re-gear as well so keep that in mind. I think everyone agrees you’ll want to run 5.29 with anything over 35” tires.
  6. Apr 9, 2020 at 11:57 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    I'm a fan of the BDS 7" lift. On my 2012 Tundra I ran 35" tires and with my 2016 I'm running a 7" BDS lift with 37" tires with the body mount cutout. Neither have had regears. One thing that really helped on my 2016 is adding the Pedal Commander. I'm getting about 13.0 mpg (indicated) with daily commutes at 70-75mph with the PC set to City +2.
  7. Apr 10, 2020 at 5:34 AM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    That BDS 7 inch lift looks great and I am surprised you get 13 mpg. Do you Gus think Kings coilers are worth the money? I keep reading great things about them.
  8. Apr 10, 2020 at 5:52 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm just here to throw a monkey wrench into your decision. Lol, Here are two Procomp 6 inch lifts. Good luck with whatever you choose, I'm sure it will turn out good.
  9. Apr 10, 2020 at 6:59 AM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    What size wheels are you running on your pro comp? I want to stay around 17 or 18. I like the look of more tire and less wheel.
  10. Apr 10, 2020 at 7:01 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    35/12.50/18
    -11 offset
  11. Apr 10, 2020 at 7:59 AM
    SonnyAde
    SonnyAde New Member
    Arlington, TX
    KatSkinz Leather seats 2 1/2” Eibach Pro-Truck Lift kit 1” Wulf Rear Lift Blocks 18X9 XD Monster, 295X70X Nitto RG 1” BORA spacers 2018 Honeycomb Grill Tonneau G2 Cover K&N CAI 77 Series Pedal Commander MGP Red calipers 20% Window Tint Chrome Bumper delete Carven Exhausts
    Nice truck
    jeremyd[QUOTED] likes this.
  12. Apr 10, 2020 at 1:38 PM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    Does anyone any have knowledge on the Bilstein Coil-Over upgrade that you can add to the ReadyLift?
  13. Apr 10, 2020 at 1:41 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks fricken killer bro...Love it
  14. Apr 10, 2020 at 2:44 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    Not sure about the bds 4.5 inch but the bds 7 used a new spindle to keeps your stock uca at a stock height so you don't need new uca if you don't want to. My alignment was all within specs. Now later I had the fox coilovers turned up and added coachbuilder shim and shackle kit for an additional 1.5 inch up front and 2 inch in rear so I could fit 38s and now I need new uca as my castor alignment is out of spec but you should be good with the bds 7.
    Here is a picture of my uca as it sits today. Still less of an angle as people running a 3-4 inch lift due to the new spindle that comes with lift
    Do t mind the rub on The body mount in th pic. That was why I lifted it higher. That has since been taken care of..
  15. Apr 10, 2020 at 4:59 PM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    Your Tundra looks pretty sick. Have you had problems with your BDS. I have read about people having problems. So what size tire do you have on your truck now?
  16. Apr 10, 2020 at 6:50 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Thanks Man! And only issue I had was I didn't have the fox coilovers put on right when I got the lift. Couldn't afford them at the time so the stock coilovers with the spacers they put on the bottom squeaked like a mo fo just had to spray lube it. Then I upgraded to fox and problem solved. Second issue the rear brake lines were touching rear leaf springs but a quick bend of the very flimsy sock brake line bracket and that problem was resolved as well. So really nothing major and I've beat the crap out of it.
    Tire size is 38 13.5 20 on -18 offset
  17. Apr 10, 2020 at 7:10 PM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    Your making me lean towards the bds lift,
    I thinking about method 312 18x9 wheel setup! WhT size wheel do you have on yours?
  18. Apr 10, 2020 at 9:58 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Ya I did alot of research before I got it. High quality lift with the best warranty available. Doesn't void factory warranty. And i have 20s on mine. Depending on your offset you could easily fit 37s without cutting the body mount 2.
    I believe methods normally have a positive or 0 offset. That would be perfect for 37s
    Ely010606 likes this.
  19. Apr 10, 2020 at 10:21 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Oh and if you do go the 7 inch do yourself a favor and get 37s. I got 35s at first brought it home and the wife told me they looked 2 small...
    devdomski, Ely010606 and StihlBuckin like this.
  20. Apr 11, 2020 at 7:42 AM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    I thought the same thing about the wheel size.Did you have to change out your gears when putting 37inch tires on? I have read about people have to change out their gears. Also on the BDS can you set the lift to 6 inches instead of 7 inches?
  21. Apr 11, 2020 at 8:11 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Do you have the pro shocks? Ready lift has the 4” bracket lift that lets you keep all your fox shocks. So it will be 6”. Which is the 4” plus the 2” you already have with the trd Pro fox shocks.
  22. Apr 11, 2020 at 8:28 AM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    I do not have the pro shocks.
  23. Apr 11, 2020 at 8:32 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    you didn't lift yours yet ?
  24. Apr 11, 2020 at 10:51 AM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Yes I regeared wasn't planning on it but after my first road trip threw the mts on 38s I could feel it struggling to find gears. I went 4.88 I would recommend 5.29 tho. Not sure if you can set the bds to 6". I had the coils cranked up higher for more lift. You might be able to turn them down for less but not 100%. If you can turn the fronts down that would still keep the rear higher than the front so idk
  25. Apr 11, 2020 at 12:00 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    Getmeacoors does mention the offset then mentions the Methods. The wheels will have to have an offset (BS or backspacing in their instuctions) for sure. From the BDS web page.
    Getmeacoors[QUOTED] likes this.
  26. Apr 11, 2020 at 12:13 PM
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Not necessarily. My offset is way to far negative according to there website and my rims are 10 wide instead of 9 . There website is for no trimming so you are right in that aspect. But if you don't mind some trimming and a bmc that opens up a lot more options :sawzall:
    But yes you are correct there website does have good guidelines to reference
  27. Apr 11, 2020 at 12:40 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Since the pro already has a 2” front lift. I just added 1” more to make it 3” and added the #3 shackles to keep the rake especially when I’m hauling material for work. I put the money in the sound system this time.
    2010bigdog[QUOTED] likes this.
  28. Apr 11, 2020 at 1:23 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Any pics ?
  29. Apr 11, 2020 at 3:27 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    Good info. I'm not sure what my offset is but I do have the BMC.
  30. Apr 14, 2020 at 2:01 PM
    Bluedevils4life
    Jeff
    2020 Toyota Tundra
    Well I decided to go with a 6 inch ready lift with the Bilstein coil overs, 18 inch fuel covert & Toyo Open Country RT 35x12.5. I am having it install in about 1 month. I am very excited!!!!!:yes:
    D4x4TRD and Jsena like this.
