19 Double cab rear speaker
Discussion in 'Audio & Video' started by motocrossman99, Apr 9, 2019.
  1. Apr 9, 2019 at 1:47 PM
    motocrossman99
    motocrossman99 [OP] New Member
    Josh
    2019 Barcelona Tundra SR5
    i've been doing some research on what type of audio upgrade i want to do and cant seem to find the answer to one of my questions.
    In the double cab if i go with component speakers in the rear where would i mount the tweeter part of the speaker or would you do components in the front and coaxial in the rear?
    Ive browsed ********* and tech12volts packages but i dont see the pictures of the rear or when i do its a crewmax configuration.
    Thanks
    Eric32444 likes this.
  2. Apr 21, 2019 at 5:15 PM
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    watching this also...
  3. Apr 22, 2019 at 6:15 AM
    motocrossman99
    Josh
    yeah i hope it gets traction at some point. i'm not ready to upgrade yet due to funds but i like to plan things out :)
  4. Apr 25, 2019 at 5:21 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    On the CM its mounted to the right of the lock/handle. D6135A12-1D42-4707-B22A-AA9DCCBAD634.jpg
  5. Apr 25, 2019 at 6:41 AM
    motocrossman99
    Josh
    oh that my work in the DC as well. ill have to check later today.
  6. Apr 4, 2020 at 12:29 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Anyone figure this out? I'm about to put tweeters in the back panels of my DC...
  7. Apr 4, 2020 at 12:34 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    You have to drill holes for the rear component. When I got mine from tech12volts I just had him send a pair of coaxial speakers for the rear (tweeter stacked with main cone in the door), and add components up front. You wont be able to tell the difference from the front seat especially if you upgrade the dash speakers
    1lowlife and texasrho83[QUOTED] like this.
  8. Apr 4, 2020 at 12:35 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Can you send a pic of the speaker you used?
    Tundyfundy[QUOTED] likes this.
  9. Apr 4, 2020 at 12:39 PM
    Tundyfundy
    Bay Area, CA
  10. Apr 4, 2020 at 2:14 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  11. Apr 4, 2020 at 2:40 PM
    Tundyfundy
    Bay Area, CA
    So after looking i have the K170 not the X170. Looks exactly the same. I think 75w.
  12. Apr 4, 2020 at 2:56 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That is what I did...
    Front: Focal Performance PS 165FX
    Made my spacer out of 3/4 MDF and bought JBL door sails for the tweeters.
    43A85727-0BAB-4627-9E77-856E38144C8A_zps_30248dc7f7b03cf447e18d31a26988063cd3477c.jpg
    B5767B44-33BF-42E9-ACEC-7ED59E995713_zps_bbe03a0902945bdb942265cf7670e96e94fcd3a7.jpg
    689D6A5A-12D7-46ED-8E04-46779903642B_zps_d82ff35472aa8b755437b11dcd1cdeea934fc1ed.jpg
    Rears: Focal Performance 165AC
    Actually ripped out the stock speaker and used the bracket.
    Too tired to make another pair of spacers.
    https://www.crutchfield.com/p_091165AC/Focal-Performance-165AC.html
    D470B1E9-862B-45C9-AD11-BC86D3147A51_zps_2b336e488103a3c40fe734e727a799f63516f3e8.jpg
    DBC6ABDD-3326-4B38-9BD4-21DCA4A06E84_zps_a9b8033e1be1bc3d3382591dad009649c83d4075.jpg
    FA5E5BA1-5D3D-45DB-9B8F-0A65256765FD_zps_0d5857bdf032a439e9f9db144655555136d17c57.jpg
    Had to trim the ring off the inside of the door panels..
    62FB5BE0-4A05-4F42-BE9E-AA50E269F7A9_zps_a6909f0e168a55c3cc27b9b13ba9953cefd6de02.jpg
    Bob likes this.
  13. Apr 4, 2020 at 4:33 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Basically did same as you except that I need to upgrade my rears from the RF 40W speakers I have to something with more oomph and install tweets
  14. Apr 8, 2020 at 8:05 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  15. Apr 8, 2020 at 9:34 AM
    Tundyfundy
    Bay Area, CA
    James sent adapters for the speakers. They fit perfect. Just enough room for the window to roll down.
  16. Apr 8, 2020 at 9:35 AM
    Tundyfundy
    Bay Area, CA
    I guess I did get the x170. I cant for the life of me find an installed pic but they fit perfect with the adapters.similar to this.
  17. Apr 8, 2020 at 10:19 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    He just messaged me back. I'm gonna order them from him. Thanks bro.
    1lowlife likes this.
  18. Apr 8, 2020 at 10:21 AM
    Tundyfundy
    Bay Area, CA
    For sure!
  19. Apr 11, 2020 at 11:14 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Gonna install some of these on them. Think it'll help with sound?
    Tundyfundy likes this.
  20. Apr 11, 2020 at 1:31 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Flip the adapter around! The speaker should be more positioned to the rear to line up with the hole for the door panel - as is ⅓ of the speakers is being covered up by the door panel. I did the same thing at first until I shined a flashlight through the speaker grill one night and noticed the speaker was not centered in the door panel hole.
  21. Apr 11, 2020 at 2:11 PM
    Tundyfundy
    Bay Area, CA
    You are my hero. Going to check now!! Just wow you are absolutely right!!!
    1lowlife and PWMDMD[QUOTED] like this.
  22. Apr 11, 2020 at 3:36 PM
    Tundyfundy
    Bay Area, CA
    Can’t hurt! I used “fast rings”. The door are huge so channeling the sound how you can is smart.
  23. Apr 12, 2020 at 6:47 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just waiting on my adapter rings...
  24. Apr 13, 2020 at 4:30 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
