4.7l tune for the 05-06?
Discussion in '1st Gen Tundras (2000-2006)' started by empty_lord, Apr 1, 2020.
  1. Apr 1, 2020 at 12:26 AM
    empty_lord
    empty_lord [OP] They see me rollin'
    Indiana, Chicagoland
    05 rollover special
    curious to see if there a Tune available for the 05-06 VVTI engines like there is for the 07+ 4.7l.
    (yes this probably has been asked before, but i haven't been able to find answers)
  2. Apr 1, 2020 at 6:51 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I haven't seen anything that is really worth the expense if not supercharged.
    For pre-05 I've had a Unichip that I got on a serious sale back in the day. I think the "out of the box" base tunes don't make much difference. When I installed it the harness intercepts every wire on the ECU, but the actual Unichip module only has about 4 wires going to it. My shift points when WOT have always been a little off since installing, it won't get near redline. I leave it on though because I do like the valet mode when the rare valet need comes up, and the kill switch mode when I leave my truck at LAX on occasion.
  3. Apr 1, 2020 at 7:05 AM
    empty_lord
    05 rollover special
    The unichip doesn’t really interest me. The ov tune is more what I’m looking for. They have tunes out there for the 07 up 4.7. So then I ally the 05-06 should be doable too
    Darkness[QUOTED] likes this.
  4. Apr 1, 2020 at 7:26 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    SO, I have Unichip and what are these modes you're referring to? How do you control these? I have Unichip because I'm supercharged and the TRD ECU took a shit but I didn't install and not familiar with this?
    On the tuning side, you're supposed to be able to tune the Unichip but I can't find anyone locally that has ever used it. I really want to dyno tune my truck once I complete the headers/exhaust how I want. My main mechanic might be open to it if I buy the program for the tuning but didn't seem overly eager to work with it...
  5. Apr 1, 2020 at 7:30 AM
    empty_lord
    05 rollover special
    The newer Toyota ecus can be flashed as far as I know (my 06 avalon has a flash from r9k) yours likely cant be. So
    Piggyback is your best bet.
  6. Apr 1, 2020 at 7:40 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @imDementeD I never found anybody who could tune it either, that's why I've only toggled around on their base tunes. The 5 position switch is needed to have more options available but if you had one tune you really liked you could set that to A and put valet mode on B. Valet mode keeps rpm under 2k.
  7. Apr 1, 2020 at 7:46 AM
    imDementeD
    @Darkness - Not to hijack his post, maybe we can take this to private message but I was told there are (2) tunes stock. (1) 87oct and (1) 93oct but I cannot change this without this switch? Is this something you add and I can switch the (2) tunes? Any pics of how this is wired in/setup? I don't know which mine is currently set at but I run 93oct always.
    Appreciate any info/help on this!
  8. Apr 3, 2020 at 11:54 AM
    NMR@ider76
    NMR@ider76 New Member
    Jesse
    2006 DC Tundra
    5 inch tuff country 35” coopers on mayhem wheels TRD CAM exhaust K&N JET flash
    JET chip tunning is available through them, here is the email they sent me.
    ECU 65002: We do have an ECU upgrade available for your application. Since
    your ECU does not have an easily replaceable chip we do require that the ECU
    be sent to us for programming. Our ECU upgrade kit contains everything
    needed to pack and ship the ECU to us and includes complete instructions,
    ECU location chart and our programming specification sheet that you fill out
    so we know what upgrades have been done to the vehicle. Next day air return
    shipping is also included in the price. The part # to fit your vehicle is
    65002, which retails for $399.00. The kit is available through JET directly
    or through any of our dealers. Once we receive your ECU it will be
    programmed according to the vehicle specification sheet to optimize the fuel
    and timing curves for your specific modifications. For best results the ECU
    upgrade should be done after you complete all of your other upgrades so we
    can program specifically for them. We also recommend using at least 89
    octane fuel due to the modified ignition advance. Horsepower gains will vary
    depending on how the vehicle is modified, but average gains are 8-10
    horsepower to the drive wheels. If you have any questions you can reach our
    tech department toll free at 800-535-1161. Our hours are M-F, 8-5 PST. Our
    chips and modules are designed primarily for performance gains, but we have
    had customers report increases in mileage, probably due to the advanced
    timing curves. We do not guarantee mileage gains with our products.
    Darkness likes this.
  9. Apr 5, 2020 at 9:46 AM
    empty_lord
    05 rollover special
    The only real reason I ask is I did see a post over on Tacoma world a while back from orange virus (I believe) stating they
    Had cracked the 1st gen 05-06 ecus. Was wondering if anyone else had heard anything really.
    My buddy sent his ecu into jet for a different car. Never really saw any gains from a/e they did.
