  1. Mar 29, 2020 at 10:11 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Rear disc may happen this year, we’ll see. Taco gets it first though.
    bmf4069[QUOTED] and Tundra2 like this.
  2. Mar 29, 2020 at 10:11 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    After getting steering wheel controls going after new HU install with an ASWC-1, found out if I can find the right side phone button assembly, I can add to project. All that to say, thru searches it appears the existing left side buttons should lite up. Anyone ever replaced the what are supposed to be LEDs on the below switch board ?
    NUDRAT likes this.
  3. Mar 29, 2020 at 10:12 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    All back together again. No left over screws like IKEA furniture. This was a fight to go back. That's probably the hardest job I think I've done so far THIS weekend.
    It's lit fam. I look forward to tonight. Time for a quick vacuum, and then the carpet gets a vacuum. Then install.
  4. Mar 29, 2020 at 10:17 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not on those but I've removed similar. It's doable but you need a good soldering iron. Every time I've done it's been in an electrical lab on campus.
    BubbaW[QUOTED] and Tundra2 like this.
  5. Mar 29, 2020 at 10:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    :confused:Okay, I'm a little embarrassed to say, but I can't remember the proper orientation of the rear seat belt receivers. I would appreciate just a rough idea photo. A picture of the back seat should suffice. Thanks
    :anonymous:
    Here is where I'm at.
    Looking at the gravel under the truck it's time for a few more loads.
  6. Mar 29, 2020 at 11:57 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Okay, since I took a little break to put some food in my belly I'll just model it after the front seat. Lap belt mounts on the drivers side, and receives on the passenger.
    Good enough. :thumbsup:
  7. Mar 29, 2020 at 12:00 PM
    Right but ICON explicitly states you should remove the overload spring, and that you'll still get 1.5" lift. That's B.S for the majority of people. You only got 1.2" WITH the overload. Had I known, I would have ignored their instructions and left it in.
    lamboboy732 likes this.
  8. Mar 29, 2020 at 12:10 PM
    empty_lord
    05 rollover special
    1.2” with a cap. I’d guess closer to 2” with the cap off. Another thing to remember is they assume new leaf springs or newer, with the age of our trucks the leafs are beginning to sag. I was ready to have these rearched if it wasn’t high enough. I could see when I Was putting the new stuff in how much flatter the original leafs were compared to the AAL.
  9. Mar 29, 2020 at 12:43 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Attacked the muff today after finishing off a Fleet Car Repair.
    The muff was on her way out boys. Glad its replaced and whoever recco’d replacing the clamp/bolt, and gasket with new OEM ones gets credit as the old were unusable. Pretty straight forward job that took about an hour. Sounds just like the day it drove off the lot. The old one wasn’t loud at all, but this new one is very quiet. Stoked!
  10. Mar 29, 2020 at 1:11 PM
    empty_lord
    05 rollover special
    working on the body harness today... half way out.
    NEW [​IMG]
    old coming out
    once this is all installed the trailer shit should 100% work. i have to straighten out the hitch where the 7 way goes. but thats easy.
  11. Mar 29, 2020 at 1:37 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Roof rack install completed. Posting on my build page more info.
  12. Mar 29, 2020 at 1:54 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    My radiator sprung a leak yesterday, crack across the top which is a pretty common failure point. The dealership has two listed on their website, one of $159 and one for $357. Anybody know what the difference is?
  13. Mar 29, 2020 at 2:00 PM
    Fred
    Hand Protectors
    Go to ToyotaPartsDeal.com and plug in your vin# then come back and cross check the part number with your stealer site. I believe the difference is brackets included and if the rad has transmission cooler ports. Irregardless, your vin will let you know.
    NUDRAT likes this.
  14. Mar 29, 2020 at 2:39 PM
    Can't help with that but it's a good time to flush the whole system. 2 drain plugs on the bottom of engine block!
    NUDRAT likes this.
  15. Mar 29, 2020 at 3:59 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Rock Auto has a Denso OEM radiator for ~$130
    Filthyphil, oscardog86 and NUDRAT like this.
  16. Mar 29, 2020 at 4:51 PM
    empty_lord
    05 rollover special
    New used one next to old one
    NUDRAT, mcharfauros, Tundra2 and 3 others like this.
  17. Mar 29, 2020 at 6:07 PM
    empty_lord
    05 rollover special
    Annnd it’s in. Cant find the brake control to test it right now. I’ll check tomorrow. But as of now everything works just have to get the rear 7way/4way installed
  18. Mar 29, 2020 at 6:30 PM
    empty_lord
    05 rollover special
    She’s also Sittin perfect to me. Little bit of rake [​IMG]
    NUDRAT, lsaami, Trailscape and 15 others like this.
  19. Mar 29, 2020 at 6:59 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I finally got off my ass and did the Nakita reverse cam and took tons of pics. Maybe tomorrow I’ll do a write up to show y’all the easy route.
  20. Mar 29, 2020 at 7:17 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Thatd be awesome man! I just ordered one and would love to have any extra info I can get before I possibly try this myself.
    NUDRAT and Tundra2 like this.
  21. Mar 29, 2020 at 8:41 PM
    empty_lord
    05 rollover special
    My fucking headlight bulb just blew up when I was driving. This is an oem new headlight with the bulbs it came with installed[​IMG]
  22. Mar 29, 2020 at 8:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    If I recall correctly, and I might be wrong. Your rollover special was mangled when you first started working on it. Its come a long way if so, EITHER way Great job man! :thumbsup::eek:
  23. Mar 29, 2020 at 8:54 PM
    oscardog86
    Southern California
    Thinking about upgrading my bilstein 5100s. Whats the next best upgrade? I see OME on Toytec for about half of Icon and King. Theres also the next level Bilstein 6200 or something? Just wondering what a good budget yet next upgrade from 5100s for extra lift for bigger tires and decent on and offroad ability would be. Thanks guys! By the way, im looking for around 2 to 2.5 inches of lift.
    Im also thinking of getting some 255 85 r16 tires for this new setup. Should these 33" clear 2 or so inches of lift?
    Also looking at a new deaver leaf pack. Is that a good choice? I have an AAL that id probably take off my current setup and add to the new deaver leaf pack. That should get me around 2 inches of lift?
  24. Mar 29, 2020 at 8:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Man, that stinks. Those aren't cheap either.
    empty_lord[QUOTED] likes this.
  25. Mar 29, 2020 at 9:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Its LIT! Lol
    I am intrigued by the yellow light from the cargo lamp, and ring though.
    What are yall's "thinkings" on this?
    Just dirt? I know the cig light is super clean. I made sure of that. I used the same bulb I had used for everything else. Cool white 4000k, 17 lumens. (I'm not 100% of the 4000k off the top of my thinker.)
    Does it throw off the clean look of everything?
  26. Mar 29, 2020 at 9:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  27. Mar 29, 2020 at 9:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Just verified proper operation of center footwell vents, and of ball cooler.
    :thumbsup::headbang::proposetoast::woot:
  28. Mar 29, 2020 at 9:13 PM
    empty_lord
    05 rollover special
    The bulbs probably too tall and touching the plastic on the lighter housing. And with age the plastic has turned yellow.
    NUDRAT likes this.
  29. Mar 29, 2020 at 9:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Very well could be. My pops used to smoke in this truck. Hell, I did too. I forgot about that for a minute. Definitely could be a factor too. That's another reason I did a full deep clean like I did.
    NUDRAT likes this.
  30. Mar 29, 2020 at 9:18 PM
    empty_lord
    05 rollover special
    My shift l button has a yellow glow because of the plastic colour and the way the light bounces off it. I’m going to try some reflective tape on the plastic to hopefully get white like the rest
    Tundra2[QUOTED] likes this.
