VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. Mar 23, 2020 at 7:50 PM
    #3091
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    this is what worked on my 19
    Jump Pins 4 & 13. Turn key to on for 20 minutes. Turn off. Truck should start.
    https://youtu.be/HQXgbSUQ0Yo
  2. Mar 23, 2020 at 8:01 PM
    #3092
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Could you elaborate what the ECU handshake is for? I'm interested in getting the OvTune as well, could we flash our current ECU to a 2018 version? Or is it a hardware issue?
  3. Mar 23, 2020 at 8:31 PM
    #3093
    shellshock
    Iowa
    2019 TRD PRO
    If you physically swap the ECU in a truck, the immobilizer does its job and keeps the truck from starting. You have to go through a pairing process to accept the new ECU.
    you can’t just flash a different ecu code revision to the ecu.
    MR TRD PRO likes this.
  4. Mar 24, 2020 at 2:48 AM
    #3094
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
    2020 Super White TRD Sport Tundra
    2" level, 34 Mickey Thompson ATZ, tint, Magnuson SC, pedal commander and katzkin leather
    that’s the thing with my 20, for pin 13 there is nothing there. Meaning there is not a wire on that pin. So if I jumped 4 and 13 as is then it would do nothing. Since I can’t get TIS to work I’m stuck since I can’t look up the diagrams.
  5. Mar 24, 2020 at 3:07 AM
    #3095
    shellshock
    Iowa
    2019 TRD PRO
    Are you sure you are looking at the connector the right way? If I remember right, in mine it’s upside down (rotated 180 from the picture). So 13 is actually the top row and 4 is the bottom row. And 14-16 are all blanks like you describe.
    so it’s the 4th pin from the left in the top row, then you go straight down and one to the right.
  6. Mar 24, 2020 at 3:31 AM
    #3096
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
    this is my connector. Sorry for the picture quality.
  7. Mar 24, 2020 at 5:29 AM
    #3097
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
    @OVTune I have been trying to reach out to you. Is there I number I can contact to help figure out this issue? I've sent a couple emails to Zendesk too.
  8. Mar 24, 2020 at 7:02 AM
    #3098
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    if you can get the wiring diagram you should be able to do it at the ECU as well if they don't run it up to the OBD connector any more.
  9. Mar 24, 2020 at 7:31 AM
    #3099
    Why can't you just flash a revision to the ECU? I have done it before through techstream on my Tacoma.
  10. Mar 24, 2020 at 7:53 AM
    #3100
    shellshock
    Iowa
    2019 TRD PRO
    That’s super weird. Yeah that’s definitely different.
  11. Mar 24, 2020 at 7:54 AM
    #3101
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The person he's trying to help has a 2020MY, there likely aren't any revisions. The avenue that appears to be available to get OVTune on a 2020 is to swap in a 2018 ECU and program it for that newer vehicle.
  12. Mar 24, 2020 at 7:56 AM
    #3102
    shellshock
    Iowa
    2019 TRD PRO
    You can flash updates, just like the Tacoma with techstream.
    you cant just pick a random code revision and flash it. It won’t let you.
    for example on the Tacoma, you could update 04b03 to 04b04. But you cannot go from 04b03 to 04b31. You also cannot go backwards from 04b04 to 04b03.
    same deal with the tundra.
  13. Mar 24, 2020 at 8:00 AM
    #3103
    shellshock
    Iowa
    2019 TRD PRO
    Yup. Typically if there is an update, mat can get the TS CUW file to the unpack the code and use that to start figuring out how to tune it. Without any updates, you have to get the ecu code by dumping the contents from the ecu which is much more difficult.
    Wynnded[QUOTED] likes this.
  14. Mar 24, 2020 at 8:03 AM
    #3104
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Thanks, for a minute there I was second guessing that I was mixing up two slightly different subtopics and spewing garble.
  15. Mar 24, 2020 at 8:06 AM
    #3105
    shellshock
    Iowa
    2019 TRD PRO
    Also keep in mind, the steps may sound basic but there’s no how to on how to do any of this stuff. It’s not like you just buy an adapter, hit a few buttons and you’ve got what you need.
    the code is written in assembly which is a low level machine code and incredibly difficult.
    also throw in some other curveballs like encryption and no documentation and that’s why this takes a while for updates and to add new ecus.
    PeakIT likes this.
  16. Mar 24, 2020 at 9:02 AM
    #3106
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
    I finally got access and that terminal is gone on the 2020. So you can force it through techstream but when I try to connect to the ecu @OVTune sent me it will not connect to it in techstream. I get communication errors.
  17. Mar 24, 2020 at 9:09 AM
    #3107
    shellshock
    Iowa
    2019 TRD PRO
    Are you running a version of TS with support for the 2020 model year? There was one floating around on tw that didn’t work on 19+ trucks. I don’t remember the number off hand.
  18. Mar 24, 2020 at 9:14 AM
    #3108
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
    Yes the version is compatible. I can access everything on the original '20 ecu.
  19. Mar 24, 2020 at 11:33 AM
    #3109
    Gotcha. Thanks for the clarification.
  20. Mar 24, 2020 at 1:02 PM
    #3110
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Anyone receive updated tunes? Any significant improvements to report?
    mzim and TruckyTruck like this.
  21. Mar 25, 2020 at 6:16 AM
    #3111
    coTony
    Tony
    Montrose, CO
    nope :turtleride:
    2Tall likes this.
  22. Mar 25, 2020 at 6:18 AM
    #3112
    Sbrakeville
    Sbrakeville Go Hawkeyes
    Scott
    Plano,TX
    2018 Tundra TRD sport
    Nothing yet
    2Tall likes this.
  23. Mar 25, 2020 at 7:35 AM
    #3113
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    i'm in the 07-09 bucket, still waiting but i know worth the wait too
    Rex Kramer likes this.
  24. Mar 25, 2020 at 11:09 AM
    #3114
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I too am interested in an offering of a 2018 ecu, pre-tuned from OVTune. If that's the only way to do it.
    Rustyscrew and MR TRD PRO like this.
  25. Mar 25, 2020 at 2:06 PM
    #3115
    MR TRD PRO
    MR TRD PRO New Member
    Queens, NYC
    2019 VooDoo Blue Tundra TRD Pro
    HP Tuned
    I would be too.....plug and play
    Rockgate[QUOTED] likes this.
  26. Mar 26, 2020 at 3:11 PM
    #3116
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    18 ECUs are considerably expensive ($1000+).
    anyways, I wanted to let everyone know that we are making some business changes due to recent events related to COVID-19.
    First, we are no longer going to sell Tundra tunes / flash kits. A few reasons for this.
    1. We have enough work to catch up on and updates to push out, and I don't want to be overloaded.
    2. Supply chain issues.
    3. We are moving forward with our release of our vF Tuning software, which will support the Tundra. This will allow people to tune their own trucks if they want to.
    This will not affect current tunes or people who want updates / patch stuff, etc. We just won't be taking on tuning of new Tundras.
    However, that doesn't mean you're completely left out. Because our vF Tuning software will come with some "example" Tunes that you can use to build upon, or a reference from. They will be some tunes we have already created for you guys.
    So you have the option to use/modify/create from an example, or completely build your own.
    Also if you have our flash kit you can also get vF Tuner
    So1988, tundra_20, mzim and 7 others like this.
  27. Mar 26, 2020 at 3:18 PM
    #3117
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    :fistbump::hattip::yes:
  28. Mar 26, 2020 at 3:26 PM
    #3118
    apbreaux
    apbreaux New Member
    Paul
    CO
    2016 Tundra DC
    Intake, exhaust, remote starter, LEDs everywhere, OVTune
    Mat,
    This is really cool. Can the tranny be tuned with vF Tuner?
  29. Mar 26, 2020 at 3:27 PM
    #3119
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    engine. transmission. torque converter. pressures, etc
  30. Mar 26, 2020 at 3:30 PM
    #3120
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Ditto.
Thread Status:
