Adding a bed rail system to a CM with a spray in Bed-liner?
Discussion in 'General Tundra Discussion' started by johnxmccoy, Jan 23, 2017.
  1. Jan 23, 2017 at 1:49 PM
    johnxmccoy
    johnxmccoy [OP] New Member
    Grove City, Ohio
    2019 Crew Max
    Has anyone experienced doing this?
    I want to add this to a bed with a spray in liner already completed.
    Thanks.
  2. Jan 23, 2017 at 1:56 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    I've done it. Piece of cake. The place that sprayed it should have left the mounting points exposed.
    jewsNbrews and Relentless like this.
  3. Jan 23, 2017 at 2:04 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    It is from the factory this way, the covered holes.
    Thanks.
  4. Jan 23, 2017 at 3:44 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    How do you do it?
    Did you have to drill out the bed liner, how did you find the holes?
    Just a little bit more details please.
    Thank you!
  5. Jan 23, 2017 at 3:47 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    They sprayed over the holes? Oh man, that sucks. I would get some measurements for you using my truck, but I have a double cab.
  6. Jan 23, 2017 at 4:03 PM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    It comes from the factory this way.
  7. Jan 24, 2017 at 3:02 AM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I apologize for not being 100% clear.
    With the factory spray in bed liner the holes are covered 100%, no holes are visible where the rail bolts onto the side of the bed.
    So, no holes are visible, they are covered by the spray. So do you just use metal screws and drill through the bed and the bed liner? How does it attach?
    The Bed rails are a sticking point on buying this certain Tundra due to me using my ladder racks for kayaks when we go camping.
    That is my question.
    Thanks.
    NewImprovedRon likes this.
  8. Jan 24, 2017 at 3:15 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Your bedliner must not be factory gotta be dealer installed. There are holes with threads in bed walls. Gonna be pretty hard to find them but if you can drill them out with a small bit 1/8in or so then run a tap through holes to clean out threads I think it was 8mm x 1.25 thread
  9. Jan 24, 2017 at 3:53 AM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    It's factory installed option on window sticker not aftermarket.
    Thanks for your reply.
  10. Jan 24, 2017 at 8:27 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Just try to get someone with a CM to measure exactly where the holes are. Or better yet take a pic of the tape measure on the holes. Should get you close enough to drill a tiny pilot hole and find them.
    *edit- make dealer install it. Tell them you know 3000 people who have bedliners and not one had their holes filled. Lol holes filled. If that doesn't work then plan a.
    jewsNbrews and Pudge like this.
  11. Jan 24, 2017 at 8:32 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    This warrants a complaint to the Toyota regional office. There's no reason the holes should be filled except that the bedliner installer was lazy. What would the dealer have done if you'd purchased a dealer installed set of rails?
    Tundyfundy likes this.
  12. Jan 24, 2017 at 8:43 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    If you haven't bought it yet I would make the dealer fix the holes. They should have been plugged before spraying. If the factory liner is as hard as Linex, you're screwed trying to do it yourself.
  13. Jan 24, 2017 at 8:54 AM
    Polly3685
    Polly3685 New Member
    Michael
    2016 Silver Sky Metallic SR5 TSS Off-Road
    TRD exhaust and intake. Pocket fender flares. Line-X: chrome grill, chrome bumpers, fender flares, rocker panels. Deck rail /w tie down cleats. Undercover Swing Case x2. All weather mats. Stereo system with custom underseat sub box and TacoTunes recurve EZQ.
    Make the dealer fix it! The holes should not have been covered, mine were not and I added the deck rails with no problem. Took less than 5 min.
  14. Jan 24, 2017 at 9:38 AM
    TheBeast
    TheBeast The Beach
    have the dealer fix it. If you are buying the truck from them ,have them throw the rails for free as well. Only $180 msrp or so.
  15. Jan 24, 2017 at 9:52 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    agree. just have dealer install them. then its on them not you. done and done!
  16. Jan 24, 2017 at 9:55 AM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Thanks. I'll suggest the dealer accomplish this task.
  17. Jan 24, 2017 at 10:03 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    I've got a CM with this set up (spray in bed liner and rails). If the OP doesn't get this resolved with the dealer, let me know.
  18. Jan 24, 2017 at 2:27 PM
    Scottri
    Scottri New Member
    Scott
    West Linn Oregon
    2017 Quicksand SR5 TRD Off Road
    If you have the rails hold them up to the bed side where they will be installed. The mounting holes on the rails match up to the pre-drilled holes on the bed. It will give you a real good idea of where the holes are that are covered.
  19. Jan 30, 2017 at 2:55 AM
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Had the dealer drill the holes out and picked her up yesterday. Bed rails installed no issues.
    Thanks.
    New 2017 Barcelona Red.
  20. Jan 30, 2017 at 8:51 AM
    Polly3685
    Michael
    Awesome! Good to see the dealership making it right. Glad you weren't left holding the bag.
  21. Dec 15, 2017 at 7:09 PM
    InfernoToyo
    InfernoToyo New Member
    Barty
    Inland Empire
    2018 Inferno Limited
    I know this is and old thread but what exactly did you tell the dealership about not having the pre-drilled holes exposed due to the spray-on bed liner. I'm asking because my truck has spray on liner with no holes exposed
  22. Dec 15, 2017 at 8:21 PM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Same with me. I currently have a case open with Toyota corporate to fix the issue. Waiting to hear back from the dealership. They have until Monday to respond.
  23. May 31, 2018 at 7:45 AM
    codyneedles
    codyneedles New Member
    Roseburg, OR
    2015 SR5 Crewmax
    remote start, diamondback cover, oem led headlights, led fog lights
    I just bought a used 2015 crewmax and it has the spray in bed liner and they covered all the mounting holes an im wanting to have the deck rail system put in but not sure how to locate the holes. I tried the Toyota dealership that the truck was purchased at when it was new and they could not help me so I tried talking to Toyota HQ and that didn't go very well. does anyone know how I can locate the threaded holes or measurements for them so that I can get this done. thanks
  24. Jun 29, 2018 at 6:05 PM
    Privett10
    Privett10 New Member
    Benjamin
    2017 Black CM TRD OR Tundra
    5% Tint, Tonneau Cover, Window Visors!
    Mine is the same way. 2017 CM. Holes are covered. How do I get this fixed?
  25. Jun 29, 2018 at 6:09 PM
    InfernoToyo
    Barty
    Inland Empire
    If you bought new. I would take it back to the dealer I bought it from. That’s what I did and had them fix it by retreading holes
  26. Jul 2, 2018 at 9:50 PM
    geno0506
    geno0506 New Member
    Michael
    I added the rail system after I got my Tundra new with the spray on bed liner, easy peasy! Got a good deal from a forum member that sold me his!
  27. Jan 4, 2019 at 2:21 PM
    Twise
    Twise More punk than you...
    Trever
    Temecula, California
    2017 Tundra Cmax TRD Off-road
    Fox 2.5 /w DSC CO’s and Rear Shocks, Total Chaos UCA’s, 17” Rock Warriors /w 35 12.5 17 BFG AT KO2’s, Powerstop Rotors and Pads Front And Rear and The stereo is really nice.
    I took an awl and held the rail up against the mounting location. Awl pushed through the liner fairly easy. Once all holes were found, I just kissed them with a countersink bit to remove the liner material. Final xacto surgery and the factory torx screws went right in.
    2 beers and is the reason it took an hour. Anyone in SoCal with 2 beers and an hour is welcome to attend the seminar.
    This is a molehill, not a mountain.
  28. Apr 18, 2019 at 2:01 PM
    RhinoChaser
    RhinoChaser New Member
    I have the same issue. The threaded holes are covered. Just want to verify that there isn't a version of the bed that doesn't have the threaded holes...
    There appear to be threaded nuts up by the cab.
  29. Apr 19, 2019 at 3:44 PM
    Twise
    Trever
    Pretty sure they all have the holes. Take an awl or something pointy and poke around. You’ll find it. When you do, line the rail up with it and it will show you where to poke around for the rest of them. Then take an xacto knife and cut away the bed liner material. Happy hunting.
  30. Apr 19, 2019 at 8:42 PM
    RhinoChaser
    Thanks! I used a small magnet and was able to find a spot that caused it to wander so I am assuming a void was there. There are definitely threaded holes up by the cab that are covered by the liner. Getting an M6x1 tap just in case.
