Front brake job
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Mar 1, 2019.
  1. Mar 1, 2019 at 8:21 PM
    bmf4069 [OP] Yup, that's car parts in a dishwasher
    I had a little free time after work and before it got nasty tomorrow so I finally did my front brakes. I bought the power stop 13WL kit from rock auto to replace my 13WE. They were definitely warped, seeing as how it shook horribly from 70-50 mph on deceleration. Not a bad job. About 3 1/2 hours, but that's with slow, pics taken, and bleeding all the brakes. Twice. On with the pics.
    The power stop KCOE2324 kit. The mounting hardware for the pads comes with it. You may or may not want another brake grease packet.
    Caliper and pads.
    Caliper, pads, and hardware.
    My recommended lug nut removal tool.
    The old stuff.
    Doesnt look too bad, but not great either.
    Had to trim the dust shields to fit the new calipers. (This is too much on the bottom.) If it was a street car I would've just taken them off.
    Test fit after cutting. Looks can be deceiving when you're eyeballing a caliper being held with one hand at dusk.
    What I cut off.
    Caliper and rotor mounted.
    All assembled.
    Purdy. New lug nuts installed too. Torqued to however tight my impact goes.
    From the underside. Stupid fat finger.
    From the underside with no fat finger.
    The old hardware.
    Drivers side hardware.
    Tools used.
    My gf took a pic of me hard at it so I figured I'd throw it in.
    So after I finished the swap I bled all the brakes since I dont think I did a good job after the rear brakes. I got a ton of air out, filled 2 20oz bottles with bled out fluid, and bled them twice. And 3 times on the rear of you count after the rear brake job.
    Notes on the job.
    I'm not sure about stock 13WL calipers, but with the power stop kit you WILL need to trim your dust shields. A breaker bar will be handy as the mounting bolts are torqued to 90lbs. Also of note, the blenders on the PS kit are 8mm, not 10mm like the rears and brake lines.
    All in all not a hard job. About 6 one packs in all. Any questions, comments, or stories about the time you you got drunk and hid in a dumpster to evade the cops in Tijuana are welcome.
  2. Mar 1, 2019 at 10:35 PM
    Aerindel
    Aerindel New Member
    Montana
    I'm thinking about this myself. I have warped rotors as well, and they are only a year old, so I'm thinking about the upgrade.
    So what is the actual technical difference between calipers? Why are the WE bad and the WL good?
    MrAristo likes this.
  3. Mar 1, 2019 at 10:54 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Interesting that there seems to be a trend of aftermarket calipers using 8mm bleeders. They kind of scare me, not much strength in a hollow bolt that skinny. Looks good, I over did the trimming as well when I did this.
    Never hide in the dumpster in TJ, that's the first place the cops look. Better off to find a really big sombrero and hide in that.
  4. Mar 2, 2019 at 12:08 AM
    Hmmm, never thought about using in a sombrero....:hattip:
  5. Mar 2, 2019 at 3:48 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Looks good! Only thing I'll add is to go buy yourself a proper torque wrench for the lug nuts, you're not doing your new lug nuts or rotors any favors cranking them on.
    bmf4069[OP] likes this.
  6. Mar 2, 2019 at 6:30 AM
    I've got one. I'll torque em down proper.
    NewImprovedRon likes this.
  7. Mar 3, 2019 at 6:24 AM
    Bonipart
    Bonipart New Member
    2002 Tundra Limited TRD
    Found great prices at Autoanything.com no tax & free shipping. This is where I purchased my brake kit front & rear. Good experience with phone support as well. Have a 2002 Tundra Limited single owner with 333333 miles on it. Been to every state except HI.
  8. Jan 18, 2020 at 6:51 AM
    Professional Hand Model
    Fred
    Hand Protectors
    This is an awesome write up. Should be a sticky.
  9. Jan 18, 2020 at 7:04 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Been doing this too long to use a torque wrench..........anyways, WHY are people trimming the shield. I didn't have too .
  10. Jan 18, 2020 at 7:52 AM
    Powerstop kit.
  11. Jan 19, 2020 at 6:18 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    :rockband: I was waiting for it, you win the prize. :rimshot:
  12. Jan 19, 2020 at 7:00 AM
    Fred
    Hand Protectors
    @bmf4069
    Did you ever install those shim wow parts?
  13. Jan 19, 2020 at 7:23 AM
    I just got my jack back from the shop yesterday. 2 month fix on an $80 jack. But it was free since he didn't fix it right the first time. So if it's nice next weekend they'll go in.
  14. Jan 19, 2020 at 7:35 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    This works too
  15. Jan 19, 2020 at 8:07 AM
    Fred
    Hand Protectors
    Awesome!
    Darkness[QUOTED] and 10TundraSR5 like this.
  16. Jan 19, 2020 at 6:46 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Nice work...thanks for the pix. Yeah, ditch that impact and use a torque wrench. You may not always have access to that impact or a trucker's 4-way on the side of a nasty road when you have a flat to change. Stay out of dumpsters in TJ, as noted...grab an empty Mescal bottle, big sombrero and recline on a plaza bench, if they roust you just pee your pants than stagger off grumbling. They won't follow...they'll figger your broke and drunk, and SOILED. Forget that man.
  17. Mar 18, 2020 at 3:44 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    OP, thanks for the write up and pics. I've added this kit to my Tundra Amazon list. Will be doing this upgrade later on.
    1kTyy_1 and bmf4069[OP] like this.
  18. Mar 19, 2020 at 12:17 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    So how is the braking now? Do you think it has improved over the we setup?
    Or should I just upgrade to the Lexus brakes?
  19. Mar 19, 2020 at 12:42 PM
    fytedapowr
    fytedapowr New Member
    Jake
    Austin TX
    '15 1794 4x4
    Bilstein 6112/5160, CB +2 shackles, SPC UCA's, CB bumper shims, 35's
    I'll add that the brake dust shield you cut has been since updated to allow venting (holes cut in it), which has helped a lot of people with warping issues.
  20. Mar 19, 2020 at 12:46 PM
    It's better, but it was awful before, so I think it's back to stockish. Better fade and warping resistance I'm hoping.
  21. Mar 19, 2020 at 1:53 PM
    Fred
    Hand Protectors
    I bought some of your Shim Wows from Stealership. Wuuu weee! on the price tag. So far so good on my 13WL. Your pics helped me out.
    bmf4069[QUOTED][OP] likes this.
  22. Mar 19, 2020 at 3:08 PM
    Damn, I forgot about those. They got put in the parts pile and forgotten!
    TX-TRD1stGEN likes this.
  23. Oct 23, 2021 at 5:55 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    So these are just bolt on? I remember reading somewhere that shims needed to be installed to center the caliper with the rotor.
  24. Oct 23, 2021 at 1:25 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Bolt on.
    FYI if your truck is 04 or newer it probably already has them. I can't remember if 03 had them as well (maybe only partial year?).
  25. Oct 23, 2021 at 1:40 PM
    Riverdale21
    OTP ATL
    10-4, did a search and it is the 14WA caliper that needs adjustment to fit.
  26. Oct 23, 2021 at 3:57 PM
