Every light on the dash turned on with a bunch of warnings
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Californian, Mar 12, 2020.
  1. Mar 12, 2020 at 5:03 PM
    The Californian
    The Californian [OP] Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Just had every light on my dash turn on, 4HI and 4LO flashing, with the warnings “Trailer brake error, if towing come to a safe stop with manual controls. Contact dealer”, “Pre-Collision System malfunction, Visit dealer.” “Keyless Start/Stop system malfunction, visit dealer.” Truck runs fine, can’t notice any problems. Just dropped it off at the dealer and they seem to be at a loss. Anyone have this happen? 2020 TRD Pro with about 4K miles on it.
    Edit: Dealership just told me that they’re showing a leak somewhere in the speed sensor - they say they’re not sure if it’ll be covered under the warranty.
  2. Mar 12, 2020 at 5:43 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Not sure it's under warranty??????? LMFAO....wow
    Guess bumper to bumper doesn't mean shit to them. Call Toyota corporate and complain
    Cpl_Punishment likes this.
  3. Mar 12, 2020 at 5:45 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    A leak in the speed sensor? Didn’t know wires could spring a leak. Lol. Unless they mean a loss of information which means either the sensor went bad or there’s a break in the line
  4. Mar 12, 2020 at 5:50 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Ha, my thoughts exactly when I read that :rofl:
  5. Mar 12, 2020 at 5:52 PM
    johnnyskullface
    johnnyskullface New Member
    Beaverton, Oregon
    2018 White Tundra Limited Crewmax
    Did it just rain a lot in your area? I’ve seen some really unexplainable things electrically that ended up being water on a junction block. Especially driver or passenger side kick panels.
  6. Mar 12, 2020 at 5:56 PM
    The Californian
    Eric
    I’m gonna give them a chance to fix it before I tear the walls down.
    Advisor said there was a leak, paperwork says “c1330 - Open right front speed sensor; c1464 Front right speed sensor”
    I asked him “What exactly is it leaking.” And he said “I’ll have to ask” haha
    Pouring rain, and I had just been driving in it for about an hour.
    Hostage81 likes this.
  7. Mar 12, 2020 at 6:28 PM
    Squatting Pigeon
    Holden
    North Texas
    Poor guy wasnt ready for follow up questions, eh? :rofl:
  8. Mar 12, 2020 at 6:29 PM
    plinyyounger
    plinyyounger New Member
    Ken
    Idaho
    2025 Tundra limited
    3-2 lift, KO3’s, Fuel wheels, tint.
    Give the dealer some time, no need to jump on them yet like you said. I like your attitude! :fingerscrossed:
  9. Mar 12, 2020 at 7:22 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Are you sure Toyota didn't start using Lucas electricals?
  10. Mar 12, 2020 at 7:30 PM
    The Californian
    Eric
    Good vibes only.
  11. Mar 12, 2020 at 7:30 PM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    Hopefully they can give you another truck to drive while the repair is done.
  12. Mar 12, 2020 at 7:31 PM
    The Californian
    Eric
    Not at all.
  13. Mar 12, 2020 at 7:32 PM
    The Californian
    Eric
    They offered me a Corolla. I said I’ll roll the dice on driving it another day and drop it off tomorrow afternoon when I get off work.
  14. Mar 12, 2020 at 7:37 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There is certainly some weird communication between you and the service writer.
  15. Mar 12, 2020 at 7:55 PM
    johnnyskullface
    Beaverton, Oregon
    It’s super likely that a junction block is wet. I don’t know how mechanically inclined you are, but if you pull up the skid plate on the driver side and pop the kick panel off I’m betting you will see some moisture. If you don’t feel like going through all that you could try to just let it dry on it’s own, or you could ask the dealer to check for moisture there. I have seen a phantom wheel speed sensor code that I spent way to long trying to diagnose. That was the cause. Let us know!
  16. Mar 12, 2020 at 9:37 PM
    The Californian
    Eric
    But it really seems like this shouldn’t happen. This seems very likely because it was seriously pouring today, and I was bobbin and weavin down the freeway for an hour in this torrential rain - but it really seems like these things should be better sealed. Are there any long term ramifications to it getting wet?
  17. Mar 13, 2020 at 2:41 AM
    Adam New Member
    Your speed sensor is connected to your blinkers, so you should have them top off the blinker fluid as well.
  18. Mar 13, 2020 at 4:39 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Is it possible that the pre collision sensor in the grille got some water in it? There is a recall for this issue where they apply some sealer to the sensor as a remedy.
    Zero One Actual likes this.
  19. Mar 13, 2020 at 1:14 PM
    johnnyskullface
    Beaverton, Oregon
    Of course they should be better sealed, but sometimes seals get rolled on assembly or sometimes the amount of water is just to much for the sunroof drain tube to handle. If it’s a one time occurrence you should be fine. If this happened even occasionally you could get some corrosion in the connectors. The dealer can clean the connectors for you, but they will probably just use a mixture of vinegar and water to clean corrosion. You could let the truck run with the heat on recirculate to try and pull moisture out of the cabin if you have a garage.
  20. Mar 13, 2020 at 4:17 PM
    The Californian
    Eric
    It’s at the dealership now, so we’ll see what they end up doing.
  21. Mar 13, 2020 at 5:11 PM
    The Californian
    Eric
    So the dealership couldn’t find anything wrong with it. The service advisor had a hard time explaining to me why I had to sign a waiver saying I was accepting full responsibility for taking an unsafe vehicle off the lot yesterday, but it’s now apparently sage even though they couldn’t find anything to fix.
  22. Mar 13, 2020 at 5:13 PM
    Danman34
    Danman34 New Member
    Danny
    Wtf? Is your truck completely stock?
  23. Mar 13, 2020 at 11:48 PM
    kgb4187
    kgb4187 New Member
    Warranty covers manufacturing defects, not damage. If a rat chewed his wires Toyota wouldn't fix it for free.
    Ruggybuggy likes this.
  24. Mar 14, 2020 at 2:23 AM
    Zero One Actual
    They just legally hosed you by having you sign that paperwork.
    How far away is the next dealer that is somewhat reputable in your area?
  25. Mar 14, 2020 at 4:21 AM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Corona Virus!
  26. Mar 14, 2020 at 6:46 PM
    The Californian
    Eric
    Completely stock. The advisor was saying my lift may have caused the problem, I had to explain to him it was a stock TRD Pro lift. He was unaware that was a thing.
    PeakIT likes this.
  27. Mar 14, 2020 at 6:47 PM
    The Californian
    Eric
    I think any leverage they would have had legally by having me sign paperwork saying it is unsafe to drive, is null and void after signing paperwork that the truck is in perfect condition, and they couldn’t find any issues with it the following day.
  28. Mar 14, 2020 at 6:48 PM
    The Californian
    Eric
    I have coughed in it a couple of times.
  29. Mar 14, 2020 at 8:55 PM
    Wahayes
    Will
    2017 tundra limited
    The corona virus officially has transmitted from bats to snakes to humans and now tundras. Seriously though I would take it to a different dealer.
  30. Mar 15, 2020 at 3:20 AM
    Zero One Actual
    Did you panic buy oil, fluids and boxes of work shop towels for your Tundra?
