295/70r18 or 305/65r18
Discussion in 'Wheels & Tires' started by khavoc, Jan 22, 2017.
  1. Jan 22, 2017 at 12:19 PM
    khavoc
    khavoc [OP] New Member
    Kyle
    17 trd
    Hi guys! Firstly, thank you for a very informative forum.
    I have a 17 Tundra and can't decide on 295/70r18 or 305/65r18. 18x9 +25s are on the way. I have a Toytec 3/2 Leveling kit installed. Any input/pics would be greatly appreciated.
  2. Jan 22, 2017 at 12:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I have 3/1.5, 18x9 +25 on Cooper STT pro 295 70 18. So really close. The STT Pros run a little big for the size. I had to remove mud flaps, trim and move the liner forward. It's barely clearing and I think I still need to make more room. But I'm clearing the cab mount by about 1/2".
    GodlessPro and boardude like this.
  3. Jan 22, 2017 at 12:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And welcome to the forum.
    GodlessPro and khavoc[OP] like this.
  4. Jan 22, 2017 at 12:48 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
  5. Jan 22, 2017 at 1:26 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    X2. The perfect combo of size and width for a 3" lift IMO.
    xtyfighterx[QUOTED] likes this.
  6. Jan 22, 2017 at 1:45 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I have Nittos G2 295 70s and like them. But I'll probably go back to the Coopers STT 305s once its time to swap them out
    dcsleeper408 likes this.
  7. Jan 22, 2017 at 2:23 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I have a 75 series profile on mine because I think more rubber on the sidewall looks better on an offroad truck. I vote for the 295/70-18
    zcarpenter92 likes this.
  8. Jan 22, 2017 at 3:05 PM
    TheBeast
    TheBeast The Beach
    295/70 or 35"s if they clear.
  9. Jan 22, 2017 at 3:10 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Las Vegas!! Go with the 295/70/18
  10. Jan 22, 2017 at 3:15 PM
    305's. Why go smaller if you don't need too?
    dcsleeper408 and boardude like this.
  11. Jan 22, 2017 at 3:18 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I went 305's and wish I went 295's. 305/65 is shorter than 295/70. With a 3/2 lift the 305's kinda look small.
    CA0FCD19-9FC8-4F57-9938-C6984E328386_zps_c88be2313ff24118c6add7393330b3ebb3aa4574.jpg
  12. Jan 22, 2017 at 3:37 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    305/65/18 is only 33.6 inches in diameter. I vote for 295/70/18. I think in this size group, Nitto Trail Grappler is the tallest and Cooper is the widest. I think STT Pro and MAXX have the same width, if I remember correctly.
  13. Jan 22, 2017 at 3:41 PM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Glad you posted that. Looking at that, I'm going to need some bigger tires if I put that Toytec lift on. Don't want my truck looking like it skipped leg day.
    BlueBottle[QUOTED] likes this.
  14. Jan 22, 2017 at 4:19 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Great....I'm glad your making the right decision under my expense. Now every time I look at my truck I'll think it missed leg day....:benchpress:
    ...I will def be getting 295's next time I need tires whenever that will be....
  15. Jan 22, 2017 at 4:22 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I think your truck and stance look great with those tires. But if you can go bigger than I say doooo it!!
  16. Jan 22, 2017 at 4:24 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Have you considered 305/70r18? These are just shy of 35" but a little narrower ~ 12". This is what I will be going with next
    T-Rex266 and BlueBottle like this.
  17. Jan 22, 2017 at 4:27 PM
    295/70
    BlueBottle likes this.
  18. Jan 22, 2017 at 4:27 PM
    Zharris
    Zharris Merica!
    Sorry bro. Truck still looks good though!
  19. Jan 22, 2017 at 4:40 PM
    I would like to recall my post. I saw "305" and jumped in lol. I run 305/70/18
    :thumbsup:
  20. Jan 22, 2017 at 4:53 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Mostly for the Coopers but I'll be going to 305/70r18 which is about a 35" tire. I originally went with 295s due to clearance concerns and seems to be the preferred size on here. But then @Sean266 put his on and have been :jellydance: ever since
    T-Rex266 likes this.
  21. Jan 22, 2017 at 7:41 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Zharris don't forget to consider what tire you are going with. An A/T tire will be smaller than a M/T even though they are the same size. Check the manuf. website to see the actual diameter of the tire you want to run. Also check @joonbug build, he's on Toytec lift and he is running 295/70's.
    khavoc[OP] likes this.
  22. Jan 22, 2017 at 8:35 PM
    509Tundra
    509Tundra New Member
    2014 Toyota Tundra Platinum
    Weather Tech Mats, Light Bar in front Bumper, Bedliner, Tri-fold, 3-1" Low Range Off-Road leveling kit, MB 352 Wheels, 295/70/18 Cooper ST MAXX tires, shorty antenna...
    I wrestled with the same question two months ago. After comparing the two tire sizes next to each other at Discount Tire (have a picture of them next to each other if you want to see) I ended up going with 18x9 +25 wheels like you mentioned and 295/70/18 Cooper ST MAXX. I love the tires! The look super aggressive, but ride pretty quiet. I also have a 3/1 leveling kit. Only modification needed was to remove the front mud flap. Easy!
  23. Jan 22, 2017 at 8:39 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I would like to see the pics of the tires side by side, please. I'm still debating what tires to get. I want 35s, but BFG has a 65 aspect ratio but I want 70 or more. I don't believe they make that size. So I have to pick before Friday.
  24. Jan 22, 2017 at 9:06 PM
    xtyfighterx
    Ty
    North Idaho
    Where are you located?
  25. Jan 22, 2017 at 9:16 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I have the 295 70 18 Cooper Stt pro. I'm really close to the cab mount and am gonna need to chop it. I think it depends a little on what UCAs you go with. I've got Camburgs and their geometry moves the top of the coil over back farther than any other uca, at least that's what I've been told. I wouldn't wanna go wider 'cause that would exacerbate the rubbing issues in my case. I've got about a + 28 offset and a different offset might help me too.
    GodlessPro likes this.
  26. Jan 23, 2017 at 3:50 AM
    Zharris
    Zharris Merica!
    You're right. I didn't realize that until after I bought my trail grapplers. Little bit wider than the ATs I tested on the truck. Luckily they still fit! Just a little bit closer than expected. Haha even the Toyota dealership said there was no way they'd fit. I'd gone through weeks of calculations and testing and told them put them on. They'd fit. Haha it's always important for anyone shopping tires to check the manufacturers website to see the actual tire size.
  27. Jan 23, 2017 at 3:52 AM
    You'll regret not going 35" while he has your truck!
    TXMiamiFan[QUOTED] likes this.
  28. Feb 2, 2017 at 9:35 PM
    Beep88
    Beep88 New Member
    Ok sorry to beat a dead horse but with factory wheels on a 17 Trd pro will the 295/70r18 rub? Wanting to get a bigger tire but don't really want to cut or chop. I am getting mixed reviews some say they don't rub and others say do.
  29. Feb 2, 2017 at 9:46 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    They will rub, in my personal experience. You need to remove mud flaps, front and rear, in front wheel well. I think you're ok with with the pro skid plate, You'll likely need to move the plastic liner forward and get 1.25" -1.5" wheel spacers.
    joonbug and GodlessPro like this.
  30. Feb 2, 2017 at 9:53 PM
    Beep88
    Beep88 New Member
    Thank u
    831Tun likes this.
