Need speedometer calibration advice.
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrianDLC, Feb 3, 2020.
  1. Feb 3, 2020 at 4:43 PM
    BrianDLC
    BrianDLC [OP] New Member
    Rockland,NY
    2019 White Tundra TRD PRO
    CB RADIO LOL General Grabbers x3
    Hello guys,
    Yessss another nub, so I recently purchased bigger tires for my pro being that we all know the stock Michelin ltx look horrible and they're way too small. So I pulled the trigger on some general grabbers x3 (295/70/18) which I honestly don't have any complaints on but unfortunately my speedometer is off by 3MPH and its killing me. I don't want to lose track of my original miles on my odometer etc. I've looked online for calibrators to purchase but nothing seems to help. The entire truck is stock besides the tires I just mentioned, please any help is well appreciated. Thanks in advance guys!!!
  2. Feb 3, 2020 at 5:54 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Hypertech Speedometer Calibrator
    http://www.hypertech-inc.com/SpeedometerCalibrator.aspx
    Fixed my issue. Mine was off by 11-15 mph after going with 37" tires.
    Not sure what part of the country you are in, but I bought mine from 4Wheel Parts. The link above does not show the actual calibrator. It is a module installed behind the speedometer with a usb cable that you can hook to a laptop and change settings as desired if you change tire sizes.
    Call them to verify but I think the p/n you need is Hypertech 730119. It is listed for 2014-2018. Is the 2019 speedometer different?
  3. Feb 3, 2020 at 6:00 PM
    BrianDLC
    Rockland,NY
    Hey MJoe,
    thanks for the reply, i actually tried their website and after putting in all of my trucks information year, model,engine unfortunately hypertechs calibrator only fits up 2017 tundras, im assuming because the gauge cluster is different. What year is your?
    Thanks in advance......
  4. Feb 3, 2020 at 6:00 PM
    BrianDLC
    Rockland,NY
    Just realized you're in a 16' 1794
  5. Feb 3, 2020 at 6:04 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  6. Feb 3, 2020 at 6:32 PM
    BrianDLC
    Rockland,NY
    thanks brother just went through the entire thread,im going to go through it one more time and confirm what exactly im going to do. leaning towards the rough country being that it runs on hypertechs programs and for 100 bucks cheaper. did you use a calibrator as well, 18s and ups are a little different I see you have an 18.
    Thanks in advance
  7. Feb 3, 2020 at 6:50 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I haven't done it yet. Getting my tires put on next week and was going to see how bad the speedo hit was, then go from there. I'm planning on saving $100 and going the Rough Country route if I decide to get a calibrator though. @azTony has it and I think it worked well on his 2018, minus some quirks with the radar speed control.
  8. Feb 4, 2020 at 3:58 AM
    coTony
    Tony
    Montrose, CO
    I have the Rough Country and the before and after tire size apparently is not correct from the web sites I looked at (Michelin and Nitto) so I had some adjusting to do. When I called and talked to them about it it seemed to be a problem with a "P2xx" size tire vs. an actual size tire it had problems with. If I change the "P2xx" size tire to the actual size (31.9 or whatever it was) then it was much closer. The guy said well you must have to play with it to dial it in.
    :monocle:
    Having said this I suggest when you install the calibrator, install the USB program cable and run it down to where you do not have to take the dash apart to program it. I used a zip tie to hold the wire in place so the connector does not back out from vibration. I was not going to do that but I have had my dash apart twice because I bought a Hypertech used calibrator from a guy on here and when I got it and installed it I seen there was a loose wire but installed it anyway thinking it was fine when he took it off his truck (he said). I was getting all kinds of errors and the dash was not correct so I removed it and seen that was not the only wire loose. The seller told me he removed it from his truck before he traded it in. Long story short I was screwed by the transaction and had to buy another one so I bought a Rough Country.
  9. Feb 4, 2020 at 5:16 PM
    BrianDLC
    Rockland,NY
    guys thank you so much for all the info @azTony and @TRDFerguson, apparently I called a shop and also hypertech and being that I have a 2019 they mentioned there is a difference between the 18 and 19 and that I shouldn't use it until they release a calibrator for the 2019....this sh*t is killing me having my speedo off by 2-3 mph lol I've honestly decided not to drive my truck until its fixed properly, call me weird I guess ....... aaaahhhhh
    coTony likes this.
  10. Feb 5, 2020 at 5:11 PM
    BrianDLC
    Rockland,NY
    I guess the real question here is, has anyone calibrated their 2019-2020 speedo meter with what's available on todays market???? apparently according to hyper tech theres difference between 2018 and 2019...... reason why they haven't released anything yet for the 2019s or 20s
  11. Feb 6, 2020 at 3:53 AM
    coTony
    Tony
    Montrose, CO
    They are not perfect for the 2018 either. Last night I went to update the ratio in the Calibration device and it said there was a later software update so I updated it and did not change the ratio since I did not know what was updated. I had the GPS up this morning on the way to work but I did not see a noticeable difference. It looks slightly closer but then again... I was looking for a difference. I will update tonight like I wanted to and see how it changes tomorrow on the way to work
  12. Mar 10, 2020 at 12:43 AM
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    Why not just use a yellow box?
