Trouble shooting dash warning lights
Discussion in '2nd Gen Tundras (2007-2013)' started by Clark14735, Mar 5, 2020.
  1. Mar 5, 2020 at 4:59 PM
    Clark14735
    Clark14735 [OP] New Member
    2007 tundra crew cab
    Hello I have a 2007 tundra and I been trying to solve a mystery, and hoping one can help I'll be driving down the road dry roads or clear and out of blue traction control tyres to activate then traction lights flashes goes solid and at same time abs light comes on 4 wheel lo and 4 high flash with vsc light did this 5 times now if I shut truck off will go out and stay out until it happens again witch it seems like 2 months apart when this happens and if I turn off it does go out by self so when I do get home and put my machine on of coarse I get no codes any ideas
  2. Mar 5, 2020 at 6:13 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
  3. Mar 5, 2020 at 6:38 PM
    Clark14735
    I have use my scanner and shows no codes do atautation test all abs run like should
  4. Mar 5, 2020 at 7:32 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Not sure what type of scanner you have, but a home use scanner is not going to read the ABS codes. It will only pull the OBD codes and won't necessarily show anything. The ABS WILL store codes even if you've restarted the vehicle and it seems to be normal again. So, I would recommend trying to do what I mentioned or take to a mechanic who has a scanner that can read ABS codes and there will likely be some codes.
  5. Mar 6, 2020 at 12:06 PM
    Clark14735
    Dalandshark thanks for reminding me I'm getting old forgot that I had to open up different section on reader for abs/vsc and slip control found problem its left rear sensor I updated my reader and only used this one few times so still working the operation bugs out I upgraded to the launch x431 mini pro good machine but thanks for the info and boot in the but
    Dalandshark likes this.
  6. Mar 6, 2020 at 6:09 PM
    Spaceiscool
    Spaceiscool Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
    I had this happen to me yesterday. I was driving through a laneway with rather deep snow and then when i had to park (on pure ice) i had this happen. I had to put it into 4x4 to back up, turn it off and restarted. All lights went off aside from abs. At the end of the day hop in, abs is still on put it in drive and it turns off. I wonder if the sensor just got some snow on it.
