Is there a center lock in the Tundras?
Discussion in '2.5 Gen Builds (2014-2021)' started by coTony, Mar 1, 2020.
  1. Mar 1, 2020 at 7:45 AM
    coTony
    coTony [OP] member since sept, 2017 and a BUNCH of messages
    Tony
    Montrose, CO
    I am wondering about a center diff lock capability on a Tundra. I had my LandCruiser that had lockers in front and rear and the center. The center diff lock would lock the front diff and the rear diff. I have not found any mention of this as an option for the Tundra.
    There was many a time that I did not need to lock the front or rear but when I came to something that caused a wheel spin you simply tap the center diff button and it would lock the front to the rear and problem solved.
  2. Mar 1, 2020 at 7:55 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Center diff? Tundra has 4WD transfer case mounted to the transmission. When the knob is turned to 4WD, the transfer case is engaged and power is sent to the front wheels. The rear differential is not a locker...Toyota uses "LSD" which simulates limited slip differential with braking.
  3. Mar 1, 2020 at 8:06 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    coTony[OP] and Black Wolf like this.
