Upgrade 1st gen 60/40 seat with something better?
Discussion in '1st Gen Tundras (2000-2006)' started by Flyboy311, Jun 17, 2018.
  1. Feb 10, 2020 at 4:58 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I am about to do the same for 3rd gen passenger seat. Lexus LX to Tundra swap. Any recommendations or advice is welcomed. Thank you!
    5N0W808 likes this.
  2. Feb 27, 2020 at 6:52 AM
    Ibby
    Ibby New Member
    Michael
    06 Tundra
    How did you make out on the seat swap? How easy/difficult was it with Lexus seats?
    (Thinking of doing the same myself).
  3. Feb 7, 2021 at 5:02 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    @Professional Hand Model, it seems you're describing putting the washers between the seat frame and the threaded hole with the bolt going through the washers, is that correct? I put washers under the seat frame which raises the front of the seat but is hokey and doesn't follow your description. Does my '03 Tundra have the same seat pedestal as yours?
    Thanks for any tips that you have.
  4. Feb 7, 2021 at 5:09 PM
    Fred
    Hand Protectors
    Thank you. You have the right idea. If you like the height you have you may be able to wallow out the hole a little to allow that screw to engage. My brackets look similar to yours iirc (its been a while). I was able to get two 1/8” washers under each seat bracket for a total of 1/4” rise which makes a big difference.
    I didn’t need to drill, but you may. Hows the seat feel now?
  5. Feb 7, 2021 at 5:21 PM
    jimf909
    Washington or Idaho
    It feels pretty good and seems like a nice improvement. I may go to only two washers after I give it a test drive.
  6. Feb 8, 2021 at 3:26 PM
    love2rv
    love2rv New Member
    Garry
    2003 Tundra 4x4 Stepside
    Following
    What year LX seats did you find would work? Any before and after pictures?
    AggiePhil likes this.
  7. Feb 11, 2021 at 3:29 PM
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    My girlfriend agrees with you but for different reasons. :rolleyes::D
  8. Feb 11, 2021 at 5:01 PM
    Cummins3500
    Logan
    If you know, you know :rofl:
  9. Feb 15, 2021 at 2:12 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  10. Jul 18, 2021 at 3:37 PM
    AggiePhil
    College Station, TX
    Did you ever do this?
    onesojourner likes this.
  11. Jul 29, 2021 at 5:18 PM
    Jonny Rotten
    Jonny Rotten New Member
    I would like to upgrade my 02 bucket seats. The armrests are so wimpy I hardly use them.
    Actually a full seat and center console swap with a higher console I could rest my arm on would be real nice
  12. Jul 30, 2021 at 11:41 AM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    I did that to mine because my old seats were crap. Swapped the driver for a power seat and swapped the passenger for the split bench. Swapping to the bench was literally just 1 plug and bolt in, took 10 minutes. Found it out of a 60k mile truck for $120.
    KNABORES likes this.
  13. Jul 30, 2021 at 11:49 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    :worthless:
    Darkness likes this.
  14. Jul 30, 2021 at 8:07 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Its already dark out right now, but I'll try to grab some pics tomorrow.
  15. Jul 31, 2021 at 10:19 PM
    05tundra916
    05tundra916 New Member
    2005 Toyota Tundra Double Cab
  16. Jul 31, 2021 at 10:39 PM
    Green01
    Green01 New Member
    Seb
    2001 green tundra Trd
    PIctures??sssssss really love this idea.
  17. Jul 31, 2021 at 10:40 PM
    Green01
    Green01 New Member
    Seb
    Also anyone know what year Subaru seats "fit"?
    I am planning on cutting off my brackets and welding them on the new seats.
  18. Mar 3, 2022 at 3:01 PM
    ivbyiv
    ivbyiv New Member
    Rust
    Old thread but very curious how this turned out- my splt bench driver seat is sagging bad, thought about mounting an es300 seat or something but keepin the split bench if possible. Any pic of your set up?
  19. Mar 3, 2022 at 6:50 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Wow, I completely forgot about this thread. Heres some pics, cant see too much because these seat covers are a bitch to remove.
    MztVi2ZGjbotAPDtTryr-H9bo3f1IvgTnx_vXbrh_a33ef9bbfa0882af96e8ea61733763e43170f33f.jpgIMG_1740.jpg
    That red circle is the alignment pin for the armrest that I pulled, because this power seat was originally made for two buckets, not a bench. Theres also a ~2.5 inch hole in the leather there. I patched the power seat into the 30a for the windows, haven't had any issues since i did it(little over a year ago). Also these covercraft seat covers rock, found them being sold open box locally for $40 and they're super durable.
    des2mtn and ivbyiv[QUOTED] like this.
  20. Mar 4, 2022 at 5:34 AM
    #50
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    Bet these will come in handy if you ever need to host a three-legged race.
    Sunnier, AggiePhil and shifty` like this.
  21. Mar 5, 2022 at 7:26 PM
    #51
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've been stuck on #26 for a while. I need to finish doing the revamp on my stereo, then bed liner my roof, then bed liner my bed, then put in my rear shock kit. That's all getting done before Summer starts.
    All my other cars are constantly in the way.
    txagg likes this.
  22. Mar 5, 2022 at 7:34 PM
    #52
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its the second time I've done my stereo lol. I installed everything in 2008, that stuff is old enough to drive now.
  23. Mar 5, 2022 at 8:01 PM
    #53
    shifty` One great big festering neon distraction
    And potentially a little acceptance of risk on a scale of 1 to 10. There's a reason floors are reinforced where the bolts pass through, just like there's a reason the bolts are aligned directly over the rail, etc.
    I've heard horror stories over the years of people mating up seats from other cars by bolting to a plate under the floor, just bolting to the floor, bolting using material that doesn't have proper tensile strength, only to have tragedy hit in a collision when the seat rips itself out or the brackets snap and fail.
    Not like I think anyone would do something stupid, but it's worth mentioning the potential risk, if for nothing else than to get people's brains going about how to over-safe-ify things.
  24. Mar 6, 2022 at 7:41 AM
    #54
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @shifty` for sure. I've seen seats held down with drywall screws, its insanity. I had a friend with a mini truck and his seats (buckets from a corolla) were held down by the weight of the person sitting on them.
    Gotta be careful with seats.
  25. Sep 8, 2023 at 4:31 PM
    #55
    Kilgore Trout
    Kilgore Trout New Member
    Oregon
    2002 AC Toyota Tundra SR5 4.7L V8
    Airaid Cold Air Intake, Magnaflow Dual Catback Exhaust, 2017 18” 4Runner Wheels
    Any idea if 2014 Escalade bucket seats are identical to your 2017’s? Did you have to make major fabrications to make them secure? Much thanks. I found a pair of 2014 Escalade leather buckets in great condition and would love to put them in instead of my split bench.
    The Black Mamba likes this.
  26. Sep 8, 2023 at 6:48 PM
    #56
    The Black Mamba
    The Black Mamba Black Sneks Matter
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    After 300,000 miles, I’m due for new seats:popcorn:
    Kilgore Trout[QUOTED] likes this.
  27. Sep 9, 2023 at 3:12 PM
    #57
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    364214811_6782345505123182_7453354239239_8da1fa4ce5ede4c5dd2a60a982e25d304ad651cb.jpg
    abcinv likes this.
