2013 power steering fluid
Discussion in '2nd Gen Tundras (2007-2013)' started by countryhog, Feb 22, 2020.
  1. Feb 22, 2020 at 7:14 PM
    countryhog
    countryhog [OP] New Member
    Jerry
    NW Arkansas
    2013 tundra prerunner
    what power steering fluid can be used? DOT 3, DOT 4, or Dexron II or III?
  2. Feb 22, 2020 at 7:31 PM
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I believe it’s Dex 3. DOT 3 & 4 are brake fluid. Definitely don’t mix the two.
  3. Feb 23, 2020 at 10:34 AM
    countryhog
    Jerry
    NW Arkansas
    Thanks. Duh!
    Will the off the shelf power steering fluid work? Or definiely has to be dex? ive got a bunch from other cars
  4. Feb 23, 2020 at 10:37 AM
    Power steering fluid.
  5. Feb 23, 2020 at 10:42 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Did PS fluid change over with the 2.5 gen?
    It's ATF.
    ColoradoTJ likes this.
  6. Feb 23, 2020 at 10:49 AM
    Dealership told me it’s nothing special.
    Owners manual will solve this problem. Anyone have a screen shot of the oils/capacities for the 2nd gen Tundra?
  7. Feb 23, 2020 at 10:59 AM
    Right from the owners manual.
    That kinda upsets me. Parts counter told me to just get plain old power steering fluid.
    Guess it’s always a good practice to check and verify the specific fluid for your vehicle.
    Zebruaj likes this.
  8. Feb 23, 2020 at 12:36 PM
    countryhog
    Jerry
    NW Arkansas
    Yeah i saw that in the OM but was hoping dex2 was compatible with iff the shelf
    Thanks guys
  9. Feb 24, 2020 at 7:26 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    FYI... On my 4runner I was able to disconnect the return line to the reservoir and crank the wheel to flush out the old fluid (while continuing to keep the reservoir stocked with fresh fluid and front end jacked up). I haven't tried on my Tundra yet, but I assume it will work as well.
