Building custom sliders. Need opinions.
Discussion in '2nd Gen Builds (2007-2013)' started by Mountun Goat, Oct 25, 2019.
  1. Nov 3, 2019 at 8:07 AM
    #61
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Thanks!
  2. Nov 3, 2019 at 8:09 AM
    #62
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, it won’t be for a while. Closer to spring. The basement isn’t going to renovate it self :annoyed:. I promised my wife I would finish the renos before doing anymore truck mods (stupid I know). I did manage to slide these in before winter for ‘safety’ reasons. See what I did there.
    saybng and jewsNbrews[QUOTED] like this.
  3. Nov 3, 2019 at 8:19 AM
    #63
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :thumbsup: hope the basement stuff goes quickly for you! Truck is looking good.
  4. Nov 3, 2019 at 9:27 AM
    #64
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Awesome thanks!
  5. Nov 3, 2019 at 9:28 AM
    #65
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ok truck is looking much better outside of the shop. The sliders aren’t bulky at all! Wooo, success!
  6. Feb 24, 2020 at 3:01 PM
    #66
    kevine0001
    kevine0001 New Member
    Kevin
    Nice job. I'll be making my own too, but using 2x2, similar to Pinay's demello sliders. did you weld yours to the frame?
    Mountun Goat[OP] likes this.
  7. Feb 24, 2020 at 4:18 PM
    #67
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Just seeing this thread. Impressive work on the fab work on the sliders. :cool:
  8. Nov 19, 2020 at 7:24 AM
    #68
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    @Mountun Goat , how has the rear portion of your sliders held up to weight? Do you wish you added another frame bracket behind the cab?
  9. Nov 19, 2020 at 8:03 AM
    #69
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yessir I’m welding the frame.
  10. Nov 19, 2020 at 8:09 AM
    #70
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Man the sliders work awesome. Mind you I haven’t high centered it yet with them. I’ve def used them for laterally sliding against trees and banks in tight corners and they are straight as the day I added them. I use the rear end of the sliders to jump up into the box regularly with the roof rack as the handles for a ‘ladder’. I use the the rear tire for the other step. Comes in real handy when I have a bed fully loaded to the top of the rack for tie downs etc.
    They feel rigid all the way to the rear ends so I feel it’s fine. When I eventually get to the box work I’ll add another rear bracket (when box is off frame) just cause I can :)
  11. Nov 19, 2020 at 8:23 AM
    #71
    BlackSheep
    Scott
    Kansas City, MO
    Sweet! They look great on there, I love the way you contoured them to the profile of the body. I'm intending to do something very similar., very soon. I saw you used 3/32" material, what are the dimensions of the tube you used?
  12. Nov 19, 2020 at 8:26 AM
    #72
    BlackSheep
    Scott
    Kansas City, MO
    It's tricky, cuz looking at the various manufacturers out there, they have all different styles of mounting to the frame. Some are just a few points, others look like they pretty much have a flange that mates to the frame the whole length of the slider. I want mine to be sturdy, obviously, but like a bumper, I want them to give before the frame does.
  13. Nov 19, 2020 at 8:27 AM
    #73
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks man, I love how they tuck up to the body lines also- came out way better than I was expecting. I was skeptical of the design at first, but wouldn’t change a thing now that they color match the rest of the accessories. The dimension is 2x6” tube and I feel the 3/32 is the correct thickness given weight vs strength.
    BlackSheep[QUOTED] likes this.
  14. Nov 19, 2020 at 8:28 AM
    #74
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    That’s right I can see those points of thought, I can’t say if mine are break-away engineered haha. I forgot to mention I can jack the truck up with the sliders so they must be sturdy enough.
  15. Nov 19, 2020 at 8:32 AM
    #75
    BlackSheep
    Scott
    Kansas City, MO
    They are probably sufficient lol. For sure, the gradual load of jacking the truck isn't the same force as they would experience if you were to come down hard on a rock, but if they'll hold the weight of the truck as you say, they would probably fall in that middle ground that you want, where they protect the body, but don't bend the frame.
  16. Nov 19, 2020 at 8:40 AM
    #76
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Full on man, hopefully I get some wheeling soon that proves either way. I need to explore my new region anyway :)
    300BLK likes this.
  17. Nov 26, 2020 at 8:32 AM
    #77
    ionyota
    ionyota New Member
    Looks great. I like that they cover everything.
    My sliders stop a couple inches short of the front wheel well/quarter panel.
  18. Nov 26, 2020 at 5:41 PM
    #78
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, I like them a lot they’re so handy.
