Sound matting worth it?
Discussion in 'Audio & Video' started by Stumpjumper, Mar 12, 2018.
  1. Feb 9, 2020 at 3:37 PM
    #271
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I used something called reflectix that I got at home depot. Idk how welling really works but I feel like I can maintain a better temp in my truck. https://www.reflectixinc.com/products/double-reflective-insulation/
    Do you have ceramic tints? That would help tremendously.
    Tundyfundy likes this.
  2. Feb 9, 2020 at 3:40 PM
    #272
    IBJC
    IBJC New Member
    2020 tundra sr5 crewmax Cavalry Blue
    Pudge[QUOTED] likes this.
  3. Feb 9, 2020 at 3:43 PM
    #273
    Professional Hand Model
    Fred
    Hand Protectors
    The ceramic film (you can get it tinted or un-tinted) as @Pudge says above really works nicely. I could feel the difference right away. Liked it so much I did another vehicle.
    I may do my front windshield in clear ceramic sometime soon. Blocks out UV.
    Rex Kramer, Flyinryank and Pudge like this.
  4. Feb 13, 2020 at 10:00 PM
    #274
    IBJC
    IBJC New Member
    Another thing to add to the list
  5. Feb 23, 2020 at 10:28 AM
    #275
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I ordered a few samples before I make another mlv order, figured it was worth sharing. Here are some shots of the differences. Samples from Acoustimac, soundproofingmlv.com and the isostore.
    I purchased the isostore stuff thinking it was all the same. I could not get anything to bond to it and it is really rubbery and clearly full of voids. The acoustimac sample is very uniform, pliable and tape/velcro bonded well. The soundproofing mlv is a little slicker and a tad stiffer but tape/velcro bonded well. I really like the soundproofingmlv .75lb mlv as it is thinner but i will go with acoustimac since i only need 12.5ft for the doors unless i can get a half order from soundproofingmlv.
  6. Feb 24, 2020 at 2:27 AM
    #276
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    really dint care to pay for a big name brand here. I went with something off Amazon. it got VERY good reviews and was very east to install and stuck well even on a 45* day. I took my time and stayed away from the plastic door clip. holes. 25sf in a box for 33$ shipped is awesome. Its enough for 4 doors. This is decent stuff. Im sure there is better and thicker out there but its your money. My local B&M car audio place was trying to sell me some crap for 120$ and it covered 2 doors.... this stuff from amazon is awesome. When I close the doors now it sounds much different. Its called Kilmat as you can see in the pics . I was able to have enough for the back doors after doing 3 layers in some spots on the front doors. I just ordered another box I was so impressed. Guys im hard to impress. Lol I've been told many times in my life. I have ONE complaint some of the sheets were not cut square out of the box, they were off by 1" on one side. But if your doing a small area like a door who cares. It didn't both me but might bother you. Some of the pictures were not taken when I had all the layers on.
    edit: In sort for the right price Yes I think its worth it if you add it while your changing the speakers out.
    Kenwood Excelon KFC-XP6902C 6X9 with 3 1/2" Dash Mid/tweeter plus the OEM JBL sail tweeters HUGE improvement. Im driving them with a clean AudioControl 6.1200 200 watt per channel 4ohm setup. I used the JBL mount with little issues. Better quality than the universal mounting kit that was included. The only mod I did was add a 1/8" packer washer behind my power window bracket mount below the speaker to clear that magnet. It might not have been an issue with the included adapter. But the JBL/OEM adapter is MUCH better quality and much stronger with a rain shield on back. Im happy with this purchase actually. My system sounds really nice with the gains set right ect..
    ElNopal, Trooper2, nekkyj and 3 others like this.
  7. Mar 19, 2020 at 9:20 AM
    #277
    Corranhorn4406
    Corranhorn4406 New Member
    Brad
    2015 Black Tundra SR5
    Looking at doing just the doors with killmat myself. Was the 25sf enough to do anything for the exterior metal also?
    What is everyone doing with the blue plastic? Tossing it?
  8. Mar 19, 2020 at 9:40 AM
    #278
    AZBoatHauler
    So.Arizona
    I peeled off the plastic and threw it in the trash.
  9. Mar 19, 2020 at 10:53 AM
    #279
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So are we talking the 50 or 80 mil versions?
  10. Mar 19, 2020 at 11:36 AM
    #280
    Corranhorn4406
    Brad
    I've only seen the 50 mil Kilmat in 25sf
  11. Mar 22, 2020 at 12:38 AM
    #281
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    oh crap, i just ordered Noico from Amazon.
    I got the 80 mil sound deadening mat and the RED 150 mil self adhesive CCD (PE foam).
    Hmmmmmmm:annoyed:
  12. Mar 22, 2020 at 1:33 AM
    #282
    Sleeper16plat
    Near Vancouver
  13. Mar 22, 2020 at 3:14 AM
    #283
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    I think it would be better to cut around the cover panel and bolts in case repair is ever needed. Would be nice for a quick swap on the rear window and not a day of peeling that stuff off.
  14. Mar 22, 2020 at 7:00 AM
    #284
    Corranhorn4406
    Brad
    I just ordered the Siless 80 mil but I got the noico finishing tape for the edges also.
    PNWTundra2021 and Tundyfundy like this.
  15. May 11, 2020 at 11:36 PM
    #285
    Tracker
    Tracker New Member
    Shane
    I ordered lots of stuff. Since the Tundra has turned into the toad trip truck since it has tons of room in the CM no offense DC guys. Once I get some time off Im gonna strip the truck down. Lots of Great info from Pudge that Im going to try.
  16. May 12, 2020 at 12:02 AM
    #286
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Go 80 mil. No reason not too if your already ripping apart the interior might as well get the most bang you can.
  17. May 21, 2020 at 7:52 AM
    #287
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
  18. May 21, 2020 at 6:56 PM
    #288
    Tracker
    Tracker New Member
    Shane
    How many tiles does the floor need? Is that gray stuff on the floor toyotas version of CDL tiles?
  19. Nov 4, 2020 at 10:37 AM
    #289
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Will 36sqft of the noico 80mil be enough for all 4 doors?
  20. Nov 4, 2020 at 11:07 AM
    #290
    Tundyfundy
    Bay Area, CA
    For me it was but I have a double cab. I went 100 percent coverage as well as covered the big holes in the door where the plastic was.cant remember if I had any left over. Recommended coverage for Noico is 60 percent from manufacturer.
    BrandonL812[QUOTED] likes this.
  21. Nov 4, 2020 at 2:14 PM
    #291
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I used 56sf or so on my crewmax doors. I covered the exterior and interior door skins 100%
  22. Nov 4, 2020 at 2:17 PM
    #292
    BrandonL812
    Brandon
    Thank you for the info. I think my Sequoia's doors are bout the same size as your crewmax. So that would make sense to use 56sf for full inner and outter coverage. I bet it sounds amazing and less road noise.
  23. Nov 4, 2020 at 2:24 PM
    #293
    Cfincke
    San Antonio
    I also did the back wall and floor up to the pedals, around 120sf in total for doors, wall, and floor. It made the stock speakers sound much better and did cut down on noise. One day I may add MLV to the floor to further cut down on road noise.
  24. Nov 4, 2020 at 3:23 PM
    #294
    Tracker
    Tracker New Member
    Shane
    My floor and doors are done, huge difference. I can drive on the highway and whisper to the rear passengers who hear me perfectly.
    Tundyfundy and BrandonL812 like this.
  25. Mar 14, 2021 at 10:05 AM
    #295
    CappyKD
    CappyKD New Member
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    I'm going to have to do this when I put the audio upgrades in. Was gonna just do killamat 80 but now I need to read more about the layered approach.
  26. Jun 20, 2021 at 10:00 AM
    #296
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    (Bear with me. This is relevant to the thread. I promise.)
    I had tons of condensation on my windshield 3 mornings in a row and the front carpet under the weathertec floor liners were soaked. I thought my heater core was leaking so I pulled everything out to get to it.
    Turns out it was just a clogged
    A/C condensation drain. (Exist at the very front, center of the trans tunnel. Right on top of the transmission. Black, square-shaped plastic flange about the size of you palm.)
    The doors, roof, rear floor and back wall are already done with 1lb/sf mlv, foam isolation layer and 80 mil noico adhesive butyl sound mat.
    I also added a second row of weatherstrip around the doors to fill the panel gaps when the doors are closed. I hoped it would reduce the wind noise coming from the B-pillars, but there's so much noise coming from the front floor and firewall that I can't tell if it did any good.
    Now I can finally finish my sound deadening project that started over a year ago. I've done ~85% of the work to get to an unobstructed firewall. I'm debating whether I should drop the steering column and remove the rest of the dash support for complete access or just work around it.
  27. Jun 20, 2021 at 10:03 AM
    #297
    careyrob
    Carey
    Massachusetts
    BTW, An empty 22' enclosed carhauler right next to the truck makes it so much easier to keep all of the dash parts and seats secure, organized and undamaged.
    81 TOY likes this.
  28. Jun 20, 2021 at 12:42 PM
    #298
    Yzed608
    Yzed608 New Member
    Wisconsin
    I don't want to de-rail this from sound deadening, but do you need to tear that much out to get to the drain? My mother's Highlander had this line clogged and did the same thing. If there's some sort of preventative maintenance I can do to avoid this from happening in my truck I'd be happy. Every time I use the AC I think about this...
  29. Jun 21, 2021 at 10:37 AM
    #299
    careyrob
    Carey
    Massachusetts
    If it's just the drain clogged then don't remove anything. Just blow some compressed air into the drain tube outlet to dislodge the clog and then spray some A/C duct cleaner into the system through the cabin air filter housing.
    I would have saved myself a ton of time if I knew that it was a clogged condensation drain to begin with.
    Yzed608[QUOTED] likes this.
  30. Jun 21, 2021 at 10:39 AM
    #300
    careyrob
    Carey
    Massachusetts
    I decided to just peel the rest of it back to access the firewall, but then realized that you have to disconnect the A/C and heater lines to take any more off so I just worked around what you see in the image above.
