ToyTec BOSS experience?
Discussion in 'Suspension' started by TundraTss, Sep 4, 2017.
  1. Feb 27, 2019 at 11:31 AM
    #91
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    forgot to ask, did you go with 700lb springs?
  2. Feb 27, 2019 at 8:46 PM
    #92
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    tundratss, what did you decide? read this thread 3 times, but maybe i missed it...
    im leaning towards the toytec boss setup for my '19 CM 4x4, based on recommendations from tundras.com peeps
    did not see one mention of need a shim on driver's side to correct the "tundra lean" throughout this thread. although, many have installed 2 on driver and 1 on passenger when using the billy 5100 setup.
    anyone require shims to aquire a level right/left stance?
    also leaning towards a rear shackle lift vs. block. opinions?
  3. Feb 27, 2019 at 8:51 PM
    #93
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I still highly recommend the Toytec Boss kit. For the price it really is the best offering that I have had. Onroad and off-road performance was great.
    Street only and want to stay low cost go with the split Toytec spacer lift.
    Mainly road with some off-road the Boss is great.
    I jumped up to the Radflo, really didn’t need to but it is a nice upgrade. Overkill for what I do, especially now that I got a new truck but I do like the rebuildability.
    whoisbambam likes this.
  4. Feb 27, 2019 at 9:16 PM
    #94
    Lambeau
    Lambeau New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    I asked that same question. Use of spacers or shims will void warranty on the Toytec Boss coilovers. They are adjustable anyway, so you can just adjust to correct any lean.
    BlackSheep and csuviper like this.
  5. Feb 28, 2019 at 4:18 AM
    #95
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Thank you, I've been wondering about this for a while, but I didn't know if different settings and hence different preload on the coils would negatively affect ride.
  6. Feb 28, 2019 at 6:21 AM
    #96
    32vsnake
    32vsnake New Member
    david
    British Columbia
    2008 DC Limited
    Shackles over blocks any day of the week...
  7. Feb 28, 2019 at 6:28 AM
    #97
    Berdine
    Frank
    Binghamton, NY
    The toytec boss kit is adjustable, you won't need shims.
  8. Feb 28, 2019 at 1:39 PM
    #98
    Berdine
    Frank
    Binghamton, NY
    This was posted on IG
    csuviper likes this.
  9. Feb 28, 2019 at 1:42 PM
    #99
    derkks
    derkks New Member
    Oregon
    Oof finally pulled the trigger on the Toytec boss kit a couple weeks ago. Barely missed this.
    Berdine likes this.
  10. Feb 28, 2019 at 1:44 PM
    #100
    Berdine
    Frank
    Binghamton, NY
    I'm going too now!
  11. Feb 28, 2019 at 1:48 PM
    #101
    Berdine
    Frank
    Binghamton, NY
    derkks likes this.
  12. Feb 28, 2019 at 3:01 PM
    #102
    csuviper
    Broomfield, CO
    Its on the 2.5 diameter Boss system. Dont think the Tundra has a Boss 2.5 system.
    They have the Radflo 2.5 but dont think that qualifies as their 2.5 Boss.
    Berdine[QUOTED] likes this.
  13. Feb 28, 2019 at 3:07 PM
    #103
    Berdine
    Frank
    Binghamton, NY
    Ok, must be different vehicles then, thanks!
  14. Mar 6, 2019 at 5:50 AM
    #104
    gdog_Tundra
    gdog_Tundra New Member
    VA
    2016 Limited CrewMax
    3 inch ToyTec coilovers, Dakar Leaf pack, Dirty Deeds 8 inch stainless exhaust, LED DRL headlights
    I pulled the trigger and will also use the Dakar leaf pack. Considering UCA's as we speak.
    G
    Berdine likes this.
  15. Nov 3, 2019 at 4:33 PM
    #105
    whoisbambam
    whoisbambam New Member
    2017 Toyota Tundra CrewMax TRD Off Road (not pro)
    @csuviper
    this one?: and then use the shackles as they are superior for 'ride' comfort?:
    SKLTUN-2247 - Toytec 1-1.5" Adjustable Shackles with new lower bushings
    I am new to this and don't know much of anything vehicle tech wise.....
    thank you all for any assistance.
  16. Nov 3, 2019 at 9:20 PM
    #106
    csuviper
    Broomfield, CO
    Thats the one. Great lift for the price. Add the rear resi for a little better ride. Helped some with the concrete highway crappy ride because of stock leaf springs. The shackles helped a little with this as well. Upgrade to the Aluma series for an even better ride. Elka coilovers are bad ass. Spacers and shackles ride close to the same. Smoother motion with new poly bushings. Better offroad. Reduces/eliminates the axle wrap associated with spacers.
  17. Nov 3, 2019 at 11:11 PM
    #107
    whoisbambam
    @csuviper , thank you very much for the confirmation.
    You all talk at a level that I have difficulty following due to my limited experience.... for instance, you referred to this as the boss 3/1 originally, i believe, and i had to figure out what that meant, lol.
    now you have stated 'rear resi' and I am assuming that is the upgraded kit that has the reservoir on the rear springs.
    well.... i am trying to keep costs down..... as it stands, with the I am at 1420.00 with the shackle option, not including shipping, and then there is the question if i need to get the upper controller arm in order to do proper alignments done on the truck (SPC Adjustable Upper Control Arms - 25490) which then adds about another $700 if that is necessary.... and $1420 is already alot...... and i have to pay to get it installed LOL
    so i have asked others if the upper control arms are necessary..... as i dont want to spend $1,000 or more on tires only to have them wear out in 10,000 miles due to uneven wear because the alignment cannot be done properly.
    I wish money wasnt an option..... but in any case it seems the other kits (rough rider, readylift, etc) seem to not be a good option according to what i have been reading.
  18. Feb 18, 2020 at 5:27 PM
    #108
    Bluebrindle23
    Bluebrindle23 New Member
    People tell me that the tundra needs 2.5" shock body because of its weight. I was thinking the boss kit with icon aal in the rear because I have a leer topper. Great discussion as always everyone.
  19. Feb 20, 2020 at 5:46 PM
    #109
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    2013 Rock Warrior..Just installed the Boss kit today..added rear shackles. They ride way better! I was SHOCKED! Thought with the 700lb spring it may be a little harsh? Nope! Makes potholes disappear. By far exceeded my expectations.A88D7DD4-4159-447C-B1C4-E04B94D11F6F.jpgJust needs 35’s!!!
    Skew12, Rippyro, Bravohook and 5 others like this.
  20. Jun 15, 2025 at 5:10 AM
    #110
    Surfsup
    Surfsup New Member
    Chicagoland
    2024 Tundra
    LOL ain't that the truth.
    Corndog123 likes this.
