Fuse tap or ?
Discussion in 'General Tundra Discussion' started by Mnorris1206, Feb 5, 2019.
  1. Feb 6, 2019 at 7:35 AM
    Itchyjuffowup85
    Itchyjuffowup85 New Member
    2014 Black TRD 4X4 5.7L V8
    Heres where I grounded it.
    Pudge and Mnorris1206[OP] like this.
  2. Feb 6, 2019 at 7:37 AM
    Itchyjuffowup85
    Those will work but youll have to expose the insulation a little bit on the cargo wire first. Those wont cut through it on their own.
  3. Feb 6, 2019 at 7:49 AM
    Mnorris1206
    Mnorris1206 [OP] Super white is fast as f***
    08 tundra
    Hey thanks for your help ! I think this is going to work out great. Still dont know if I will use the turn signal feature. I may hook it up and I can always cut it later if I dont like it .
    Itchyjuffowup85 likes this.
  4. Feb 6, 2019 at 8:43 AM
    Itchyjuffowup85
    No problem. Glad I could help. I have the red LED brakelight strip on the back of the truck. I'm thinking abkut upgrading to one that had the amber turn signals. It does the turn signals, just red. Havent decided yet lol.
    Mnorris1206[OP] likes this.
  5. Feb 6, 2019 at 10:34 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  6. Feb 6, 2019 at 11:31 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    We'll need to see some pictures when you get done.
  7. Feb 6, 2019 at 4:55 PM
    Mnorris1206
    08 tundra
    So I hope to do this tomorrow the day didnt go as planned as always lol. Only got driver side strut and breaks done it was a struggle . but I do like the white spring .
  8. Feb 6, 2019 at 5:03 PM
    15whtrd
    15whtrd Mr. Blonde
    I hate those things. Inside the cab it’s not too bad. But I’ve seen those things become a problem anywhere on the exterior. The service bed on my work truck was wired up with these, and over time the connections just failed and needed to be redone. PosiTap for a interior is the way to go. Less intrusive and almost removable with no evidence.
  9. Feb 6, 2019 at 9:06 PM
    Itchyjuffowup85
    I agree. I used the crappy splice connectors because they were all I had. For further applications I will be using positaps though.
    Mnorris1206[OP] and 15whtrd like this.
  10. Jan 6, 2020 at 9:11 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    I starting looking at the wiring diagram today to figure out how to wire up rock lights to the cargo switch and came to the same conclusion as the forums about the magic brown wire! For any inquiring minds who want to know WHY it works here's the snip of the wiring diagram showing that the little brown wire is from pin 13 on the "DC" junction connector which is on the visible side of the drivers side main body ECU junction box when looking behind the lower dash panel. It can be tapped anywhere between the "DC" connector and the cargo lamp socket. Also for reference, there's no need to go all the way to the grounding bolt in the drivers kick panel, there are ground points under the truck so you only need to route one power wire into the cab, OR you can simply tap the white wire with black stripe in the same wire bundle. Toyota likes to use this color designation for ground.
  11. Jan 6, 2020 at 2:25 PM
    Mnorris1206
    08 tundra
    I have yet to do this mod. Never got around to it but this info sure is helpful.Thanks for sharing!
  12. Feb 10, 2020 at 4:01 AM
    blackoutt
    NWA
    OEM+
    Worked like a charm. $20 rock lights. Wires fished through the rockers with cell phone endoscope and holes drilled in center of body grommets near them for a clean install. Only 4 zip ties!
  13. Feb 18, 2020 at 6:25 PM
    minter66
    minter66 2007 TSS CrewMax
    Man that's nice. Do you have a link to the rock lights? I think I want to switch to those instead of my LED strip - the strip looks cheap to me.
