6112 Ride Quality at Different Settings
Discussion in 'Suspension' started by 737fixer, Feb 16, 2020.
  1. Feb 16, 2020 at 3:49 AM
    737fixer
    737fixer [OP] New Member
    Have been reading the absolutely amazing thread "6112 Setting and Tire/Wheel Combo Thread" and did not want to hijak it with a completely different subject on the 6112. My question is ride quality at different height settings. Over and over it is posted to only go with the 1.9" height as it "maintains" ride quality and the 2.5" hurts it significantly. Several posts even suggest the 1.9" setting and adding either a 1/2" shim or 1" shim to retain the good ride quality. My question is for anyone who has played with both settings and is the 2.5" really a huge difference? Thanks in advance for any comments.
    300BLK likes this.
  2. Feb 16, 2020 at 4:13 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Imo changing from a p rated tire to a load range e is way worse for "ride quality" than the setting from 1.9 to 2.5.
    The 6112 at 2.5 setting is a very nice controlled ride, will it feel like a nicer set of Fox's at low speeds, no because of bilsteins being digressive. So for the mall crawlers the speed bumps can be jarring but get some speed offroad and then you really understand how they perform.
    Bakelite and stuckinohio like this.
  3. Feb 16, 2020 at 4:17 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The spring used with the 6112 is designed to maintain its compression and rebound qualities throughout the height settings. With that being said, you are adding more preload are 2.5 vs 1.9, but it will not be as dramatic a negative effect on the spring as it would be with a stock spring slapped on a 5100 since the stock spring is not designed for added preload. Will you be happy with the ride quality at 2.5? Absolutely. Will you be happy with it at 1.9? Absolutely. The top setting will inherently be a smidge “stiffer” than the 1.9, but like I said, the spring is designed to basically maintain its properties within a certain percentage even at the highest setting. I personally run them at 1.9 and my truck rides like a dream. I even had a co worker with a Cadillac Escalade tell me my truck rides better than his haha.
    If you want 2.5, go for it. It will still ride great. If you go 1.9, keep in mind there is only so much thread on the bolts where they attach to the frame. So the most you can do is 2 shims on the driver side and 1 on the passenger side. 2 on driver to account for tundra lean. After 2 shims, you run out of available thread for the nut.
  4. Feb 16, 2020 at 5:43 AM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    So I went from a 3" spacer lift to 6112s set on the 3rd notch. I could not tell a difference in ride quality. I asked the local shop if they could adjust the springs to allow for a softer ride and they told me it wouldn't really matter. Since I didn't like the height, it lowered my truck, I removed the 6112s. For now I put the stock springs and spacers back on.
    tundramarco and Rica25 like this.
  5. Feb 17, 2020 at 9:06 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    The ride for me on the 6112s on the top setting is much nicer than when I was on 5100s on the top setting. I also have E rated tires that have stiff sidewalls. If I was running 8 ply it would more cushy.
    Rica25 and Bakelite like this.
  6. Feb 17, 2020 at 10:08 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'm running 6112s on the second to the lowest setting with a CB shim on each side.
    I got 2.5 of lift out of it on a 2WD.
    The ride is pretty stiff, I won't deny that..
    But I'm running KO2s, the stock KOs gave me an even stiffer ride...
    Rica25 likes this.
  7. Feb 17, 2020 at 10:09 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Thanks for posting, I've always wondered if I should have went with a 5100.
    I''m glad I didn't..
    Rica25 likes this.
  8. Feb 18, 2020 at 4:59 AM
    codename607
    Chicago
    2024 Tundra
    Question for you all...Can you tell if these are on the top setting or the 3rd?
    84061854_2952187041498616_79705068021837_957d70619576391aa1b58c33efe67610432b6f17.jpg
    Rica25 likes this.
  9. Feb 18, 2020 at 5:02 AM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    Have to agree 1000%. Went trailing this weekend and was able to keep significant speed even on the rougher terrain. Truck handled all the heavy trails like a champ. The ride is way better than stock as well - even at 2.5.
  10. Feb 18, 2020 at 5:43 AM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Looks like the 3rd setting
    Rica25 and codename607[QUOTED] like this.
  11. Feb 18, 2020 at 6:30 AM
    Danman34
    Danman34 New Member
    Danny
    3rd.
  12. Feb 18, 2020 at 7:36 AM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    449AAF9E-7810-40E1-B488-C767B3C7A391.jpg I had 5100s on the top setting on my Tacoma.... rode pretty rough. I have 6112s on the top setting on my Tundra and 5100s in the rear......love the ride! Not mushy or stiff.....just right.
  13. Feb 19, 2020 at 6:57 PM
    r1-superstar
    DB
    UTAH
    Edited. thanks forum peeps. :thumbsup:
  14. Feb 19, 2020 at 7:03 PM
    jordan0317
    Jordan
    Martin, TN
    Theres only 4 settings on the 6112. .75, 1.3, 1.9, 2.5 ish on heights
    r1-superstar[QUOTED] and Rica25 like this.
  15. Feb 19, 2020 at 7:03 PM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    You're on the 4th setting The 6112s only have 4 settings: 0.75, 1.3, 1.9 and 2.5
  16. Feb 19, 2020 at 7:04 PM
    jordan0317
    Jordan
    Martin, TN
    Beat ya......:p
    Rica25 and Pomp_Cat115[QUOTED] like this.
  17. Feb 19, 2020 at 7:07 PM
    Pomp_Cat115
    Los Angeles, CA
  18. Feb 19, 2020 at 8:56 PM
    r1-superstar
    DB
    UTAH
    Ah, makes total sense. Thanks for clarifying. :thumbsup:
  19. May 5, 2025 at 9:28 PM
    HipHapa
    HipHapa New Member
    Monday
    2008 Tundra Crewmax Limited
    6112's & 33's
    I know this is way late, but I came across this thread and wanted to chime in. I have 6112's on set to the 2nd clip (1.3"), 5160 in the rear, on 33" KO2's and my tundra rides rough. I have a 2WD 2008 Crewmax with tow package. I take it offroading often and a few times I've punched through rutted terrain and I wasn't impressed. My buddy has a 2011 DC on stock suspension and E rated tires. His ride is so plush and smooth. Even off-road.
  20. May 5, 2025 at 10:22 PM
    blenton
    blenton New Member
    Look at your leaves in the back - are they sitting on the overload? Worn out leaf springs will sag on to the overload and the truck will ride like garbage no matter what suspension you have on it, especially if they are sitting on the overload when empty.
  21. May 6, 2025 at 2:39 AM
    HipHapa
    HipHapa New Member
    Monday
    6112's & 33's
    Thanks for the help. I removed the overloads long ago and have helper bags in place for when I tow. At the time I installed them, the leaf springs were not touching. I'm considering adding a leaf or CB shackles because I've read they help with comfort, but I'm afraid to invest too much chasing a more comfortable ride. It's a truck after all. When I'm towing it or loaded with dirt bikes and gear, it rides much better. As is, the family hates driving in it. They prefer my '05 Sequoia that's lifted 3" on 34s. The ride is comfortable.
  22. May 6, 2025 at 7:55 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    With the benefit of including springs with the package IME they certainly do better than 5100's which make use of the stock springs but at the end of the day, each incremental step results in more preload and a stiffer ride. For some that are more concerned with form over function or people like me that don't want to spend a boatload on high performance suspension this won't be a problem.
