Wiper blade issues.
Discussion in 'General Tundra Discussion' started by Rockstar72, Feb 17, 2020.
  1. Feb 17, 2020 at 3:07 PM
    Rockstar72
    Rockstar72 [OP] New Hampshire in the house
    Kris
    Manchester, NH
    2020 Army Green Toyota Tundra TRD Pro Crewmax
    I just bought a 2016 Tundra Limited. I'm attempting to put new wipers on. I'm using the same Michelin wipers I've used forever that normally pop right on. However, my Tundra wipers have plastic protective pieces that snap over the wiper arm. The new wipers are to narrow to snap the pieces on. I really don't want to spend 40 or 50 bucks on factory wipers. Any help would be greatly appreciated.
  2. Feb 17, 2020 at 3:11 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Feb 17, 2020 at 3:54 PM
    Rockstar72
    Kris
    Manchester, NH
    I see no message. Lol
  4. Feb 17, 2020 at 3:59 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    GNTundra and TXRailRoadBandit73 like this.
  5. Feb 17, 2020 at 4:00 PM
    TXMiamiFan
    Jose
    He's a freakin' slacker.
  6. Feb 17, 2020 at 4:01 PM
    Toyota Sight Lines are on sale now. At least at my local dealership.
  7. Feb 17, 2020 at 4:02 PM
    With the Mrs at Rooms to Go
    Black Wolf likes this.
  8. Feb 17, 2020 at 4:02 PM
    Pics
  9. Feb 17, 2020 at 4:02 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Regular after market wipers such as the Michelins will work. I remember I had to spend a few moments with it to figure it out; it is different than the typical J-hooks, but it will work.
  10. Feb 17, 2020 at 4:31 PM
    Rockstar72
    Kris
    Manchester, NH
    Here's pics. Not sure if you can tell. There's like a plastic casing around the wiper.
  11. Feb 17, 2020 at 4:52 PM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    I went to Firestone this weekend to have mine replaced. I had to show the dude how to put em on.
  12. Feb 17, 2020 at 5:03 PM
    Nick T
    Nick T New Member
    Picture of the wiper is for J hook arms... you need to swap out the connectors for the U hook that would have come with your blades for it to fit 2007+ Tundra
    Luckydog likes this.
  13. Feb 17, 2020 at 5:41 PM
    I use Rain X blades they just snap in place
  14. Feb 17, 2020 at 6:02 PM
    Rockstar72
    Kris
    Manchester, NH
    The new wipers go on my truck. That's not the issue. The plastic cover won't fit on the new wiper. I've never even seen anything like this before.
  15. Feb 17, 2020 at 7:04 PM
    Nick T
    Nick T New Member
    The plastic covers ( 2nd picture? )
    I have never seen wipers that reuse a factory plastic cover.
    They either come frameless, with frames that are covered with plastic, or with just the frame. (As a complete replacement)
    The oem framed or framed with covers can use the OEM rubber inserts. These days Toyota is pushing the sightlines instead of the inserts, are you sure your Michelin replacements are designed to reuse the plastic covers?
  16. Feb 17, 2020 at 7:05 PM
    GNTundra
    Gino
    2013 White
  17. Feb 20, 2020 at 5:33 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    If Toyota only used normal connectors that just about every car uses .,nope gotta be different
  18. Mar 10, 2020 at 6:42 AM
    Mo_Martz
    Mo_Martz New Member
    Great Country of Texas
    2017 White Tundra CM
    Thanks for the help on this issue. I bought the high end RainX blades and they were terrible and the headpiece doesnt snap in all of the way even with the attachments. On the way home this morning the driver's side finally popped out and was bent up. It never wiped correctly from the get go. The regular Rain X Beam $10 set snapped in and worked like a champ!
    Boerseun likes this.
