Slight hum/vibration in steering wheel when hard left turn.
Discussion in 'General Tundra Discussion' started by MistrRoboto, Jan 2, 2018.
  1. Jan 2, 2018 at 6:36 AM
    MistrRoboto
    MistrRoboto [OP] '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Hey fellas,
    2017 SR5 TRD Crewmax w/ 12000 miles.
    I recently installed 6112s @ 1.9in lift in the front. Install was uneventful, alignment done afterwards. No diff drop.
    I'm getting a very slight, short "HUMMM" sound in the cabin (originates around the wheels), that can be felt as a slight vibration in the steering wheel, as I approach full left turn at very slow speeds. Easiest way to recreate it is pull out of my driveway onto the street. As the wheels pass 70-90% left turn and I accelerate from 0-10 mph, I get the sound for less than a second, then its gone. At higher speeds, I either don't notice it due to other noises, or its not happening. It doesn't happen as I pass back by to straighten the wheel out. Also haven't been able to recreate it in reverse.
    Any guesses?
    Thanks!
    Stormtrooper81 likes this.
  2. Jan 10, 2018 at 3:09 AM
    MistrRoboto
    Virginia Beach, VA
    Anyone? It's almost like second long groan while turning hard left at low speed accelerating
  3. Apr 1, 2019 at 10:52 AM
    Mkpw24
    Mkpw24 New Member
    Michael
    2018 Black TRD Sport
    Any luck on finding what the problem was? I am having same issue. Slight humming sound during slow turns that I just noticed 3 weeks after 6112 install at 1.9 setting.
  4. Apr 1, 2019 at 11:01 AM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    A groaning or growling sounds can sometimes point to a wheel bearing.
    Being its at slow speeds while at a hard left turn could also point to a wheel bearing also, but thats just from my experience.
    Your truck is still pretty new which works against the idea of a bad bearing, though.
    Is the sound constent once you have the wheel fully turned?
  5. Apr 1, 2019 at 11:11 AM
    Mkpw24
    Mkpw24 New Member
    Michael
    Thanks for the response. It makes the sound while turning and goes away once the wheel is straight. Passenger axle did pop out though during install of the shocks and replaced with new axle. Not sure if that could be the cause.
  6. Apr 13, 2019 at 4:03 AM
    MistrRoboto
    Virginia Beach, VA
    Nope never fixed!! I took it to the dealer but of course couldn't reproduce it. Then it groaned all the next day.
    Please PM me if you figure it out, I'm stumped and it still happens daily
  7. Apr 13, 2019 at 4:04 AM
    MistrRoboto
    Virginia Beach, VA
    For me the sound comes in the first 30-60% of the turn. At full lock, it's not present. My truck is also new, so wheel bearing seems odd. It's like a deep groan with a little bit of vibration felt in the cab and steering wheel.
  8. Apr 13, 2019 at 5:42 PM
    Twinky
    Wish i could be more helpful, this one is new to me. Did the dealer check anything or just go for the ride?
    And it wouldn't hurt to check the power steering fluid.
  9. Apr 13, 2019 at 6:09 PM
    agkleino
    agkleino New Member
    Aaron
    Arizona
    2014 Tundra Platinum
    Could it be the power steering making some noise due to the workload?
  10. Apr 15, 2019 at 7:19 AM
    MistrRoboto
    Virginia Beach, VA
    We just went for a ride. Of course, I take 1000 turns and it is dead silent. They topped off the fluid. Anything else fluid related I could do in the driveway?
  11. Apr 15, 2019 at 7:20 AM
    MistrRoboto
    Virginia Beach, VA
    Sure! It seems like it is power steering related, but what would cause increased load? I did install 6112s in the front at 1.9in of lift. Anything in that install that could be over or under tightened now that would impact steering?
  12. Apr 15, 2019 at 10:36 AM
    agkleino
    agkleino New Member
    Aaron
    Arizona
    I was thinking that upgraded suspension usually comes with bigger wheels, tires, or both. Thats where I figured an increased load would come from. Mine makes more of a groan at greater than 85% to lock, but then I'm running 37s with a 7" lift. I expect I'll have to replace something before most people anyway.
  13. Apr 15, 2019 at 10:56 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    I have the same noise and its been there since before the level kit and bigger tires were put on. Took it to dealer before the level/tires and they couldn't replicate. I just live with it now.
  14. Apr 16, 2019 at 12:19 PM
    MistrRoboto
    Virginia Beach, VA
    I'm about there as well. I get headaches trying to recreate it... Then I pull out of my driveway the next day and get a 3 second groan and vibration through the wheel.
    Just came out of my 36k warranty last week.
    nowayout[QUOTED] likes this.
  15. Apr 18, 2019 at 12:22 PM
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I have a 17 CM TRD and I've had this same issue. I'm at 50k miles now and it doesn't seem to be getting any better. My 1st thought was wheel bearing but I dont know everything seems fine from the eye test and jacking it up there isnt any play. I had a Tacoma and at 62k I lost a passenger side wheel bearing but after that never had another wheel bearing problem and I traded it at 192k
  16. Apr 18, 2019 at 1:03 PM
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    Start saving for a new rack and pinion
  17. Apr 19, 2019 at 9:22 PM
    Mkpw24
    Mkpw24 New Member
    Michael
    We solved the problem on mine. It was metal grinding sound during slow turns and disappears once the turn was made and steering wheel straighten out. The problem was the backing plate. We just pushed it in more and totally solved the grinding sound.
    hillbillytoyo likes this.
  18. Apr 24, 2019 at 5:52 AM
    MistrRoboto
    Virginia Beach, VA
    Can you provide additional details or pics? I'd like to explore this on my truck but I'm not sure what your talking about.
    Are you talking about the thin plate behind the brake rotors?
  19. May 18, 2019 at 10:30 AM
    RDunny1794
    RDunny1794 2014 1794 3" up
    R
    GA
    2014 Silver 1794 4x4
    3" Toytec Boss 20x9 Helo HE900 33" Wildpeak AT3W Borla dual exhaust remote tailgate lock ARE bed cap
    Yes, I'm having the same problem here on my 2014 1794 after a 3" Toytec Boss all-around suspension lift. I first noticed it when turning about 30-70% left to park on a hill, moving less than 5mph. It sounds atrocious outside the truck and embarrassing, though it's not real loud.
    Happens every time I turn left the same % at around the same MPH, like entering my driveway. I'm glad to know I share the problem with others, but I want to find the solution. It has to be simple...
  20. May 20, 2019 at 7:49 AM
    MistrRoboto
    Virginia Beach, VA
    You just perfectly described my symptoms! Now... we wait for someone to figure out what it is. I don't personally think its the actual rack and pinion if its this common among us. And for me - it started immediately after the install, with like 12k miles.
    -Jim
  21. Feb 7, 2020 at 8:47 PM
    RDunny1794
    R
    GA
    Jim, just curious here.. any updates for you? Were you ever able to find any relief?
    Early on it was infrequent. I can actually replicate it perfectly now on U-turns or sharp lefts at slow speeds (not full lock, 3-5mph). Power steering fluid level seems fine and no leaks noticed near/around CV boots. Haven't taken it in yet, but likely will soon.
    Has anyone else had this or better yet, actually fixed it?
  22. Feb 10, 2020 at 6:33 AM
    MistrRoboto
    Virginia Beach, VA
    Nope, I never figured it out. And I think its actually a bit worse now since I can hear it in both directions. My only lead is it seems to be present when its cold out. Back in the early spring when still under warranty, I tried to replicate it at the dealership and couldn't. From that day forward, I don't remember having heard it until it got cold again. Right now, Feb in Virginia... I can replicate it every turn.
  23. Feb 10, 2020 at 8:45 AM
    RDunny1794
    R
    GA
    For the most part, that's when mine is more "vocal" too. It still happened through the summer/fall, but mostly during a 90% left turn.
    I did a bit more research and investigating this weekend since the rain and snow on Saturday turned to a beautiful, sunny ~60° on Sunday. I pulled into a lube shop to get my UCA boots greased and asked the guy to double-check my power-steering fluid while everything was "hot" under the hood. He said it was a bit low after all, but not bad, so he topped it off. He didn't have much insight to provide on the sound, but it made me think about any seeping or leaking if the fluid was low. I hadn't noticed anything before as I last posted, but I also hadn't given it a thorough inspection either. So I went home to check it out.
    Turns out, the driver-side tie rod arm accordion boot had some PS fluid on the bottom of it. Nothing serious, but enough to notice it pretty easily. I couldn't tell if it was fresh and I didn't see anything else of concern or indication. I looked it up online more and found the below articles/posts.
    https://www.tundras.com/threads/rack-and-pinion-replacement-on-2014-tundra-crewmax-4x4.26872/
    https://www.tundratalk.net/threads/steering-operation-after-adding-new-steering-stops.255938/
    (These are more for the 1st-2nd gen, but still helpful)
    https://www.tundras.com/threads/power-steering-leak.48461/
    https://www.tundratalk.net/threads/...ck-thread-with-solutions.451194/#post-5660218
    I looked into the "backing plate" (dust shield?) rubbing as Mkpw24 described above, and that doesn't seem like that's the issue at all. I think Wiscdave hit the nail on the head, unfortunately. It seems Tundras are just notorious for rack issues relating to hydraulic over-pressurization on the internal seals. Having a lift and/or bigger tires would only exacerbate that force or "hyper-extend" the rod arms. With a lift on a stock rack and pinion, full-lock is should probably happen sooner than the 100% mark. I'd say more like 80-85% on Tundras, being conservative to not over-pressure the internal rack seals. Maybe adding steering stops could also help preventing full-lock at 100%. IDK.. just a theory...
    I'm going to do a PS flush/fill with some Royal Purple fluid and see if it goes away even slightly or if anymore seeping/leaking occurs.
