  1. Feb 8, 2020 at 4:28 PM
    #601
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Well frick.
    My truck has 3.91 axle ratios.
    My parts truck has 3.92 Axle ratios.
    GG Toyota.
    kodyquist21 likes this.
  2. Feb 8, 2020 at 4:35 PM
    #602
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    anyone know if I can use leather w/o airbag seats in my 06 that has cloth airbag seats and not get an airbag dash light?
  3. Feb 8, 2020 at 4:44 PM
    #603
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Try disconnecting them now and see what happens? should be a quick simple test?
  4. Feb 8, 2020 at 4:46 PM
    #604
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    haha. Never even thought of that. Will do. Thanks. Hope I don't have to go to the dealer to have them reset an airbag light though now...
    NUDRAT[OP] likes this.
  5. Feb 8, 2020 at 6:10 PM
    #605
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    An acquaintance is moving to a condo (old guy) and selling his Ford 8N tractor (sorry, no pics), with a 6' brush hog. I could use it to mow my 10ish acres once a month during the summer, otherwise I have no use for it. Fairly new paint job (well done), 12v conversion, no leaks and fires right up. He wants $2500 for the setup with brush mower. Any idea what these old tractors are worth? online info is all over the place. Is his price in the ballpark?
  6. Feb 8, 2020 at 8:07 PM
    #606
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Thanks, regardless of mfg, a/c package heat pump unit is not the way to go anymore vs a/c unit with heat strip. Wow, times sure have changed. Thnx.
  7. Feb 9, 2020 at 6:00 AM
    #607
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That's probably about right. The bad part about those old 8n tractors is everything is driven off the transmission so if you push the clutch everything stops and the residual speed from the mower will keep moving the tractor.
    Not a deal breaker but something to be aware of.
    Dog[QUOTED] likes this.
  8. Feb 9, 2020 at 6:11 AM
    #608
    Dog
    Dog sit!
    Thanks, didn't know that
  9. Feb 9, 2020 at 9:33 AM
    #609
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well. I might order my carpet today, they don’t make anything for reg cabs, so hoping cutting an access cab carpet will fit. Going black. Debating on what to do with the head liner, I’m really leaning grey. But the rear trim piece is one solid piece from the bottom to the top, so transitioning that to grey will be difficult. Might just paint the bottom black and right after the bottom of the rear window, go grey
  10. Feb 9, 2020 at 10:40 AM
    #610
    Tohopko
    Tohopko New Member
    2004DC
    I've actually thought about blacking out mine, just to increase the "more sidewall" look. Easy enough to squirt with Plastidip and see how it looks before committing further.
  11. Feb 9, 2020 at 11:21 AM
    #611
    empty_lord
    05 rollover special
    Center console woes continue, access cab brackets don’t make it fit. Running out of ideas unless I go custom. I do have to drill out the sheet metal for some of the mount bolts... that’s going to be fun...
    because_wumbo-truck likes this.
  12. Feb 9, 2020 at 11:46 AM
    #612
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    I guess they didn't make any single cabs with buckets?
  13. Feb 9, 2020 at 12:13 PM
    #613
    empty_lord
    05 rollover special
    No. But the bucket mounts are there and the mounts for the basic console. But nothing for the big console. I may have to try a access cab console. Mines from a tundra
  14. Feb 9, 2020 at 3:28 PM
    #614
    Professional Hand Model
    Fred
    Hand Protectors
    This Milwaukee Impact Drill is the best tool investment by far. Makes tire removal/install so easy compared to a lug wrench.
  15. Feb 9, 2020 at 5:24 PM
    #615
    Dog
    Dog sit!
    Deets?
  16. Feb 9, 2020 at 5:27 PM
    #616
    Fred
    Hand Protectors
    Not sure of your question.
  17. Feb 9, 2020 at 5:36 PM
    #617
    empty_lord
    05 rollover special
    Link to the tool will suffice I believe. He just wants details on what tool
  18. Feb 9, 2020 at 5:41 PM
    #618
    Fred
    Hand Protectors
    Ok. Deets!
    bmf4069 and because_wumbo-truck like this.
  19. Feb 9, 2020 at 5:42 PM
    #619
    Dog
    Dog sit!
    Yep. deets = details please. And the Milwaukee, in case there is any misunderstanding of which tool...:eek2:
    (I guess I could have just typed "details" but that's not how the interwebs works...)
    EDIT: beat me to it...thanks!
  20. Feb 9, 2020 at 7:08 PM
    #620
    empty_lord
    05 rollover special
    man, I cant find any used access cab center console front halfs..
  21. Feb 9, 2020 at 7:11 PM
    #621
    empty_lord
    05 rollover special
    hmm.. looks like the double cab console wont work at all. its physically taller.. oh well i paid nothing for the one i do have now. Onto the hunt for an access cab one.
    CodyP likes this.
  22. Feb 9, 2020 at 8:10 PM
    #622
    lsaami
    lsaami Let ‘er buck
    Minnesota
    My parts truck is a front bench, otherwise I’d offer to send you one.
    empty_lord[QUOTED] likes this.
  23. Feb 9, 2020 at 8:23 PM
    #623
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Speaking of parts truck, I’m leaning towards not putting that thing back on the road, so if anyone has a part they need, shoot me a PM and I’m sure we could work something out.
    bmf4069 and NUDRAT[OP] like this.
  24. Feb 9, 2020 at 10:27 PM
    #624
    empty_lord
    05 rollover special
    what color is the interior....
  25. Feb 9, 2020 at 10:28 PM
    #625
    empty_lord
    05 rollover special
    also, didnt that truck have a new frame?
  26. Feb 10, 2020 at 5:21 AM
    #626
    lsaami
    lsaami Let ‘er buck
    Minnesota
    It does not have a new frame, but the frame is in decent shape.
    Interior Color code FB11
    It's like a brown, which is a bummer because mine is grey. :(
  27. Feb 10, 2020 at 5:27 AM
    #627
    empty_lord
    05 rollover special
    I could totally use the steering column trim and the shifter (or at least the button for overdrive mines mia)
  28. Feb 10, 2020 at 6:11 AM
    #628
    Why not just sell it? You just stole the good body panels off it right? If the frame is in good shape I would think someone would buy it.
  29. Feb 10, 2020 at 6:22 AM
    #629
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Because there's more and more that I want to steal off it. Pretty tough to sell it as running/driving when there are no mid pipes, body panels, interior trim, axle left.
    And it's not worth anything as a chassis. May as well just scrap it at that point.
    Edit: and also, it's worth about a grand running and driving. If I salvage all the stuff I want/need, I'm already way ahead of buying it on its own, plus if I share the wealth around here I'll maybe get my money out of it, and people on the forum benefit as well.
  30. Feb 10, 2020 at 6:23 AM
    #630
    Fred
    Hand Protectors
    1) Front passenger side tow hook
    2) All 4 Wheel Hub Covers
    3) The #1 and #2 Brackets for the throttle body cover
