Dash speakers
Discussion in 'Audio & Video' started by Cmo tundra, Feb 9, 2020.
  1. Feb 9, 2020 at 2:21 PM
    Cmo tundra
    Cmo tundra [OP] New Member
    Clay
    Black 2014 tundra 1794
    Hi I'm new to the tundra family and have been seeing everyone on other places talk about the jbl systems suck and r replacing speakers so I'm starting with the dash speakers and I need to know what wires do I splice into since there are 4 wires going into connector
  2. Feb 9, 2020 at 3:17 PM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    I dont think replacing the dash speaker will be the first thing to do. Im pretty sure there powered off the radio not the amp. I would start with the door speakers to contact James at tech 12 volts.com and replace the factory sub. He had some Plug and play systems. I would start with a sub. Im starting by replacing the factory JBL amp with a ADS-DSR1 WITH TO3 HARNESS . TO3 HARNESS and adding a AudioControl D-6.1200 6-Channel Car Amplifier with Digital Signal Processing. For now im just throwing a cheap 8" sub into he factory plastic sub box until I have the funds to replace all the speakers. But the dash speakers are last on my list. so far I have spent 1000$. but im keeping the truck and dont have to hack any wires every thing is pretty much plug and play. good luck.
  3. Feb 9, 2020 at 3:19 PM
    Cmo tundra
    Clay
    Truck all ready has new sub and box the dash speakers came with truck was gonna just put them in
  4. Feb 9, 2020 at 3:26 PM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    Pudge likes this.
  5. Feb 9, 2020 at 3:27 PM
    Cmo tundra
    Clay
    How do I get ahold of James to see
  6. Feb 9, 2020 at 3:28 PM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
  7. Feb 9, 2020 at 3:36 PM
    Cmo tundra
    Clay
    Ok thank u
  8. Feb 9, 2020 at 3:40 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    James at tech12volts is the way to go.
    I used some 3.5 inch infinity reference speakers in the corners and his dual tweeter mount for some JL C1 tweeters in the center.
    If you plan to replace the door speakers with components with tweeters in the sale panel it may not be worth doing the dash depending on what you wanna accomplish.
  9. Feb 9, 2020 at 4:46 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
  10. Feb 9, 2020 at 5:06 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, I don't have JBL but added amp and components. I don't even hear the dash speakers.
    Pudge[QUOTED] likes this.
  11. Feb 9, 2020 at 5:17 PM
    purplenova
    Tom
    Ohio
    Did you add sail panel tweeters with your upgrade?
  12. Feb 9, 2020 at 6:09 PM
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    When I added my dash speakers I cut off the speaker end connector and soldiered them to the new speakers and instant connection.
    purplenova likes this.
  13. Feb 10, 2020 at 3:19 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Yep, Infinity Kappas with tweeters in sail panels
