2015 5.7l cam tower leaks
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hughjanice, Jan 13, 2017.
  1. Jan 13, 2017 at 5:54 PM
    Hughjanice
    Hughjanice [OP] New Member
    Hieu
    2015 Toyota Tundra CM 4x4
    Two single led light bars behind grille, bak revolverx2, fn 18" wheels, bfg ko2. 46gal transfer flow tank.
    Had my truck up in the shop today to do my 30k mile interval service and found my driver side cam tower is leaking. Anyone with a 3rd gen have the same issue?
  2. Jan 13, 2017 at 6:18 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
  3. Jan 13, 2017 at 6:39 PM
    Hughjanice
    Hieu
  4. Jan 13, 2017 at 6:52 PM
    Cat3ILS
    Yeah that's a pisser. Make sure to post your progress as it moves along!
    Hughjanice[OP] likes this.
  5. Jan 13, 2017 at 7:04 PM
    Hey there Hieu any chance u can zoom out on another pic n show or point out where specifically that's coming from greatly appreciated
  6. Jan 13, 2017 at 7:19 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Both sides leaked on my 16. Repaired at 3k miles.
  7. Jan 14, 2017 at 7:49 AM
    Hughjanice
    Hieu
    Most definitely. I'll try to get them tonight
    Cat3ILS likes this.
  8. Jan 14, 2017 at 7:50 AM
    Hughjanice
    Hieu
    I suppose no manufacturer is perfect.. besides the oil leak, I love this damn truck
    BlueFalconActual likes this.
  9. Jan 14, 2017 at 3:22 PM
    Hughjanice
    Hieu
    With the brake lines in the way it was very difficult to get a photo of the leak but if you look on the rear driver side head you can see oil seepage from the cam tower
  10. Jan 14, 2017 at 4:03 PM
    Thanks
  11. Jan 14, 2017 at 5:34 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    It's the freaking automobile manufacturers being cheap and instead of using a gasket they elect to use freaking RTV or some kind of Anaerobic sealer.
    Cat3ILS, Hughjanice[OP] and 040Tundra like this.
  12. Jan 14, 2017 at 6:49 PM
    Hughjanice
    Hieu
    Oil burning smell is only evident after driving 20+minutes
  13. Jan 17, 2017 at 6:55 PM
    Hughjanice
    Hieu
    Dropped the truck off this morning. As expected they cleaned up the area and put in a dye. They've asked me to return in 500miles. Looking to get truck back in next week..500 miles is a weekly norm -.-
    NewImprovedRon and T-Rex266 like this.
  14. Jan 17, 2017 at 10:52 PM
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    It's been done for years man. Hell my 95 Tacoma still has the original rtv seal on the oil pan when I bought it new no leaks still.
    Alot has to do with the type of metals you are trying to seal. Also temperature and humidity play the biggest factors when the sealant is curing.
    Side note to this. If the parts in question are failing like I have seen here and few other places I lean toward something is either not machined right and/or using sealant to fill a void. Or piss poor engineering/manufacturing processes in place.
    Hughjanice[OP] and ColoradoTJ like this.
