2001 transmission issue
Discussion in '1st Gen Tundras (2000-2006)' started by Bubbadog, Jan 29, 2020.
  1. Feb 1, 2020 at 4:57 PM
    #61
    Professional Hand Model
    Fred
    Hand Protectors
    Do not do a new Taco! Trust me. Two friends bought and got rid of them within a year. Both in newer Turd Gens. Nice but too big. Better than Taco though.
    speedtre, bmf4069 and FrenchToasty like this.
  2. Feb 3, 2020 at 9:45 AM
    #62
    Bubbadog
    Bubbadog [OP] New Member
    Shop called today and said it has a bad crankshaft position sensor. Getting a new Toyota sensor installed and hope to be back in business.
    Filthyphil likes this.
  3. Feb 3, 2020 at 10:37 AM
    #63
    This'll be the first I've heard of a CKS going bad on these trucks. Do you have a leaky water pump?
  4. Feb 3, 2020 at 12:08 PM
    #64
    Bubbadog
    No. The water pump is fine. I replaced it along with the timing belt about 2 years ago.
  5. Feb 3, 2020 at 1:02 PM
    #65
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    So you are telling me all the forum diags were wrong? Unheard of!
  6. Feb 3, 2020 at 1:50 PM
    #66
    Aerindel
    Aerindel New Member
    Montana
    Yep. I think a lot of people here will agree with you. The first gen is the right size tundra. Everything else got too bloated.
  7. Feb 3, 2020 at 1:51 PM
    #67
    Aerindel
    Aerindel New Member
    Montana
    Eh, we where partially right. We all said it wasn't a tranny issue. Some of us said specifically that it was a sensor of some kind.
    SouthPaw[QUOTED] likes this.
  8. Feb 3, 2020 at 2:00 PM
    #68
    SouthPaw
    2000 Limited 4x4 AC
    I guessed alternator, shame me!
  9. Feb 3, 2020 at 2:29 PM
    #69
    Bubbadog
    Not quite. I don't have it back yet. I am telling you t
    It's a goldilocks size. Not too big or too small. The 2020 Double Cab Tacomas are very close in height, length, and width as my Access Cab 2001 Tundra. The cabin feels much more spacious in my Tundra. I kept hitting my head getting in and out of the driver's seat of the new Tacoma. I'm only about 6 ft tall.
    speedtre likes this.
  10. Feb 3, 2020 at 3:37 PM
    #70
    Fred
    Hand Protectors
    Nice! Hope thats the cure.
  11. Feb 3, 2020 at 4:00 PM
    #71
    Bubbadog
    Thanks
  12. Feb 4, 2020 at 2:21 AM
    #72
    tvpierce
    tvpierce Formerly New Member
    Maine
    Seems plausible.
    As @bmf4069 said, it's not a common failure with Toyotas (at least in my experience). But I've seen that issue in other brands, and the symptoms were similar to yours. Hope that fixes it. Keep us posted.
    bmf4069 likes this.
  13. Feb 4, 2020 at 5:08 AM
    #73
    Yup, common problem in my SHOs. But they only fail because the WP fails and weeps coolant onto them. Itll just up and die and give a crank/no start situation at first. Then it just refused to start if not addressed. It's a bitch to get to an requires a full tear down of the front of the motor.
    Now if it's in the same position and you gotta remove the timing belt and crank pulley, and your due for that service, might as well do it.
