6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Feb 2, 2020 at 7:57 AM
    #841
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I’m running 1.9” with no shim. Both fenders measure exactly 39.25”. No Lean.
    To add shims your will have to completely remove and reinstall the coilover
  2. Feb 2, 2020 at 8:42 AM
    #842
    Marshwalker
    Marshwalker New Member
    Z
    Correct and not yet!!
    tango[QUOTED] likes this.
  3. Feb 2, 2020 at 9:51 AM
    #843
    Marshwalker
    Z
    This tango that worked for Tac?
  4. Feb 2, 2020 at 5:06 PM
    #844
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    Eddyline is the one! I was there mid summer back in 2015. I’d love to do way more of Colorado than I did. And I did a lot.
  5. Feb 2, 2020 at 5:59 PM
    #845
    Marshwalker
    Z
    Haha it’s Zach Runners
  6. Feb 2, 2020 at 9:53 PM
    #846
    ostm282
    ostm282 New Member
    Stock 2018 Tundra Limited Silver
    2" leveling kit installed up front
    Great looking truck! Are you running stock upper control arms and if so, how did the alignment turn out with the 6112's set up high at 2.5"? If you're running aftermarket UCA's, what brand? Thanks
    cmack[QUOTED] likes this.
  7. Feb 3, 2020 at 5:22 AM
    #847
    cmack
    cmack New Member
    AZ
    2018 Burrito
    Running stock uppers. Alignment was fine. Slightly rubbed the cab mount prior to get an alignment but it clears it now.
  8. Feb 3, 2020 at 12:18 PM
    #848
    WellWater
    WellWater New Member
    2020 Tundra CM
    Great thread. Appreciate all the sharing and knowledge.
    Do any of these 6112 configurations still allow for garaging (assume stock wheels and 275/65/18)?
  9. Feb 3, 2020 at 12:23 PM
    #849
    AZBoatHauler
    So.Arizona
    I'm set at 1.9" with one shim on driver's side and 275/70 18 tires and have about 1.5" of clearance to spare for the garage door at my house and can get through the vast majority public parking garages.
    WellWater[QUOTED] likes this.
  10. Feb 3, 2020 at 12:51 PM
    #850
    WellWater
    2020 Tundra CM
    Thanks for the reply. Is that from your roof or shark fin?
  11. Feb 3, 2020 at 12:52 PM
    #851
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Watch your shark fin antenna, there was a thread not long ago about a guy who bought a 20 and couldn't get in the garage because of it.
  12. Feb 3, 2020 at 12:59 PM
    #852
    wwinslett
    wwinslett New Member
    Will
    Birmingham AL
    2016 Tundra CM Magnetic Grey
    6112's Toytec Shackles Method NV on Ridge Grapplers 295/70/18
    Fresh bath this weekend. I park mine in my garage and my antenna drags but I'm clearing the roof of the truck no problem
    I'm at 2.5" with 1" in the rear.
  13. Feb 3, 2020 at 1:26 PM
    #853
    AZBoatHauler
    So.Arizona
    Mine is 2017 so I am pre-sharkfin.
  14. Feb 3, 2020 at 2:43 PM
    #854
    ostm282
    ostm282 New Member
    Same question for you @wwinslett. Great looking truck! Are you running stock upper control arms and if so, how did the alignment turn out with the 6112's set up high at 2.5"? If you're running aftermarket UCA's, what brand? Thanks
  15. Feb 3, 2020 at 4:45 PM
    #855
    wwinslett
    Will
    Birmingham AL
    thanks! I’m running stock UCAs. Below is my alignment specs. Everything looks to be green but I’m about 14k miles into my setup and I’m seeing very slight wear on the outside of my tire compared to the inside. :( I rotate every 5k with oil change to try and even them out. :confused:
    Because I don’t see myself getting rid of the truck I think I’ll eventually get the SPC UCAs. I’ve seen a lot of positive feedback and they’re maintenance free.
  16. Feb 3, 2020 at 5:59 PM
    #856
    ostm282
    ostm282 New Member
    Thank you so much for the alignment chart! You and several others that I've asked who are running stock UCA's with the top setting on the 6112's are saying that good alignment can be achieved without going to aftermarket UCA's. I just ordered some 6112's at the 2.5" setting but started getting concerned about alignment and the potential for spending another $600 on new UCA's. Thanks again for your feedback.
  17. Feb 7, 2020 at 6:58 AM
    #857
    recomr
    recomr New Member
    Sent you a PM about these
    Marshwalker[QUOTED] likes this.
  18. Feb 13, 2020 at 9:00 AM
    #858
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    Was this in LBK? I live up in the panhandle but travel there frequently to see inlaws. Im looking for someone to do mine but cant get alot of positive feedback up here.
    fuzzamungus likes this.
  19. Feb 13, 2020 at 10:00 AM
    #859
    WestexSBK
    Yes sir. I had ricks tire install the front Coilovers and align the truck for $250 out the door! Highly recommend.
  20. Feb 13, 2020 at 10:04 AM
    #860
    WestexSBK
    I’m getting consistent rebound in the front on streets and highways with my 6112 Coilovers. It’s like driving on a fine washboard road. Not sure what’s going on. I have had all tires rebalanced and I did not resolve the issue. Any ideas?
  21. Feb 14, 2020 at 9:03 AM
    #861
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    Any lean?
  22. Feb 14, 2020 at 6:30 PM
    #862
    jml403
    jml403 New Member
    Georgia
    2017 SR5 4x4 Crewmax
    1.3” setting, 275/70-18 tires. Just put coachbuilder +1 on the rear. 1x shim on the drivers side.
    It sat level at 1.3” with no shackles. I do tow so bringing the rear up a bit was a must. I had to redo the drivers side to add the shim. I couldn’t believe it, but had almost .75” lower on ds measurements, now I’m about .2” lower. Very pleased with how it sits now.
  23. Feb 14, 2020 at 6:51 PM
    #863
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    That's a nice setup. Less is more and it works. What tires do you have?
  24. Feb 14, 2020 at 7:07 PM
    #864
    jml403
    jml403 New Member
    Georgia
    Thank you, I absolutely agree. I’m boring and run BFG AT’s. I must have owned 7-8 sets on 5 different vehicles by now, and they’ve never let me down.
    Iowa12tundra[QUOTED] likes this.
  25. Feb 14, 2020 at 8:23 PM
    #865
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
  26. Feb 15, 2020 at 10:33 AM
    #866
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    6112 top setting, toytec shim on driver side. 5160 in the rear with icon/deaver leaf expansion pack and toytec aal. 37x13.50r18 Cooper Stt pro on moto metal MO961 18x9 +18 offset
  27. Feb 15, 2020 at 10:55 AM
    #867
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    really really nice set-up there!
    jordan0317[QUOTED] likes this.
  28. Feb 15, 2020 at 8:33 PM
    #868
    ostm282
    ostm282 New Member
    BOSS 4X4S SWAYBAR RELOCATION KIT 2007-2020 TOYOTA TUNDRA
    Has anyone used or have thoughts on this swaybar shim kit to go with lifting the front end? Seams like a reasonable thing to do when lifting 2.5"-3" using 6112's. Boss Offroad has it for $40 and helps with getting the swaybar back into proper alignment. Thoughts???
  29. Feb 15, 2020 at 11:39 PM
    #869
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Interesting. Can’t find it on their site. Can you post the direct link?
  30. Feb 16, 2020 at 8:17 AM
    #870
    ostm282
    ostm282 New Member
