Factory paint problems? Really?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kbayashi, Sep 24, 2019.
  1. Sep 26, 2019 at 5:38 AM
    mastergunnera8
    mastergunnera8 New Member
    Northern Virginia
    As a recent buyer of a white truck this is not making me feel very good!!!!
    Have a 2011 Sienna, white, and the paint is super thin and the clear coat stinks...
    WrigglingWilly likes this.
  2. Sep 26, 2019 at 6:04 AM
    When I was researching the paint on my 1st gen I found out Toyota used a single stage paint job. Someone commented saying the white ones made today are still a single stage paint job. I cannot confirm this.
    Edit- not that this should make the paint peel but it does make me wonder.
  3. Sep 26, 2019 at 6:48 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Looks like an issue with adhesion of the anti-chip layer. That is a process in painting unto itself. It's the 1st stage of top coat application with paint and clear then applied over it.
    15whtrd likes this.
  4. Sep 26, 2019 at 8:05 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    No, in the letter, Toyota states the issue is the underlying primer not adhering to the electroplated body metal. So the whole compound finish (primer, base coat, clear coat, and chip guard) is pulling away from the body metal in places on white vehicles.
    My arm chair guess is that they use a different primer on white vehicles (a paler formulation) than they do on dark vehicles, where the primer can have a darker pigment. I don’t necessarily think the issue would be the color of the primer, but more to do with the formulation of the primer.
    From the pictures, it looks like there is the desired adhesion of paint to primer, but not the desired adhesion of the primer to the body metal.
    15whtrd likes this.
  5. Sep 26, 2019 at 8:16 AM
    panicman
    Eric
    If you talk to professionals there is a long standing debate over the superiority of SS paint versus BC/CC.
    There are 60+ year old cars with their original SS paint still shiny and intact. In formulating single stage paint, the glossifiers are added to the base color by the jobber/painter and then the mix is shot onto the primered vehicle in as many coats as desired (or paid for!).
    My point is that SS paint is not necessarily “bad” or “cheap”.
    Black Wolf likes this.
  6. Sep 26, 2019 at 8:20 AM
    I agree. Didn't mean to imply it was bad. I'm just saying that because it was asked "why only white" and I remembered that previous post. Based on some other posts it doesn't seem like Toyota is still doing SS on these like I though.
  7. Sep 26, 2019 at 9:34 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That seems to be ALL Toyota’s and Honda’s. If you look at my truck the wrong way it scratches. My wife’s Acura has 100k miles on it and the paint looks like it went through a war zone. To be fair we have kids so it kind of has...
    GODZILLA and jewsNbrews like this.
  8. Sep 26, 2019 at 5:56 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    I'm in the paint shop on Monday and ask will around and report back. I may get a Polish salute as to what is going on as sometimes there is a screw up in the chemistry at the higher spectrum of the supply chain and the specialists in charge not know exactly what is going on and are not much aware because they are building new trucks today. I'm sure if there paint adhesion issues that are related to every unit that had that paint configuration, they are trying to minimize the damage by going back through the quality system info. The guys I work with try to make sure the paint job is perfect. It looked good to them when it rolled off the line. Always remember the big paint companies like PPG and others screw up batches. The folks at TMMTX who run that place are pretty top notch automotive professionals.
    pickeledpigsfeet and jewsNbrews like this.
  9. Sep 26, 2019 at 6:08 PM
    Mnorris1206
    08 tundra
    Something I have noticed in the pics the O.P posted is that it doesn't look like the bottom of my door panels / rockers my 08 has a like texture to it not smooth to the touch wonder if they have used something under the paint that makes It look smooth. I was told mine is like a rock guard material to prevent chips and things from rusting the rockers . Are there and rough like textures on rockers of the 3rd gens ? Or is this the new way of trying to "protect" the paint job?
  10. Sep 26, 2019 at 6:10 PM
    Mnorris1206
    08 tundra
    This hole area is what I'm talking about.
  11. Sep 26, 2019 at 6:19 PM
    Forkhunter
    Forkhunter New Member
    2018 DC Limited
    Man...2018 here with no letter yet either. No issues yet though.
  12. Sep 26, 2019 at 6:19 PM
    15whtrd
    15whtrd Mr. Blonde
    Mine is textured all along that area. But at certain angles and it’s hard to tell.
    Mnorris1206[QUOTED] likes this.
  13. Sep 26, 2019 at 6:22 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Yes the 1st phase of top coat painting after moist sand coming out of primer into the spray booth is anti chip. Then top coat base followed by clear and bake. After that they are inspected. Some go off-line for an hour or so to get a touch up. The next process in auto paint is finesse. That's where all the little defects are corrected with a small buffer and some polishing compound. When paint is fresh and the lighting is good, anybody can be taught to touch up a paint job. If there is a dent in the sheet metal, the body is scrapped.
    You want a really great paint job buy a Mercedes. I just want my truck
  14. Sep 26, 2019 at 6:50 PM
    panicman
    Eric
    7.62tundra- thank you for your insight! Having an insider with knowledge is really helpful.
    plumber802 likes this.
  15. Oct 7, 2019 at 8:29 AM
    mastergunnera8
    Northern Virginia
    Any updates on this? Whomever received a letter, what was your production date? I’ve got a 19... no letter... any way you could send me one?
  16. Oct 7, 2019 at 8:34 AM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    I have a feeling my letter was for my 2017 White Camry. The paint on the front bumper is pretty banged up. Granted, I do a lot of freeway driving each year for my job so it’s quite possible it’s jist normal wear and tear for my usage. My 2016 Tundra on the other hand still had almost factory new paint. I haven’t had the time to dig into this further.
  17. Oct 9, 2019 at 10:08 AM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Update. Anti-chip issue probably. I forgot but anti-chip issue more than likely and not all over. Anti-chip is installed before the primer. I got it mixed up as it the 1st step as it enters the primer booth.
  18. Jan 29, 2020 at 7:02 PM
    one4x4dad
    one4x4dad New Member
    James
    Houston TX
    2019 Tundra Crew Pro
    following
  19. Jan 29, 2020 at 7:13 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I have a 19 pro in white with 6500 miles and when detailing it I have notice a couple of what I would call like spider webs or stretch marks it’s weird never seen that on paint b4 it’s minor you have to really look at it close to see them
  20. Jan 30, 2020 at 2:23 AM
    #50
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I hope my tuck isn't affected by this. Here in Vermont the roads are a carpet of rock salt and brine from November until March. I can just imagine the problems that will occur if this toxic cocktail gets between the paint and bare metal. Ugh...
    jewsNbrews likes this.
  21. Jan 30, 2020 at 7:12 AM
    #51
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Nissan had a similar issue and it effected the entire vehicle.
  22. Jan 30, 2020 at 8:22 AM
    #52
    panicman
    Eric
    Howdy 7.62,
    So the chip guard gets applied to bare metal, then prime, then paint, then clear?
  23. Jan 30, 2020 at 8:29 AM
    #53
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Not bare metal. It is applied on top of the ecoat/phosphate that the bodies are dipped in. Then the primer is applied to the entire body which is on top of the anti-chip and sealer as well. Cured in oven which sets primer, anti chip and sealer. Sealer is still tacky until it's cured in the primer oven.
    Next base coat (tint is the technical word) with a hot air step to flash any VOCs then clear coat and back into another oven to cure.
    panicman[QUOTED] likes this.
  24. Jan 30, 2020 at 6:26 PM
    #54
    panicman
    Eric
    I forgot about the anti corrosion treatment.
    Thanks! Interesting to hear the process.
  25. Jan 30, 2020 at 6:54 PM
    #55
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    What's fun is watching the dejig process as all the carriers come back around. Dejig is taking it off of a carrier and moving to the next process. All the hardware that holds the jigs to keep the doors and hoods open and taken off. It's coated with paint. Blasted and used again
  26. Jan 31, 2020 at 6:17 AM
    #56
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Could be bad PDR....... dime sized spider web cracks? Hail in your area?
  27. Jan 31, 2020 at 8:53 AM
    #57
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    No dents anywhere and I don’t drive it in bad weather stays in the garage never been hailed on didn’t hail in chicago since I bought it in Jan of 19 and I only got cought in 1 snow fall rare late March of 19 other than that always been in the garage nice and clean
