275/70r17?
Discussion in '1st Gen Tundras (2000-2006)' started by jImmegart, Dec 12, 2019.
  1. Dec 12, 2019 at 1:09 AM
    jImmegart
    jImmegart [OP] Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    Anyone run 275/70r17 and have pictures? There isn't a lot of options available but I have been looking at the firestone destination a/t c-rating. Just seeing if anyone has any experience with the size.
  2. Dec 12, 2019 at 4:39 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
  3. Dec 12, 2019 at 5:01 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Great size in my opinion. I wish there were more tire options to bring the price down. I sold a set of BFGs on an 05 Sequoia with some black rhino wheels and a 2” lift. It was the perfect mix between big tire and not over doing it.
    Not too wide. Not too tall. Not too heavy. Perfect for a Toyota.
  4. Dec 12, 2019 at 8:18 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Are you absolutely set on that size. If so, are the tires a great deal? Or is it for potential fitment issues?
  5. Dec 12, 2019 at 10:56 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    My buddy just put some BFG's on his truck in that size with 5100's and I think they are on the 4th notch. Great size for no rubbing but like @Scuba said expensive cause there arent a lot of options out there.
  6. Dec 12, 2019 at 11:32 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
  7. Dec 12, 2019 at 11:34 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Billys can only be set so high on the AC models.
    Double check Billys website. Believe 5100’s can go no higher than second notch on AC. DC can go all the way up. Just make sure you check specs first as OP has a Access Cab.
    I realize this is a tire size thread for AC.
  8. Dec 12, 2019 at 12:31 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I was actually gonna say it’s a horrible size, because of the price and lack of options. I just don’t see much gain or benefit by going 275 over the 285/70/17:notsure:
  9. Dec 12, 2019 at 12:43 PM
    jImmegart
    Jonah
    California
    Id need more lift to run 285, but I am a little over level in the front and I have 265/70/17 atm which look a tad small. I need to measure but I think I could run 275 without a problem. Price wise It is cheaper for me to get 275s then new suspension and 285s.
  10. Dec 12, 2019 at 1:44 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Fair enough, how much are the Firestone’s your looking at?
  11. Dec 12, 2019 at 5:15 PM
    jImmegart
    Jonah
    California
  12. Dec 12, 2019 at 5:59 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Those Firestone’s are probably fine tires. I will urge you to at least consider/look into the p285/70/17’s. Most of them are about 45lbs. each and they run small. I’ve run the hankook dynapro AT and they are a great all around tire. If you choose the 275/70/17 size, check out this link for the new design.
    https://www.amazon.com/dp/B07M75V5J3/ref=cm_sw_r_em_tai_X2U8Db5H9SXHP
  13. Dec 14, 2019 at 2:16 AM
    jImmegart
    Jonah
    California
    After thinking about it, I kinda want to lift a little more and get p/285/70/17. I just need to figure out how much lift I need.
  14. Dec 14, 2019 at 3:06 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    If your answer is that you need 2" lift spacers you should send me a message.
  15. Dec 14, 2019 at 5:06 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Awesome, there’s actually a pretty decent selection of 4 ply (P rated) options in that size. Here are a few I found that I wouldn’t hesitate to run on my vehicles. I personally run the p285 70 17 nitto g2 on my 2006. Unfortunately some brands like Hankook don’t offer a 4 ply in that size:cool:
    https://www.ebay.com/ulk/itm/362300396624
    https://www.ebay.com/ulk/itm/372728654194
    https://www.ebay.com/ulk/itm/333320598347
    https://www.ebay.com/ulk/itm/292767352291
  16. Dec 15, 2019 at 2:36 AM
    jImmegart
    Jonah
    California
    I was reading your trucks bio on your page. What suspension setup do you run on your 2006 and also how do you like the banks exhaust?
    I have been looking at mbrp exhaust, jba and bamufflers but I cant deside. My uncles 2001 for some reasons sounds like it should but mine on my truck is very quiet (they are both stock), and I want more v8 sound. Also, for the headlights on your 2002, did the 2005 ones just fit or did you need some modification?
  17. Dec 18, 2019 at 2:47 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    275/70/17's KO2's
  18. Dec 19, 2019 at 6:10 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I've had these 275/70R17 KO2s on the truck since I picked it up almost 2 years ago. It's really a perfect size for a lifted DC...should have been the factory size with 4.30 gears. I do wish there were more options, though...especially in C-rated. These E-range KO2s are way overkill for what I do and they don't balance well...and they're almost 15 pounds heavier per tire than the stock size. Whenever I replace them I'll likely either go with a differnt 32" size (for more choices) in P- or C-load or drop down to 265/70R17 (again, for more choices).
    IMG_20180927_173307.jpg IMG_20180601_223455_618.jpg IMG_20190722_131556.jpg IMG_20190921_144107.jpg
  19. Dec 19, 2019 at 6:15 AM
    How much lift do you have? I only raised the front 2" and had no issues fitting 285/70/17's. I didn't even trim the usual places. I touch the frame at full lock, but only in reverse.
  20. Jan 17, 2020 at 9:51 AM
    Chicken Run45
    Chicken Run45 New Member
    Marshville NC
    04 silver streak dcsr5
    None YET
    I run 275/70/17s General ATs on my 04 DC very little rubbing only when I turn left,on stock suspension
  21. Jan 27, 2020 at 7:17 PM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Bilstein 5100’s in front, but on lowest setting. No rubbing that I can see but I just installed them yesterday.
  22. Jan 28, 2020 at 9:06 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Check your clearance between the UCA with those wheels.
    Darkness likes this.
  23. Jan 28, 2020 at 10:36 AM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    285/16s are where its at. Moar tire
  24. Jan 28, 2020 at 3:43 PM
    Musashi66
    I had a chance to drive her, and I think some spacers are in order. Any consensus on what is good, hubcentric, and not thick?
  25. Jan 28, 2020 at 4:25 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Go with Spidertrax 1.25"
  26. Jan 29, 2020 at 3:04 PM
    Musashi66
    On order! Should be here Friday.
    seth419[QUOTED] and bmf4069 like this.
  27. Jan 30, 2020 at 4:20 PM
    Musashi66
    Spidertrax installed. No rub, but I had to take the front mudflaps off.
    Not optimal - tires stick out (2000 Tundra, without the fender flares), and no mud flaps. I wonder how much nasty stuff will be flung around.
  28. Jan 31, 2020 at 5:59 AM
    Fred
    Hand Protectors
    Lots. You’ll be a slave to washings after every rainfall/snow event. Sideview mirror will get abused, as well.
    revtune likes this.
  29. Jan 31, 2020 at 8:13 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Solution = get fender flares:D
    bmf4069 likes this.
  30. Jan 31, 2020 at 8:15 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I like both of those stock Toyota wheel choices.
    SC T100[QUOTED] likes this.
