2019 Tundra Pro Transmission Failure 19000 miles
Discussion in '2.5 Gen Tundras (2014-2021)' started by one4x4dad, Jan 24, 2020.
  1. Jan 24, 2020 at 2:59 PM
    one4x4dad
    one4x4dad [OP] New Member
    James
    Houston TX
    2019 Tundra Crew Pro
    First off let me say, I dont rag or race my truck, rarely pull a duck boat (maybe 150 miles total) and over maintain my truck. Only mods are a diamond back cover, ESP under seat storage and a radar detector into the mirror installed. I was driving down the tollway yesterday around 75-80 mph and the power dropped and it felt like the engine was dying. Dropped about 15 mph then started shifting hard, as if I had a shift kit installed. I pulled off the toll road to a parking lot, turned it off, no fluid leaking, no bad smell nada. Started it up no noise. Backing up and driving slow it sounded as if I had gravel in my transmission. As I sped up the noise went away. Drove like a snail home, intermediately powering up and down most of the drive. Unloaded my truck of personal items and drove it to the shop. Videoed the sound a few times. Pulled up to the dealer and the assistant service mgr came out, asked me what was going on. I said lets go for a quick ride, literally 10' he said stop, as we could hear the marbles/gravel in the transmission making the noise. They took the truck in. Called me today and they are replacing my transmission. They said the diagnostic computer said it failed. I asked if it was getting a new torque converter and if they were flushing the cooler and all of the lines, he said he thought they were. Said they techs have a book of work they have to follow when replacing it. I asked if they or I could take pictures of the truck when it was torn apart as I keep EVERYTHING on my vehicles and over maintain them(I have done 4 services at the dealer so far). He said they dont take pictures or allow clients in the shop. I asked if they took the tranny apart, they said no. That this is not typical and they actually have to order the part. I asked about the warranty on the new part, he stated that it would follow the factory warranty(remainder of my 5/60k). He said that if I was paying for the part and work it would have a lifetime warranty. I added that my shaky fog lights(third time to bring it up and third shrug off) and the muffled blue tooth microphone. He said since the truck is parked they will have to handle the transmission first then look at the other items.
    Concerns:
    1 Are they going to install a reman part or a new tranny?
    2 What if they dont flush everything out perfectly and something buggers it up again?
    3 What if it fails again at 70k miles. I bought this truck to drive it for a while not expecting this failure so soon. (he told me that Toyota stands behind their products, to which I answered Ok put it in writing.)
    4 Why will they not give the same lifetime warranty on this replaced part?
    5 Is this a common issue?
    6 Has anyone else had this happen or had any luck with getting the warranty extended?
    The service guy seemed nice and has been responsive, but....
    Thank you in advance
  2. Jan 24, 2020 at 3:11 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Not common, they will fix it, no need for pics, yes, there is always risk on any warranty repair, my guess is they will replace with new and they probably dont “open” up transmissions at all. Codes tell them what is wrong and they follow a flow chart.
    Overall, not to worry, sometimes things fail...which sucks but they are stepping up so you are good.
  3. Jan 24, 2020 at 3:14 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I would ask Toyota for an extended warranty on the transmission. Not the dealer.
    MTRock, JohnLakeman, Durania and 5 others like this.
  4. Jan 24, 2020 at 4:01 PM
    timsp8
    NY
    Most likely will be a remanufactured transmission. And they’ll send yours off somewhere to be rebuilt and used for someone else. Toyota won’t open them up and fix them and you probably wouldn’t want the local dealer to do that anyway.
    You don’t have a cooler to be flushed. I don’t think you need a new torque converter just cause trans went bad. It’ll be under you powertrain warranty unless you have an extended warranty. If it went out at around 59k like mine did on my 2010, the warranty would be 1 yr 10k miles. I don’t know why Toyota would ever give a lifetime warranty on a transmission.
    I also have shaky fog lights. Haven’t asked Toyota about it though as a new bumper is on my to do list.
    one4x4dad[OP] likes this.
  5. Jan 24, 2020 at 4:07 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Tell them you want a trans cooler installed.:thumbsup:
  6. Jan 24, 2020 at 4:44 PM
    one4x4dad
    James
    Houston TX
    Will/can they install a trans cooler? My last 3 trucks were all Ford Superdutys, 2011 F250, 2103 F250, 2017 F350. All 3 never had a powertrain issue. All 3 I drove to almost 100k miles. The transmission issue is really disturbing as this is also the first truck I did not get the extended warranty(rethinking that now). I was thinking since the transmission kept lagging and stressing during the drive it may of been damaged or at least prematurely worn. I do not have great mechanical skills or knowledge so thanks for the insight.
  7. Jan 24, 2020 at 5:02 PM
    specter208
    specter208 New Member
    2017 Tacoma and 2005 Tundra RGCAB
    I wonder if the trans got hot at somepoint.
  8. Jan 24, 2020 at 5:13 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Not too bad in the late 90s, early 2000s.
  9. Jan 24, 2020 at 5:23 PM
    Azblue
    The Dirty T ( ^_^)_且
    The transmission in the Tundra has been around for quite a while and is considered to be a very durable one, I would call your failure rare but shit happens. If you are concerned about extending the warranty you can buy the Toyota Platinum warranty up until the standard 3/36,000 new vehicle warranty expires.
  10. Jan 24, 2020 at 5:24 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    1. Probably a Toyota reman, not to be confused with a generic reman.
    2. If there's a silver lining here, it's that your truck doesn't have an ATF cooler, so there's no place for failure debris to hide.
    3. If you bought the truck new, and the miles are low, press dealer/corporate for an extended warranty, well beyond 5/60K.
    4. Forget lifetime warranties, nothing lasts forever, and they're not crazy.
    5. Not yet.
    6. I have read histories of owners getting extended warranties on transmissions.
    Q1. How many miles on the truck?
    Q2. What's a "duck boat"?...(a) A flat-bottomed duck hunting boat, or (b) A WW2 amphibious landing vehicle?
  11. Jan 24, 2020 at 5:42 PM
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    If a transmission fails and there is metal carnage, the torque converter will be replaced as well because there is no way to remove the debris inside. And trust me if it came apart from what you described then its inside the converter.
    rodm1 likes this.
  12. Jan 24, 2020 at 5:55 PM
    one4x4dad
    James
    Houston TX
    I did buy it new, they gave me a sweet deal and were pissed when I didn't finance it, even tried to add some to it when that came out at the last min. Mileage is right over 19,000. Duck boat is a 20'x6' aluminum boat built by Mike Kleibert, with a 70+hp gatortail on the back, not the old tourist traps(literally).
    JohnLakeman[QUOTED] likes this.
  13. Jan 24, 2020 at 5:58 PM
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Did you ever get transmission overheat dash light?
  14. Jan 24, 2020 at 6:05 PM
    timsp8
    NY
    There is a thread on here where someone with a 19 added a trans cooler. Doubt Toyota would do it and warranty it since they say you don’t need it.
  15. Jan 24, 2020 at 7:13 PM
    one4x4dad
    James
    Houston TX
    No, not one light. I did get a funny smell about a week ago. And had some resistance or misshifts around that time as well.
  16. Jan 24, 2020 at 7:16 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    That sucks, hope mine holds up. Have you ever shifted from drive to reverse to rock your truck free of mud/snow? That will kill a tranny quickly.
  17. Jan 24, 2020 at 7:17 PM
    one4x4dad
    James
    Houston TX
    We have never been in snow
    pickeledpigsfeet likes this.
  18. Jan 24, 2020 at 7:21 PM
    one4x4dad
    James
    Houston TX
    in this truck. I had 2 100 series cruisers that spent allot of time in Colorado. And as far as mud, have not been stuck before. Just riding ranch roads. We use Polaris Rangers for mud.
  19. Jan 25, 2020 at 5:31 AM
    timsp8
    NY
    I tried to do that a few weeks ago in snow and it didn’t work. At least not like it did in my old Nissan hardbody. I think it’s electronically controlled to not let you rock it. I even tried turning all traction control stuff off and there was no difference.
  20. Jan 25, 2020 at 6:15 AM
    JohnLakeman
    Just checking...the DUKWs weigh 13,600 pounds dry without a trailer. :D.
    Toyota will take care of you for 5 years/60K miles. For planning beyond that, I don't know what I would do. I tuned out the extended warranty overture when buying because it was a Toyota. In most cases, I believe deferring the extended warranty will still be a good decision when buying a Toyota, but that's just me.
    Two ways to look at your transmission failure now: (1) It was anomaly from the factory that won't be repeated in the lifetime of the truck, or (2) the AB60 transmission is a Tundra weak link with foreshortened service life. There is little evidence of weakness prior to 2019. You have about three plus years to consider your decision before committing to an extended warranty or another truck. In any case, I would monitor my ATF temperatures to determine where they're running, even in light duty. Texas in the summer could be a tough environment without an ATF cooler.
    Those that have inquired about dealers adding an ATF cooler to 2019-2020 Tundras have been refused, probably because of warranty considerations.
  21. Jan 25, 2020 at 6:23 AM
    Adam New Member
    Check out the extended warranty threads on here. You can get them at pretty much cost through a couple of Toyota dealers. You have until 3yrs/36k miles...whichever comes first to throw down on one.
  22. Jan 25, 2020 at 10:04 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Not 100% sure if true but the service guy at the dealer told me that if something is a warranty repair that Toyota has barred them from using any reman parts for at least a few years now. If customer-paid then they would offer it. Any truth to what he was saying?
    rodm1 likes this.
  23. Jan 25, 2020 at 10:34 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
  24. Jan 25, 2020 at 10:44 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  25. Jan 25, 2020 at 10:51 AM
    JohnLakeman
    If true, that would be good news and good policy for Toyota imo. Maybe @Roman can help us regarding warranty repairs using reman or new parts. The only transmissions listed on any Toyota online parts sites, which by definition would be for outside shops and individuals, is Toyota re-manufactured transmissions.
    2WD: https://parts.toyotaofcoolsprings.c...0dW5kcmEmeT0yMDE5JnQ9c3I1JmU9NS03bC12OC1nYXM=
    4WD: https://parts.toyotaofcoolsprings.c...0dW5kcmEmeT0yMDE5JnQ9c3I1JmU9NS03bC12OC1nYXM=
  26. Jan 25, 2020 at 12:08 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2025 GMC Sierra 2500HD AT4 2017 CM Limited (Sold) 2019 CM SR5 l
    I would guess if you’re under the 3/36 you’ll be getting a brand new crate transmission, not reman. If it were covered under an extended warranty, there might be language that allows them to use remanufactured parts. As for the failure, consider yourself unlucky. I haven’t heard of or seen many failures with these transmissions.
    Trooper2 and sask3m like this.
  27. Jan 25, 2020 at 12:18 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Cant speak for Toyota but on the 2011 ram I had the torque convertor went out less than a month after getting the truck, Dodge replaced it with a reman with a 12 month/12,000 mile warranty, shortly after I traded for my first Tundra.
    rodm1 and jewsNbrews like this.
  28. Jan 25, 2020 at 12:41 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Take it from someone who works at a Toyota dealership. You trans will be replaced with a transmission from Toyota and will include the torque converter. The oil to coolant heat exchange will be flush out. They will not add an external cooler. The transmission failure rate on Tundras is very low, your just one of the unlucky ones.
  29. Jan 26, 2020 at 1:16 PM
    one4x4dad
    James
    Houston TX
    Boat weighs 2500 lbs. Double axle alum trailer and surface drive.
  30. Jan 26, 2020 at 2:12 PM
    Danimal86
    Daniel
    Sacramento, CA
    Dang. That's nothing.....sorry to hear about the bad trans. Haven't heard of any trans failures.
