  1. Jan 23, 2020 at 8:48 PM
    #211
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    Am I crazy trying to justify going for the budget reman CV axles from cvjreman? They’re $119 and come with neoprene boots. According to the several dealer parts shops I talked to the OEM remans are backordered indefinitely, and I’m not sure a reboot is in my wheelhouse. My boots aren’t failed but have some minor cracking and look like they could be on the way out
    because_wumbo-truck likes this.
  2. Jan 23, 2020 at 9:00 PM
    #212
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Just keep in mind those black lines are springs, they & the foam flex with the drivers weight. You'd have to be sure to leave room for seat movement. 'twood sux to feel a hard shape in the seat back.
  3. Jan 23, 2020 at 9:56 PM
    #213
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If you put anything there you’ll feel it. That flexes in when your sitting
  4. Jan 23, 2020 at 11:06 PM
    #214
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    That's not bad. I paid $200 for a pair of Napa CVs ... Let's see if they last.
  5. Jan 23, 2020 at 11:25 PM
    #215
    empty_lord
    05 rollover special
    New or reman? The new ones use a tripod unlike the duel cv on the oem ones
  6. Jan 24, 2020 at 12:31 AM
    #216
    empty_lord
    05 rollover special
  7. Jan 24, 2020 at 12:47 AM
    #217
    empty_lord
    05 rollover special
    well the diamond back might not happen if i can get a good price on this Leer cap that popped up on a rotted out truck..
    where the hell was this thing when i was rebuilding mine? same color and all. could of just thrown a bed, door and fender on from it and not painted a thing!
    hopefully they still have it..
  8. Jan 24, 2020 at 3:13 AM
    #218
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I understand that. I was thinking if there was a compartment in there is would have an air gap with foam between it and the seat back. Still it looks like enough room to have a lock box for a pistol or whatever.
  9. Jan 24, 2020 at 3:37 AM
    #219
    because_wumbo-truck
    Jon
    Houston, Texas
    New. I'll get some remains with the cores once I swap em out
  10. Jan 24, 2020 at 5:59 AM
    #220
    Professional Hand Model
    Fred
    Hand Protectors
    There is plenty of room. You could fab up a slim profile box or platform across the lower portion of the seat frame and it would work nicely. Those seat springs don’t flex that much (maybe 1/2” max). I actually considered doing something in that area after inspection when doing my seat cushion/lumbar mods. Mucho room.
    KarmaKannon[QUOTED] likes this.
  11. Jan 24, 2020 at 6:01 AM
    #221
    Fred
    Hand Protectors
    That lumbar mod is the bomb btw. The seat cushion mod (firming up the outer seat rim) is pretty sweet, as well. So cheap and easy with huge improvement.
    KarmaKannon likes this.
  12. Jan 24, 2020 at 7:08 AM
    #222
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I found your pool noodle mod when I searched but nothing about the lumbar. What is this you speak of?
    I don't know specifically what it needs, but I know these seats need something. I find myself pushing my left foot on the footrest to keep myself back in the seat waaaay too often. I scooted my seat up a notch last week but now I feel entirely too close.
  13. Jan 24, 2020 at 7:24 AM
    #223
    speedtre
    speedtre New Member
    Inland Northwest
    Get one of these...best part is it will go anywhere, so great for multiple cars and air travel...and it rolls up to nothing. Worst part is it will go anywhere, so it's easy to lose. :) It really is awesome for lumbar support though, because you can put it right where you need it.
    https://www.amazon.com/gp/product/B00HANX2VO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Sunnier likes this.
  14. Jan 24, 2020 at 7:24 AM
    #224
    Fred
    Hand Protectors
    Its actually natural fiber insulation from a food delivery company. A pool noodle would work. Stuff the backside of the lumbar region with anything (between seat cushion and internal back frame). This bulks up/out the lumbar portion on your back.
    Also, you can tilt your front portion of your seat tracks up by loosening and slipping some washers underneath the frame. Retighten. Gives the seat pan more tilt vs. flat feeling.
    Sunnier and KarmaKannon like this.
  15. Jan 24, 2020 at 7:47 AM
    #225
    Fred
    Hand Protectors
    Anyone here use these ‘speed bleeders’ for one man brake bleed operations? Sounds pretty cool. I can pick up some from local parts store fitted to Tundra ( 2 sets of 2 for around $32). Front calipers and rear drums are differing sizes.
    TX-TRD1stGEN and bmf4069 like this.
  16. Jan 24, 2020 at 7:52 AM
    #226
    empty_lord
    05 rollover special
    I’ve used them. They work like a charm, I just don’t buy them anymore because I have a vacuum bleeder
  17. Jan 24, 2020 at 7:57 AM
    #227
    because_wumbo-truck
    Jon
    Houston, Texas
    If you can find electric seats they have lumbar adjustment
  18. Jan 24, 2020 at 8:09 AM
    #228
    Fred
    Hand Protectors
    I’m going to grab some today. Just bought a honer for doing my rear cylinders service.
  19. Jan 24, 2020 at 9:56 AM
    #229
    Fred
    Hand Protectors
    Confirmed at Toy Corp. this is the grease to use per spec.
    Compatible with glycol Dot 3/4/5.1 fluids.
    FrenchToasty and bmf4069 like this.
  20. Jan 24, 2020 at 9:58 AM
    #230
    Whothefat
    Clark
    Las Vegas
    Not a bad deal, but the 119 is for neoprene boots, with OEM boots they’re 200 a piece
  21. Jan 24, 2020 at 10:25 AM
    #231
    It's interesting how we all have some similar and some different complaints about the seats. The lumbar is fine for me. The only issue I have is that my left leg likes to roll off the seat towards the door. Almost like the foam there has gotten weak with age.
  22. Jan 24, 2020 at 10:56 AM
    #232
    KarmaKannon
    Utah
    Some junk
    Just add more foam when you do your leather.
    speedtre likes this.
  23. Jan 24, 2020 at 12:03 PM
    #233
    empty_lord
    05 rollover special
    $220 bucks and I own a leer 8ft fiberglass cap now
  24. Jan 24, 2020 at 12:47 PM
    #234
    Fred
    Hand Protectors
    I just researched the axles my 4 wheel place installed almost 2 years ago. Good warranty on them. Seem quality. Just type in this pictured part number for further research. Check out that grease layer on everything. :yes:
    Sunnier likes this.
  25. Jan 24, 2020 at 12:53 PM
    #235
    That's a good deal for a hard to find item. Even harder to find an 8' one.
    empty_lord[QUOTED] likes this.
  26. Jan 24, 2020 at 1:12 PM
    #236
    Fred
    Hand Protectors
    Found out today, when buying brake fluid, that STP bought out Prestone Licensings to sell. Same product, but packaged by STP.
  27. Jan 24, 2020 at 1:45 PM
    #237
    Sunnier
    Sunny
    San Diego, CA
    :spy:
  28. Jan 24, 2020 at 1:45 PM
    #238
    speedtre
    speedtre New Member
    Inland Northwest
    Wow, you stole that...good job!
  29. Jan 24, 2020 at 3:32 PM
    #239
    Really interested in these but not clear how they work.
    Sunnier likes this.
  30. Jan 24, 2020 at 3:38 PM
    #240
    I guess I never understood untill I saw that cutaway, it looks like a flare type situation, the end of that bleeder seals against the machined bevel, the same way a flare nut does. Then when you loosen the bleeder it backs pressure off of the flare, letting fluid go into the passage at the top front and then out the nipple thru that check thingy. That’s a guess though
