White smoke while starting up
Discussion in '2nd Gen Tundras (2007-2013)' started by Lineman4x4, Jan 20, 2020.
  1. Jan 20, 2020 at 8:32 AM
    Lineman4x4
    Lineman4x4 [OP] New Member
    2009 5.7 4wd
    2nd time this happen to me in 6 months, started truck and some white smoke came out of tailpipe.
    It also happen back in the summer while starting up.
    Truck runs great, synthetic oil every 5,000 miles. Very well maintained since day 1.
    2009 5.7, 92,000 miles.
  2. Jan 20, 2020 at 8:36 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So this isn't the rather normal moisture built up overnight in exhaust vaporizing off in first few miles of driving/warmup? This happens all the time in humid areas like central texas.
    Only 2 others things cause White smoke, headgasket leak or excess fuel being dumped in. If no missing coolant I doubt either of these 2 is happening.
  3. Jan 20, 2020 at 8:43 AM
    Lineman4x4
    2009 5.7 4wd
    Only happened 2 times. It's a noticeable white puff, and goes away within 1 second of starting
  4. Jan 20, 2020 at 9:06 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    May just be th ed right combination of temperature and humidity. Probably what the Raptor owner I saw this morning hopes. He hit the throttle lightly at 65 mph and 2 distinct puffs of blue smoke came out.
  5. Jan 20, 2020 at 9:48 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Probably just some dipshit vaping by your truck. Seems they cant go 30 seconds without doing it everywhere.
    duece292 and Lineman4x4[OP] like this.
  6. Jan 20, 2020 at 10:23 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    If it's only happened twice in 6 months it's almost definitely water vapor in your exhaust system. Nothing to worry about. I've had it happen a couple of times as well. It happens during high humidity or after a short trip where the exhaust gases don't get hot enough to burn off the moisture.
