Confused about drain and fill vs flush
Discussion in '1st Gen Tundras (2000-2006)' started by BGS41, Nov 20, 2019.
  1. Dec 15, 2019 at 6:22 AM
    Makes total sense. If you really want to take care of her, do another drain and fill in 5K miles. Keep working out the old fluid and getting new in. ATF is so cheap that it's easy to justify.
  2. Dec 15, 2019 at 7:58 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Dexron is cheap. WS ATF is not. You lucky bastads :p
  3. Dec 15, 2019 at 11:23 AM
    Professional Hand Model
    Fred
    Hand Protectors
    We are loving it BTW. $14 dollas a gallon at wally wurrllll!!!
  4. Jan 18, 2020 at 4:07 PM
    Sbct
    Sbct New Member
    Dave
    2002 Tundra 4.7L. 4x4.
    None
  5. Jan 18, 2020 at 4:14 PM
    Sbct
    Sbct New Member
    Dave
    None
    If I do a drain and fill several times what are the chances that something bad will happen? I just bought a 2002 Tundra with 179,000 miles. I have no clue what kind of fluid in in the tranny. I was going to use Amsoil since I really like using it. I had a friend say not to worry but I read on here that doing that is horrible if you are not using the same fluid.
  6. Jan 18, 2020 at 4:32 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Use the Toyota spec fluid...not real pricey and it's made to use that.
  7. Jan 19, 2020 at 5:04 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    My 2000 takes Dex III, I think your 2002 does too. If the Amsoil meets Dex III specs (I'd be very surprised if it didn't) then use it if you want. There are other options that are much more affordable and some may be just as good. But by all accounts Amsoil makes a very good quality product.
  8. Jan 19, 2020 at 5:18 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Has anyone had a Transmission cooler blow......the one inside the radiator? I did, and I'm still amazed. Pink fluid everywhere, looked like strawberry Quick. Thought my transmission would be toast. I ran about 3 cases of cheap ATF through it until it , well looked like ATF. Changed the filter as well. Took it out for a nice hot run and all was good. Reinstalled another filter, and then drained and flushed the cheap ATF out and replaced with Aisin fluid. Toyota's original fluid I got cheaper than my dealer. 30k miles later now over 355k on my 2000.........moral of the story.............You can flush your transmission. Those old fables are for Domestic transmissions. Besides you are just running extra fluid through. If it looks good, just drain fill. Most times that's good enough for these. Also, I dont use the Trans cooler in the radiator anymore, screw that, I bought a bigger and better one, and run it with the other external cooler.
  9. Jan 19, 2020 at 5:25 AM
    tvpierce
    Maine
    I had a pink milkshake with my last vehicle -- 2002 4Runner. Essentially the same transmission and same radiator/cooler fittings. I caught it right away, and it took 9 gallons of ATF to flush it out properly.
    Yours is the first Gen-1 Tundra I've heard of to experience the pink milkshake.
  10. Jan 19, 2020 at 5:58 AM
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    So you had one of those V8 4Runners? (I have an issue with Toyota not putting a V8 as an option for the Tacoma, yet they fit one in the 4Runner and RX400 from Lexus)
  11. Jan 19, 2020 at 8:15 AM
    Fred
    Hand Protectors
    Wally Wurlldd $14. Cheap and meets/exceeds spec. Do multiple drain and fills until your last drain looks like this pouring out.
  12. Jan 19, 2020 at 1:39 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    The 2002 4Runner was a 3rd gen with a 3.4L V6. 2003 is when they introduced the new body style and added the 4.7L in that lineup.
  13. Jan 19, 2020 at 3:42 PM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Recently bought an 02 w 228k miles. Thinking of doing this soon. How often are owners having tranny failures, and what is mileage usually for this to happen? Mine seems to be solid, just more food for thought..
  14. Jan 19, 2020 at 3:49 PM
    Fred
    Hand Protectors
    My tranny is holding just fine at 167k. She has done some tow/haul over the years, as well. No signs of problems. I’ve had the fluids changed by others fairly regularly over the years. Just started doing my own maintenance again which is so easy.
    Not sure about others mileage failures. Haven’t heard much since readings from mid-2000’s ‘planetary explosions’. I think those were from not enough fluid after service because the manual spec’d the fluid fill wrongly at 2.1 quarts when in reality its around 5 quarts. Just a theory.
    MrAristo[QUOTED] likes this.
  15. Jan 19, 2020 at 3:53 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Thanks for this! So a drain and fill would require 5, not 2.1 quarts?
  16. Jan 19, 2020 at 4:12 PM
    Fred
    Hand Protectors
    Correct. Thats what most here report.
    @empty_lord works at a Toy Stealership as a mechanic and he says thats the approx. amount.
    Check your dipstick with engine running and warm. It should be right at the top line once you get it right. Thats your final indicator.
  17. Jan 19, 2020 at 4:14 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Approx. many variables. Which is why it’s best to measure. If the truck sits longer you’ll get a little bit more than if it’s sat for a short stint
  18. Jan 19, 2020 at 4:17 PM
    Fred
    Hand Protectors
    I also noticed if the engine has been running in hot summer conditions that the fluid will read higher. This is due to expansion of the fluid which is normal.
    MrAristo likes this.
  19. Jan 19, 2020 at 4:19 PM
    empty_lord
    05 rollover special
    Yes. That is normal. After sitting for hours it’ll change the level too because of the valve body draining out a bit
  20. Jan 20, 2020 at 4:53 AM
    #50
    bmf4069 Captain wtf
    You'll definitely know you don't have enough in. I had to keep adding since it wouldn't even go into gear to drive off the ramps.
  21. Jan 20, 2020 at 6:36 AM
    #51
    zombie
    paul
    Rhode Island
    2007 Black DC 4x4
    Check level before you start if just doing the drain and fill. If level is correct, what comes out, goes back in. Use the old gallon jug of ATF as one measuring device.
