Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Jan 14, 2020 at 10:18 AM
    #1831
    War Machine
    War Machine SSEM # 5 3MW
    I haven’t had any issues, and I don’t take any precautions to keep it off of the plastic.
  2. Jan 14, 2020 at 10:40 AM
    #1832
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    How about brake calipers? The site I ordered from said avoid that. Anything to it?
  3. Jan 14, 2020 at 1:22 PM
    #1833
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    Thx Sean & Jason.
    I figured it wouldn’t be an issue otherwise there would have been plenty said earlier. Just making sure.
    War Machine and Pudge like this.
  4. Jan 15, 2020 at 4:46 AM
    #1834
    War Machine
    I’ve seen the same warning, but I know a lot of people use it to clean their wheels. I don’t know how that can be avoided if people are doing that. I’ve used it a few times on wheels, and have seen no I’ll effects. A lot of dedicated wheel cleaners have the same chemicals in them. As a matter of fact, a lot of people use wheel cleaner in place of iron x to decontaminate their paint.
    I don’t want to go so far as to say that the warning should be ignored, but I personally haven’t seen it cause any harm, nor have I heard of anyone else who has. The only problem I’ve ever had with Iron X is from me not rinsing it off quickly enough when it was hot outside. It left some streaks, that wouldn’t wipe off. Since I was claying anyway, it took them right off.
    jpod[QUOTED] likes this.
  5. Jan 15, 2020 at 4:48 AM
    #1835
    War Machine
    No problem. Like I said in the previous post, if it dries on there it will will take a clay bar to get off. Other than that I’ve experienced no issues with the product at all. That’s not to say it’s not possible, I just haven’t had a problem.
    Honestly there’s really no way to keep it from getting on the plastic. Even if you taped it off it would soak through.
    jpod likes this.
  6. Jan 16, 2020 at 3:35 PM
    #1836
    ryanryan34
    ryanryan34 "Its almost done"
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    Need some help getting my wheels clean, this is the worst of the 4. I don't know what caused it ( I do not use tire shine on my tires and the wheels are smooth to the touch, can't feel any build up). I have attempted to get them clean with Chemical Guys wheel cleaner and saw no change. Really appreciate any help.
  7. Jan 16, 2020 at 3:44 PM
    #1837
    throughitalldude
    throughitalldude New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    I had this happen to my wheels. Saw it after someone sprayed them down with degreaser and it etched the finish could never get it off.
    truefunk likes this.
  8. Jan 16, 2020 at 4:00 PM
    #1838
    ryanryan34
    Olympia WA
    Thanks for the info, can't recall them ever getting sprayed with degreaser. Hope there is some way to get them clean again.
  9. Jan 16, 2020 at 4:42 PM
    #1839
    War Machine
    How long have they been like that? Looks like a chemical dried on them.
    Pudge likes this.
  10. Jan 16, 2020 at 4:50 PM
    #1840
    ryanryan34
    Olympia WA
    Best guess is around a week or so now, this past weekend was when I tried to clean them with Chemical guy wheel cleaner. Any suggestions on how it get it off ?
  11. Jan 16, 2020 at 5:01 PM
    #1841
    War Machine
    CG wheel cleaner isn’t very strong, but it should’ve done something. Did you use a spray wax or sealant that may have gotten on them?
  12. Jan 16, 2020 at 5:49 PM
    #1842
    ryanryan34
    Olympia WA
    Not to my knowledge, I did take the truck on a long road trip and saw a load of snow and rain, my first thought was salt from the roads or maybe even paint
  13. Jan 17, 2020 at 2:31 AM
    #1843
    Adam New Member
    try a mild stripping soap like dawn to see if it cuts it off. If it doesn't, I would think a clay bar may be your next step.
    Brownsfanhere likes this.
  14. Jan 17, 2020 at 3:58 AM
    #1844
    Looks like Brine to me. They spray that on the roads for the snow.
    https://www.theruststore.com/How-to-Save-Your-Car-from-Brine-Sprayed-on-Roads-W113.aspx
    Istvank11 likes this.
  15. Jan 17, 2020 at 4:13 AM
    #1845
    War Machine
    It worries me that the cleaner had no effect. I sent your picture to Jeremy at Shine Supply asking for advice. I’ll let you know what he says.
    ryanryan34[QUOTED] likes this.
  16. Jan 17, 2020 at 4:13 AM
    #1846
    War Machine
  17. Jan 17, 2020 at 5:17 AM
    #1847
    owb2gp
    owb2gp New Member
    ID
  18. Jan 17, 2020 at 5:23 AM
    #1848
    That stuff is real bad.
  19. Jan 17, 2020 at 6:30 AM
    #1849
    ryanryan34
    Olympia WA
    Thanks for all the help, going to start with some Dawn and see what that does, if not, look at buying some Carpro Echo2 and seeing if that will help.
  20. Jan 17, 2020 at 11:20 AM
    #1850
    ryanryan34
    Olympia WA
    Tried Dawn dish soap and Chemical Guys Decon Pro Iron Remover cleaner today with zero luck. Wheels look exactly the same. Any other suggestions
    out there? Again, thanks for the help.
  21. Jan 17, 2020 at 11:25 AM
    #1851
    owb2gp
    owb2gp New Member
    ID
    If you have facebook reach out to these guys with pictures. They answer really quick and might be able to recommend something.
  22. Jan 17, 2020 at 11:36 AM
    #1852
    ryanryan34
    Olympia WA
    Thanks, I definitely will.
  23. Jan 17, 2020 at 12:44 PM
    #1853
    owb2gp
    owb2gp New Member
    ID
    Report back the results.
  24. Jan 18, 2020 at 8:40 AM
    #1854
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    Did you have the truck washed somewhere?
    That looks like acid wheel cleaner dried out and damaged the finish on the wheel. If that is the case, your only solution will be to refinish the wheel.
  25. Jan 18, 2020 at 1:13 PM
    #1855
    ryanryan34
    Olympia WA
    Not beyond a normal carwash to get salt and dirt off. Sky's The Limit Car Care suggested Scholls Concepts S3 Gold XXL compound to remove the etching.
  26. Jan 18, 2020 at 1:46 PM
    #1856
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    I'd give Bar Keepers Friend a try. You can find it cheap at Walmart.
    ryanryan34 likes this.
  27. Jan 18, 2020 at 2:51 PM
    #1857
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I honestly don't think that you'll be able to fix the finish. It sucks for sure, something etched the finish and my guess is that they will need to be painted or powder coated.
  28. Jan 18, 2020 at 3:58 PM
    #1858
    ryanryan34
    Olympia WA
    That was my fear after wheel cleaner and the few other things I have tried made zero difference.
  29. Jan 20, 2020 at 12:07 PM
    #1859
    War Machine
  30. Jan 20, 2020 at 12:38 PM
    #1860
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    At this point I may be thinking of a small buffer wheel on something like a Dremmel tool and some kind of compound.
