  1. Jan 16, 2020 at 7:30 AM
    speedtre
    speedtre New Member
    Inland Northwest
  2. Jan 16, 2020 at 8:02 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Apologies if this is insulting question, but are your rear brakes adjusted correctly? When mine are loose it makes a huge difference in pedal travel.
    Aerindel and TX-TRD1stGEN like this.
  3. Jan 16, 2020 at 8:08 AM
    rock climber
    @empty_lord Can you dumb this down for me:) I have an 01 without steering wheel radio controls and would love to add it. I have an aftermarket stereo so that part isn't a problem. If I grab a 4runner steering wheel how would I go about wiring it up to work? Also, does it matter which year 4runner? I was going to hit a junkyard and find a good condition nice leather steering wheel to fancify my truck
  4. Jan 16, 2020 at 8:20 AM
    Not insulting at all. I believe the rear are dialed in now. They recently improved a bit when I adjusted the parking brake cable. I've felt the rear drums after driving and they are hot to the touch so I know they are being used.
  5. Jan 16, 2020 at 8:43 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You need to find an 03 sequoia steering wheel and air bag and clock spring. The. You have to run 3 wires for the radio controls. The 01 has a single stage airbag so the new new wheels won’t work.
    rock climber[QUOTED] likes this.
  6. Jan 16, 2020 at 9:08 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    5th gen T4R is practically the size of 1st gen Sequoia. I wouldn't be surprised if it weighed as much or even slightly more. Most 3rd gen Tacos weigh more than most 1st gen Tundras
    Edit: Sequoia was 6400-6500lbs
    4Runner is 6100-6300lbs
    speedtre[QUOTED] and KarmaKannon like this.
  7. Jan 16, 2020 at 9:35 AM
    empty_lord
    05 rollover special
    I do believe the 4runner setup is a little bigger. The front brakes on a a 4runner are bigger too. (The calipers will fit our truck, the rotors will not though)
    as far as I know 16” wheels don’t fit 5th gen runners
  8. Jan 16, 2020 at 10:17 AM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    I think you're looking a GVWs. Curb weights for both are lower, but they are similar, with the 4Runner (4,400-4,800) generally a few hundred pounds lighter than 1st gen Trees (5,000 to 5,300).
    And similar story for our Tundras (4,800-5,0000) vs the newer Tacomas (4,000-4,500).
  9. Jan 16, 2020 at 10:41 AM
    I dunno, my truck on the scales was 5400 lb with me in it. Stock and empty, 1/2 tank of gas.
  10. Jan 16, 2020 at 11:44 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah I looked at the GVWR for the new T4R and 1st gen Sequoia. Maybe I remembered wrong about the Taco but I could've sworn I had looked up the curb weight
    Edit: here's what I found a while back
    3rd Gen Tacoma : 3,980 to 4,480 lbs
    1st Gen Tundra : 3,935 to 5,020 lbs
    SC T100[QUOTED] likes this.
  11. Jan 16, 2020 at 12:27 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Been hanging with Sensei for about a week deciding on proper handling of bearing ‘re-repair’. Sensei beatings sharpened me up.
    Dropped the 2002 Tundra off at stealership for her 8am appt. this morning for proper bearing service on the rear drivers side. Recall that I had prior failed service done a few months ago at another shop and was refunded $ plus new high dolla MK Kashiyama brake pads to replace the soaked ones (still to be installed).
    Stealer calls about 2 hours after she is opened up this morning and says we have a mess. They sent pics (below).
    I call failed service shop (still haven’t cashed their refund check BTW) and sought a solution. Met some ‘resist!’ from owner. Used some ‘Himalayan Mind Jujitsu Technique’ on the owner. Took him about 10 minutes to un-twist out of the pretzel I put him into, but he finally succumbed to buying a new axle (old one was clearly destroyed) and new bearing kit for stealership to install (both to be delivered tomorrow).
    Hack job to say the least. I swear I can do better work than most mechanics these days. Takes me a bit longer (no lift), but my stuff lasts and is fixed right the first time!
    Glad I didn’t try to open this mess up in my driveway to correct it and made a good call by taking it to stealer. Should have trusted my instincts and went there in the first place.
    Check out these crap work pics! So much wrong here.
    mcharfauros likes this.
  12. Jan 16, 2020 at 1:06 PM
    rock climber
    That's terrible, but glad it's getting fixed and the old shop is making it right.
  13. Jan 16, 2020 at 1:21 PM
    Aerindel
    Aerindel New Member
    Montana
    Indeed. I can't imagine going to a mechanic at this point in my life.
  14. Jan 16, 2020 at 1:29 PM
    empty_lord
    05 rollover special
    How the hell does one even manage to destroy the axle like that? Holy shit
    Bet they forgot to remove the snap ring before the pressed the old shit apart
  15. Jan 16, 2020 at 2:54 PM
    Fred
    Hand Protectors
    Yes and thank you. New NAPA kit (axle plus bearings,etc. is $300).
  16. Jan 16, 2020 at 3:47 PM
    Mityvac arrived today. Here's to hoping this thing works as well as the reviews claim.
    I'll knock out both vehicles Saturday. I'm really hoping that there is some air left in the lines and that the pedal feels better after this. If not, then I'll just accept the mushy pedal and move on.
  17. Jan 16, 2020 at 3:48 PM
    Fred
    Hand Protectors
    Was reading the flurry of rear disc mod conversations a few pages back and got to thinking about how much more surface area the rear shoes have compared to the front pads.
    Never measured the actual surface areas of each for hard comparison, but the rear shoes seem to have more total surface area on them. Am I missing something?
  18. Jan 16, 2020 at 3:53 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Maybe..? I just want disc brakes so I don't have to adjust them. My brakes actually seem to stop my pig fairly well even on 35s. Realistically I would just expect a more consistent stopping experience and ease of serviceability. I wouldn't be surprised if I get better feeling and performing brakes though because my drums probably aren't adjusted very well unless I've done it in 2 weeks.
    speedtre likes this.
  19. Jan 16, 2020 at 4:01 PM
    Fred
    Hand Protectors
    Ever since I figured out my inner drum parking brake cables were not installed properly years ago, and therefore weren’t self adjusting my parking brake, its been a change for the better.
    Both rear drums were like this.
  20. Jan 16, 2020 at 4:22 PM
    speedtre
    speedtre New Member
    Inland Northwest
    The issue with drums relative to discs is not lack of surface area, it's poor heat/water dispersion...the two things that lead to inconsistent brake performance.
    http://knowhow.napaonline.com/disc-vs-drum-brakes-pros-and-cons/
    BubbaW likes this.
  21. Jan 16, 2020 at 7:12 PM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    Ive only used mine on my road and mx bikes but always had good results. Makes brake bleeding so much easier. Thats a nice setup you picked up.
  22. Jan 16, 2020 at 7:27 PM
    markshoreline
    markshoreline New Member
    Mark
    Whidbey Island, WA
    2006 Tundra TRD 75k miles
    Front trailer hitch, tonneau cover
    This is a confusing thread in that folks are discussing detailed information about the differential and dash lights.
    Can the moderators split the discussion into two separate posts so readers can find pertinent searches more efficiently?
  23. Jan 16, 2020 at 7:34 PM
    Fred
    Hand Protectors
    You really are confused because this whole thread covers ‘What Have You Done Today’ A-Z on our Tundras.
    Maybe you can start a new thread and ask what you are looking to answer?
    Levy, MS22 and speedtre like this.
  24. Jan 16, 2020 at 7:37 PM
    Aerindel
    Aerindel New Member
    Montana
    Its because they work so much worse than discs they need more surface area, even though the actual braking power of the rear is always much less than the front. On rear disc vehicles the rear pads are much smaller than the front and they have less pistons, one or two as opposed to two or four in the front.
  25. Jan 16, 2020 at 7:47 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I dont think its any sort of moderators responsibility to do that but I do agree that we should be better at creating new threads for detailed stuff.
    There is a ton of useful information in this single thread and not everyone has the time to dig through 14,000 posts to find the goodies.
  26. Jan 16, 2020 at 8:10 PM
    ESTundra937
    Eddie
    San Diego
    I love the roller coaster ride this thread provides. It keeps the mods plentiful and my wallet empty.
    :cheers:
  27. Jan 16, 2020 at 9:03 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Does anyones bed stick out alittle on one side? I noticed awhile ago but I forgot to bring it up. It sticks out a little on my passenger side.
    Levy, NUDRAT and mcharfauros like this.
  28. Jan 16, 2020 at 9:06 PM
    empty_lord
    05 rollover special
    mines straight... but my bed also been off and moved around alot... its a few bolts to shift it around if it really bothers you.
    jImmegart[QUOTED] likes this.
  29. Jan 16, 2020 at 9:07 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Not that I can remember. I know the my 3rd gen starts off narrower than the cab.
  30. Jan 16, 2020 at 9:09 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Mityvacs are great. Just out of curiosity, what brake fluid are you using?
