What’s the coldest temperature your Tundra has started from?
Discussion in 'General Tundra Discussion' started by Tex Man, Dec 5, 2018.
  1. Mar 27, 2019 at 12:32 PM
    lwittmayer
    lwittmayer New Member
    2008 Pyrite Mica TRD Crewmax
    2.5 inch ReadyLift front level kit. AFE CAI. Gibson Dual Extreme Catback. 18x9 XD Hoss +30 offset. 275/70/18 tires
    -40 something in North Dakota. We didn't get above 0 for almost all of February this year.
    Metro14536 and (deleted member) like this.
  2. Mar 27, 2019 at 12:48 PM
    lwittmayer
    Yeah, gas gets gobbled up. Especially when your truck has to run for 10-15 minutes just to thaw out!
    Watt maker likes this.
  3. Mar 27, 2019 at 12:56 PM
    proROB
    proROB New Member
    Robert
    Temecula, Ca.
    2017 Tundra TRD PRO
    a freezing and bitterly cold 45 F. Hey I live in so cali. ;)
    twistedcricket and Metro14536 like this.
  4. Jan 14, 2020 at 12:05 PM
    Sharinganuser
    Sharinganuser New Member
    -39 C today... No issues so far. But man on highway it barely keeps cab warm at this temp. My ford was a sauna no problem. Prob due to active shutters and two turbos. Anyone else have this issue? Or a fix? Can i buy something to limit the cold air?
    Cpl_Punishment and Metro14536 like this.
  5. Jan 14, 2020 at 12:07 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    -12 F a few winters ago in duck creek Utah
    Metro14536 likes this.
  6. Jan 14, 2020 at 12:24 PM
    You might see some improvement from insulating/sound proofing the cab.
    https://www.tundras.com/threads/sound-matting-worth-it.22604/page-9#post-1263186
    https://www.tundras.com/threads/sound-deadening-and-insulation.49371/#post-1288794
  7. Jan 14, 2020 at 12:48 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    -40 or so overnight here. I had the block heater plugged in all night and it still made some unpleasant noises when I started it. Same problems as @Sharinganuser, too. I have the heat all the way up at max fan speed and have to decide between being able to feel my fingers or my toes or see out the windows.
    Also, is the rear defrost only supposed to cover the centre third of the window or do I have an issue for the dealership to investigate?
    BravoDeltaRomeo and Metro14536 like this.
  8. Jan 14, 2020 at 12:52 PM
    EddieWouldGo
    EddieWouldGo New Member
    Nathan
    2019 Tundra Limited CrewMax
    ADD Stealth Front Bumper w/Winch, 35" KO2s, OME BP51 Suspension, Decked Drawers, ExpeditionOne Dual Swing Rear bumper, Firestone Airbags, Thule Adjustable height bed rack, Roofnest Sandpiper.
    I have never seen a MORE Canadian post.... You should be the Mascot for your whole country.
  9. Jan 14, 2020 at 12:55 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Never had that problem. :notsure:
    I Actually have to turn down the heat.
    Ronin73, MTRock and Mountun Goat like this.
  10. Jan 14, 2020 at 1:03 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Yeah I read that whole thing in a Letterkenny voice in my head.
  11. Jan 14, 2020 at 1:15 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I guess the fact that I don't have remote start and my commute is only 10 minutes doesn't help.
  12. Jan 14, 2020 at 1:34 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    I get remote start put in at end of month!
    Can’t wait lol
  13. Jan 14, 2020 at 2:35 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I feel you guys.
    It was almost 72 here this morning at 6AM (Brrrrr cold!).
    Thought I was going to have put pants on!
    Luckily no clouds, and I pulled through it while it warmed up to 84.
  14. Jan 14, 2020 at 2:35 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Going to really test the truck the next 2 days. I've had battery issues since it doesn't run at times for a couple weeks, so if it doesn't crank right up it'll be time for a new battery. Had the battery on a trickle charger for the last 24 hours to give it the best shot possible.
  15. Jan 14, 2020 at 2:44 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Winnipeg is looking pretty good compared to that. You guys in AB are getting some nastily cold weather....keep warm.
    Mountun Goat and Y0TA PR0 like this.
  16. Jan 14, 2020 at 5:33 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Haha I had fun with that one :thumbsup:
    Wrongside likes this.
  17. Jan 14, 2020 at 5:54 PM
    WNY PAT
    WNY PAT New Member
    -23F or so when I was in Old Forge NY snowmobiling last winter. It started right up. I let it warm up for awhile since i had a 6,000+ pound trailer hooked up but no trouble with the heat.... maybe the extra heat produced pulling the trailer helped?
  18. Feb 8, 2021 at 6:37 AM
    TundraLady89
    TundraLady89 New Member
    Naomi
    2020 White SR5 CrewMax
    20” BMF rims, Venom 33x12.5 mud tires, Levelling kit.
    It’s currently -26F (-32C) and my tundra just started without being plugged in. I’m impressed.
  19. Feb 8, 2021 at 6:42 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    It was -32C this morning or -45C with windchill this morning.
    Plugged in all night, still screamed when I started it.
    Cpl_Punishment likes this.
  20. Feb 8, 2021 at 7:12 AM
    #50
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Coldest for me was -30F/-34.4C
    Did not like it. Let it run for >20 min before driving it. Have been in colder weather, but refrained from starting the Tundra or other vehicles, except the 95 Accord winter beater. Didn't care if that car pooched it.
    It was -15F/-26.1C recently. I have purchased an oem block heater. Don't have a heated garage so will be installed this next spring/summer.
  21. Feb 8, 2021 at 8:01 AM
    #51
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    It was on the colder side last night. Truck started but it was not happy, even after being plugged in all night. Nothing is happy in this weather, mechanical or otherwise!
    Wrongside, MTRock and Cpl_Punishment like this.
  22. Feb 9, 2021 at 5:08 AM
    #52
    ND90
    ND90 New Member
    2019 Limited Off-road
    where did you get the block heater? Mine parks outside and yesterday morning I heard it cry when I started it
  23. Feb 9, 2021 at 8:17 AM
    #53
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    PN: PU140-00913-2 from Toyota
    OEM can also be found on ebay.
    #53
  24. Feb 9, 2021 at 8:20 AM
    #54
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    In all reality, if I had temps that cold often, I would have the following on the tundra:
    1. Block heater
    2. Battery (pad heater)
    3. Magnetic style heater on the oil pan or trans fluid pan
    49ºNRTH[QUOTED] likes this.
  25. Feb 9, 2021 at 10:20 AM
    #55
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    Thankfully the extreme cold is only a couple weeks out of the winter. We do see sustained temps of -25ºC regularly
    I optioned the comfort+ from the dealer when I purchased to make the cold a bit easier to bear. It's a block heater, electric cabin warmer and battery trickle charger I can turn on or off via an app connected by Bluetooth. It definitely helps when the temps dip
    Warreng likes this.
  26. Feb 12, 2021 at 2:25 AM
    #56
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Feels like -62! WTF? That temperature doesn't even sound real.
    If I saw that I would start my Tundra... and then head south until the minus sign went away.
  27. Feb 12, 2021 at 4:33 AM
    #57
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
  28. Feb 12, 2021 at 5:10 AM
    #58
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
  29. Feb 12, 2021 at 5:15 AM
    #59
    Outbound
    Aaron
    Northern Alberta
    My remote start kicked the bucket this year so my Tundra has been garage parked all winter. I know, I spoil her. I've been driving the Corolla to work anyways. It started via remote at -35C after having sat for 9 hours at work without being plugged in. I was impressed. Not bad for a little sewing machine.
  30. Feb 12, 2021 at 5:33 AM
    #60
    BravoDeltaRomeo
    Bruce
    MB Canada
    -33C (-27F) this morning....started. :canada:
    Black Wolf and Cpl_Punishment like this.
