Using cab bed light for rear pods?
Discussion in 'Lighting' started by kevine0001, Jan 13, 2020.
  1. Jan 13, 2020 at 10:11 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    I have a ‘17 CM with a shell. I’m wondering if anyone has removed the cab light that illuminates the bed, and used that wiring for rear pods or another type of light in the back?
    thinking of adding pods in back and using same wire and switch
  2. Jan 14, 2020 at 1:00 AM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
  3. Jan 14, 2020 at 4:39 AM
    kevine0001
    Kevin
    Thanks. I assumed I’d be using the red and ground wire but I suppose ur right. I don’t need to use the ground wire from that rear bed light. I could ground it anywhere.
  4. Jan 22, 2020 at 11:08 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    Don't overload the wire gauge or the circuit's maximum amps. If what you're adding exceeds either then use a relay as suggested above.
    kevine0001[OP] likes this.
