Old man emu lift?
Discussion in 'Suspension' started by Tundra1794E, Jan 24, 2018.
  1. Nov 12, 2019 at 1:49 PM
    #121
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Stock upper control arms, alinement numbers fell right into place. No diff drop kit. @Skey44
    Skey44[QUOTED] likes this.
  2. Nov 12, 2019 at 1:56 PM
    #122
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Thanks RHLOK appreciate the input. Will try stock in front besides OME lift.
  3. Nov 12, 2019 at 4:46 PM
    #123
    Treemite
    Treemite New Member
    AZ
    I'm still on the stock UCA with my lift, I did do the diff drop up front though. Rolling on 37s now:thumbsup:IMG_20190917_160827.jpg
  4. Nov 12, 2019 at 5:10 PM
    #124
    Northern Inferno
    Northern Inferno New Member
    2016 Tundra Trd inferno
    Ome bp51, JBA uca
    I just had the bp51 kit installed with the Dakar leaf springs and Jba uca. Love it so far we had our first real snow yesterday and the truck felt solid. I have to commute an hour and forty minutes each way with a mixture of dirt roads and highway.
  5. Nov 20, 2019 at 6:31 PM
    #125
    Thumper1794
    Thumper1794 New Member
    Jon
    2020 Mesquite 1794 TRD
    Stock
    I have a BP51 on my 2019 Tacoma and am thinking about it for my 2020 Tundra. Keep us informed on how it does.
    DesertGorilla and Mountun Goat like this.
  6. Dec 11, 2019 at 4:46 AM
    #126
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Anyone running this setup for a while able to comment and post some pics of the CV Angles (with or without the drop kit) and just overall updates on ride?
    Mountun Goat likes this.
  7. Dec 12, 2019 at 7:32 PM
    #127
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I run 613 coils (arb front bumper). SPC uca’s and Dakar’s in rear. Sway bar deleted. I wanted the most lift possible so I have two coach builder shims on the drivers and one on the passenger side to fix ‘tundra lean’. I run a diff drop on it and judging by the way the cv angles look, I for sure wouldn’t run without it. I have never had any shake or shim’s since alignment. On the ride side of things the truck is working great. I have even jumped the front of the truck a few times, granted I did rip a cv axle boot :D. The ride is slightly on the stuff side (spring rate is tuned for the weight of the bumper plus a winch, which I don’t have yet). Honestly I love the way it rides. Feels tight and planted they way I want it to feel.
    vhstejskal[QUOTED] likes this.
  8. Dec 12, 2019 at 7:35 PM
    #128
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Plus, any excuse to post a pic of it haha.
    Oh and on 37’s :D:D
  9. Dec 12, 2019 at 7:38 PM
    #129
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I like that bumper you built. Pretty slick!
  10. Dec 12, 2019 at 8:11 PM
    #130
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thank you sir :hattip:
    TruckyTruck[QUOTED] likes this.
  11. Dec 14, 2019 at 1:24 PM
    #131
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    So I got the OME kit from @Toytec Lifts with Dakar rear leafs. I've seen most folks add shackles, but didn't get the option when ordering (could always order separately I guess).
    Will the Dakars work with the stock OEM shackles?
    vhstejskal and Mountun Goat like this.
  12. Dec 22, 2019 at 6:56 AM
    #132
    vhstejskal
    Vic
    Yes, they should work with the stock shackles. OME sells the shackle but it’s one you can grease.
    https://www.youtube.com/watch?v=S6DaX8TM8fo
    Install video where they just reused the old shackles. Good luck with the install; let us know what how things go.
  13. Dec 22, 2019 at 7:07 AM
    #133
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Awesome, thank you!
    I'll be reusing the stockers and maybe will upgrade to the greasables down the line.
    I'll be posting photos when I get it done! Hopefully tomorrow.
  14. Jan 11, 2020 at 8:02 AM
    #134
    Tundy White
    Tundy White New Member
    Jesse
    Ontario, Canada
    13 DCOR
    Levelled and Debadged
    How have you found the SPC UCA's durability wise and quality wise? Haven't found many Canadians running them so I'm curious to hear how they hold up through salt season.
    Any issues getting the alignment done up right?
    Mountun Goat[QUOTED] likes this.
  15. Jan 11, 2020 at 8:13 AM
    #135
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    They have been awesome. No alignment issues. I have run them for two winters now without issue. I’ve gotten airtime in the front of the truck a couple times and it’s kept alignment as well. I’ll be SPC for life at this point.
  16. Jan 11, 2020 at 8:17 AM
    #136
    Tundy White
    Jesse
    Ontario, Canada
    13 DCOR
    Damn eh! Do you have an "alignment guy" or was a "normal" shop able to do it for you?
    Where did you pick them up from?
    Thanks for the info to eh. Been going between the SPCs, BDS, and Camburgs but I like the ability to swap out the joint easily without removing the arm and the fact they seem super freaken adjustable.
  17. Jan 11, 2020 at 8:25 AM
    #137
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Those are the same reasons I picked spc over a hiem joint. Salty snow. I did sort of have an alignment guy, my neighbor is the mechanic I brought it to. He said he ‘road force’ aligned it. I guess it’s the setting on the machine they use for luxury cars. He said no issues while doing it. Plus when I lol at the setting on the arm I have room to adjust camber less/more which is good to see.
  18. Jan 11, 2020 at 8:26 AM
    #138
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I got all my lift parts from baja north in Kamloops. They are awesome. The owner basically sells parts at cost cause he wants everyone to wheel hard haha. I’m trying to remember but I’m pretty sure with the cost saving compared to the next lowest quote I ended up getting the spc’s free. Came shipped to my house on a pallet.
    bajanorth.ca
  19. Jan 11, 2020 at 8:47 AM
    #139
    Tundy White
    Jesse
    Ontario, Canada
    13 DCOR
    Beautiful, thank you really appreciate the info.
  20. Jan 11, 2020 at 8:56 AM
    #140
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :hattip: Np. Gotta love this forum!
  21. Jan 11, 2020 at 9:20 AM
    #141
    Tundy White
    Jesse
    Ontario, Canada
    13 DCOR
    Oh 100% comes in handy, especially talking to people who have to deal with salt and winter.
    Sorry OP for taking away from the post, to bring it back on topic a question for those that are running the OME Nitro sports front and/or rear do you wish you had gone with a Resi at all? Aka anyone noticed any fading at all?
  22. Jan 11, 2020 at 9:32 AM
    #142
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I run an OME lift on my 2006 4runner....love it. Performs much better and is so much better when it comes to towing.
  23. Jan 11, 2020 at 10:13 AM
    #143
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    @Tundy White bumping this thread made me realize I never posted any pics of my OME kit all installed!
    Followed the video @explore more made for installation. Thanks Steve! :thumbsup:
    Before:
    After:
  24. Jan 11, 2020 at 10:23 AM
    #144
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    No fading yet for me.
    Looks great!
  25. Jan 11, 2020 at 10:24 AM
    #145
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Thank you sir :fistbump:
  26. Jan 11, 2020 at 10:27 AM
    #146
    frichco228
    Frank
    Virginia
    looks good! Are those tire stock size or a little bigger?
  27. Jan 11, 2020 at 10:28 AM
    #147
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    They are a little larger than stock: 275/70/18
  28. Jan 11, 2020 at 10:30 AM
    #148
    frichco228
    Frank
    Virginia
    Did you do UCA? Any clearance issues?
  29. Jan 11, 2020 at 10:34 AM
    #149
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    No UCA, and no issues whatsoever. Everything has been great!
    I just put about 800 miles on the kit over this past week, and still couldn't be happier.
  30. Jan 14, 2020 at 1:19 PM
    #150
    EddieWouldGo
    EddieWouldGo New Member
    Nathan
    2019 Tundra Limited CrewMax
    ADD Stealth Front Bumper w/Winch, 35" KO2s, OME BP51 Suspension, Decked Drawers, ExpeditionOne Dual Swing Rear bumper, Firestone Airbags, Thule Adjustable height bed rack, Roofnest Sandpiper.
    I ran BP51 on my 4 Runner for a couple years and then bought a 2019 Tundra. I liked the kit so much on my 4Runner I decided to run them on the Tundra. The Tundra kit is newer to OME and I feel like it isn't as tested...
    Don't get me wrong, it rides like a dream compared to the stock suspension... but I have had 3 rear shocks that leaked immediately after install. It seems to be a Known issue on early runs of the product but it was supper annoying to have to keep getting replacements and reinstalling them. To OME credit... the warranty process was super easy.. I sent them photos they sent me replacements with no problems.
    I just ran them on a 3400 mile Baja trip on some really rough roads and they run like a dream...
    My feeling is if you can get a solid set that doesn't leak they are an incredible ride.
    On my 4Runner... after a couple years I still had no leaks and no issues.
