2020 Tundra hood material
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gene5253, Jan 8, 2020.
  1. Jan 8, 2020 at 2:33 PM
    Gene5253
    Gene5253 [OP] New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Anybody know if the new Tundra hoods are steel,aluminum or fiberglass? Thanks in advance
  2. Jan 8, 2020 at 2:34 PM
    mt95
    mt95 New Member
    Ohio
    2017 Tundra Crewmax-White
    Easy answer is to test it with a magnet on the underside. Magnet will stick to steel , not aluminum or fiberglas.
  3. Jan 8, 2020 at 2:57 PM
    Gene5253
    Gene
    Boise ID
    Aware or the magnet test. I don't have a Tundra yet. Still would not know of it is alum or fg. Thanks for the reply
  4. Jan 8, 2020 at 3:18 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
  5. Jan 8, 2020 at 3:23 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    very thin steel.....Toyota, as with almost all other automobile manufacturers, have been decreasing the thickness of the steel used on cars and trucks. They’re trying to save weight and increase mpg. On my 2014 4runner you could literally see the hood flexing at highway speeds.
