MORIMOTO XB LED HEADLIGHTS 16+ Issues
Discussion in 'Lighting' started by coTony, Jan 2, 2020.
  1. Jan 2, 2020 at 5:35 AM
    coTony
    coTony [OP] member since sept, 2017 and a BUNCH of messages
    Tony
    Montrose, CO
    I have a set of the Morimoto XB LED Headlights on my 2018 Platinum and the headlights all work with all lights, sequential turn signals, leveling, no hyper flash, etc. but the problem is I have all warning lights on my dash and it beeps then entire time driving. The warning screens that pop up are as follows:
    Pre-Collision System Malfunction
    Blind Spot Monitor Malfunction
    Trailer Brake Error. If Towing, Come to a Safe Stop with Manual Controls
    SRS Airbag System Malfunction
    Cruise Control Malfunction
    LDA Malfunction
    I have been in contact with TRS and was told that I am the only one that has had this problem. I was also told that other 2018+ Tundras have installed these lights and do not have this problem and they work just fine. I am not happy being the lucky one to see this problem and am trying to figure out what the problem is since TRS does not know. I do not have a schematic of the headlight circuit but obviously something is causing the error. It was offered to have TRS send me a replacement harness to see if this corrects the problem. That concerns me also because I would have assumed these have some sort of QA before the items shipped.
    Just reaching out to see if there is anyone else that had to travel the same journey I am challenged to travel that could provide some light on this topic. I cannot continue to drive the rig like this with the beeping and not being able to see anything except splash screens of errors and malfunctions.
  2. Jan 2, 2020 at 9:09 AM
    coTony
    Tony
    Montrose, CO
    I was hoping that at least @Headlight Revolution would chime in since I was asked questions and said they were happy to help.
  3. Jan 2, 2020 at 9:24 AM
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Hey OP!
    I am not super familiar with the Backstory on the situation, but I would be happy to help where I can! I just now saw this post due to the Tag, I apologize!
    Have you taken the truck into a Dealer by chance for a Scan? With the Airbags, Cruise Control, and Lane Departure flashing at you, that complicates things as I have personally not seen this issue. I would be curious to see what a Dealer has to say on the situation.
  4. Jan 2, 2020 at 9:29 AM
    booyaa
    booyaa New Member
    You still have the OEM set? If so - put them back in and clear the computer and see if the errors go away
  5. Jan 2, 2020 at 10:15 AM
    coTony
    Tony
    Montrose, CO
    I am not prepared to pay a dealer to tell me the lights have a problem they have never seen before. I will hook up my Techstream today when I get home and see what codes are there.
    I have a LONG FREAKING STORY for the light install, first it was a missing harness, then what was done the first time, then what I was told to do, etc.
  6. Jan 2, 2020 at 10:17 AM
    coTony
    Tony
    Montrose, CO
    Negative, the old lights are gone. There was no errors before the light install and during the install until the very last. I will post up everything later after the Techstream session is completed
  7. Jan 2, 2020 at 10:44 AM
    Atlanta, GA
    I would be curious to see what comes up from that scan. If anything, swing by O'reillys and snag their OBD2 Scanner for a couple minutes. Should hopefully be able to find something new there!
  8. Jan 3, 2020 at 3:30 AM
    coTony
    Tony
    Montrose, CO
    Well I just used my Techstream 3 months ago and it is now asking for a new Key. I have a set back until I get the Techstream up and working. Very frustrating at this point
  9. Jan 3, 2020 at 7:14 AM
    Atlanta, GA
    Man one thing after another... I am so sorry my man! Any chance with a local Auto store/Shop for a quick OBD Scan?
  10. Jan 3, 2020 at 8:27 AM
    coTony
    Tony
    Montrose, CO
    Anyone have the wiring diagram from an OEM EWD for the headlight circuit of a 2018 Platinum? Just trying to see what would cause the problem with the warning lights on the dash that causes the Royal Flush on my dash
  11. Jan 6, 2020 at 3:51 AM
    coTony
    Tony
    Montrose, CO
    I had a long weekend that kept me from the garage, too much going on still after the Holidays and I was not able to get the Techstream working. I will get it working today or I will take it somewhere and get it scanned
  12. Jan 6, 2020 at 4:17 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Have you changed any other Mama Toyota factory lights in the truck??
  13. Jan 6, 2020 at 6:44 AM
    coTony
    Tony
    Montrose, CO
    What are Mama Toyota factory lights? Sorry
  14. Jan 6, 2020 at 9:34 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    The factory light bulbs. Such as the bed cargo light bulb. Map lights bulbs. Etc. Many swap those out for LED's.
  15. Jan 7, 2020 at 6:37 AM
    coTony
    Tony
    Montrose, CO
    I have a very LARGE listing of codes from the Techstream scan I did yesterday evening after I got the Techstream up and running. Now I have a haystack and in there is a needle. How does one find that needle in the sea of hay? I am not sure what exactly to look for. Any suggestions?
  16. Jan 7, 2020 at 7:02 AM
    Atlanta, GA
    Could you PM me some Pictures of the Codes or maybe shoot them to Sales@HeadlightRevolution.com? We'd like to help out where we can on this, Email would be best!
  17. Jan 7, 2020 at 7:11 AM
    coTony
    Tony
    Montrose, CO
    I have the "xxx.TSE" file I saved. Would that work for you?
    Headlight Revolution likes this.
  18. Jan 7, 2020 at 7:20 AM
    Atlanta, GA
    That would be awesome if you could attach that and email it in! :)
  19. Jan 7, 2020 at 5:01 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    In techstream save the codes then clear them all. Then turn the ignition off and restart. See what codes are present after the restart and address them first.
  20. Jan 7, 2020 at 5:58 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Did you unplug the TSS sensor on the grill when you did the install? Stupid question but did you plug in back in? If you started the truck with that unplugged you need to clear the codes.
  21. Jan 8, 2020 at 3:32 AM
    coTony
    Tony
    Montrose, CO
    Yes I unplugged the sensor like I have 100 times removing the grill and just turn the truck off, plug it in and start it the codes clear themselves.
    So the new harness' arrived last night so after dinner I dove in. Replaced both harness' and the warning lights were still there. I got out my Toughbook and connected up to the truck using Techstream and there were codes EVERYWHERE! It was actually overwhelming going through EVERYTHING but a necessary evil. I deleted all codes but the SRS Airbag would not let me delete the code and digging into that, it showed that it could not communicate with the sensor. I dug through the wiring harness and made sure everything was connected and it was so I was stumped. I then looked for the fuse and there it was, the airbag fuse was blown. As soon as I replaced the fuse I was allowed to remove all codes. I just drove to work this morning for 18 miles with 13 of those highway miles of 80 mph and so far no codes. I am confident this is behind me now.
    The pigtail harness for the blinkers was found during my process that they are not needed and what it did was blow the HAZ fuse. I did notice the Airbag fuse was not quite seated in the connector just right but it was blown so replacing fixed that. I checked every fuse in that under dash fuse box to make sure they were seated properly and to my surprise just about everyone was not 100% seated. Weird but all good now.
    Thanks to everyone who has reached out, it has been a long process with a Florida vacation in the middle of the install. I have to admit everyday of my vacation I was thinking of what the hell could be wrong with a simple headlight swap. So happy now! :bananadance:
    drumzdj, AZTundra, BlueBottle and 2 others like this.
  22. Jan 8, 2020 at 3:48 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    Should of hit up @iHacker for a harness and or @Roman for harness. Theses guys know there stuff as well as @Headlight Revolution for lighting the tundras. Good luck and hope all is well in the future. If problems exist hit theses guys up.
    iHacker, WNY PAT, Roman and 1 other person like this.
  23. Jan 8, 2020 at 3:53 AM
    coTony
    Tony
    Montrose, CO
    The harness' come with the Headlights, they thought there may be a problem with one or both of the ones they sent to me.
  24. Jan 8, 2020 at 5:15 AM
    Atlanta, GA
    Hell yeah! Super happy to hear you got that solved, @azTony ! Them pesky Fuses I tell you... Good thing it was a tricky but simple fix! :)
    coTony[OP] likes this.
  25. Jan 8, 2020 at 3:00 PM
    19Platinum
    19Platinum New Member
    2019 Magnetic Gray Tundra Platinum
    OP I had the same thing happen to me with my new 2019 Platinum a couple weeks ago. Put in the lights and the required harnesses and my dash lit up like yours and my blinkers wouldn't work. Swapped back to the stock LED's and the messages all went away, but my blinkers were still not working. Called LightWerkz and they said I had them plugged in correctly. Well, I had to drop off my truck at the dealer to have them look at the blinkers and found out the aftermarket lights had fried my dash! They initially checked the flasher/fuses and found nothing. It came back to the aftermarket lights frying something in the dash. Well, 22 days later and a couple grand out of pocket my truck is back home. Literally picked my truck up today after dropping it off December 18th. The electronic dash had to be replaced and was on back-order from Toyota for 3 weeks. I will say that Lightwerkz was totally useless and wouldn't let me return the lights. I had to make a claim against them with my CC company to get refunded the purchase price. Then, of coarse, after the seller saw the claim they asked me to return the lights.......lol.
  26. Jan 8, 2020 at 3:25 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    They have a problem with their product and they don't step up to the plate. To me that's a new kind of low. I would start a new thread about your experience. Payback is a bitch.
  27. Jan 8, 2020 at 6:28 PM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    So was the issue the harness for the headlights or your fuses being loose
  28. Jan 8, 2020 at 6:51 PM
    coTony
    Tony
    Montrose, CO
    Blown fuses was my problem. I would have asked for the “fried pieces” they removed from my truck. I am sorry but if you look at the wiring harness for the Tundra, what could possibly cause the dash to fry before a fuse blows? I am not saying it didn’t happen but I would really want to see some proof that the dash fried. That sucks and is expensive.
  29. Jan 8, 2020 at 7:08 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    High voltage straying into the instrument cluster from the parking light circuit from a deflective harness.
    coTony[QUOTED][OP] likes this.
  30. Jan 9, 2020 at 2:59 AM
    coTony
    Tony
    Montrose, CO
    I would have still wanted to see the fried dash I just purchased and also had something to use for proof with TRS
