Any way to make footwell lights comne on withdoor closed?
Discussion in 'Lighting' started by Worriedman50, Dec 30, 2019.
  1. Dec 30, 2019 at 12:05 PM
    Worriedman50
    Worriedman50 [OP] New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    As I get older, and my co-pilot does as well, and, for sitting in a parking lot waiting for said co-pilot to get out of a store, I find it would be handy to have a method of turning on the footwell lights come on sans opening the dang pneumonia hole.
    Anybody figured a way to do that?
  2. Dec 30, 2019 at 1:40 PM
    Jrharvey02
    Jrharvey02 New Member
    The “dang pneumonia hole”, now that’s a good one. I like it. Wish I could be more help with your question but I’m too busy rolling on the floor laughing. Good luck.
    Okay, I’ve got my composure back now, what you’re asking for wouldn’t be reinventing the wheel, basic 12v knowledge could definitely hot wire that bulb to a keyed wire in the dash, but then you’d be looking at a switch being added on your dash somewhere, kinda overkill in my mind. If I were you I’d grab a $3.00 push light from autozone and keep it in your glovebox or zip tie it to the underside of your seats...
    dang pneumonia hole....bwhahahaha.....
    NewImprovedRon likes this.
  3. Dec 30, 2019 at 2:12 PM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Well here is the deal, I just ordered a set of footwheel VLEDs, and I know there is a way to rig a switch to have them operate as designed, then go to another position to turn it on, do double Pole double throw switches work like that?
  4. Dec 30, 2019 at 3:27 PM
    Jrharvey02
    I do believe double throws do work like that but I think you lack the constant power to do that like every switch needs. There’s only two wires going into the bulb, positive and ground. If you throw a switch along the positive, you would lack power when the door is closed to turn it on. Whatever turns that tiny bulb on is triggered by the door opening, which then sends power to the wire supplying the bulb. You need to figure out a way to implement a keyed power, switched, into the positive wire powering it...
  5. Dec 30, 2019 at 3:35 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  6. Dec 30, 2019 at 4:02 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Did you wire them to the light under the dash on the driver side?
  7. Dec 30, 2019 at 4:52 PM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    I was going to when they get here, just ordered.
    I actually wondered if I could patch into the dome lights for no more draw than would be required and then I could operate them with the interior switch.
  8. Dec 30, 2019 at 4:57 PM
    GiantsFanDan
    That's the way to do it. VLED's makes a kit for the Tundra and it turns on and off with the switch and doors.
    https://www.vleds.com/tundra-fwk-front.html
  9. Dec 30, 2019 at 5:15 PM
    Jrharvey02
    Yup, there’s a solution, that tiny bulb couldn’t account for much draw at all, especially a new led
  10. Dec 30, 2019 at 5:24 PM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    I don't find anything on their site that mentions a kit to wire into the inside light system, just plugging it into the existing light socket, am I just missing it? Figured I could chase down the hot wire for the inside lights cut the end off the VLEDs and hook to there and run the other side to ground?
  11. Dec 30, 2019 at 8:42 PM
    GiantsFanDan
    No need to cut. The link I provided to vleds includes bulb adapter so you remove the bulb and plug it in.
  12. Dec 31, 2019 at 4:07 AM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    I think that just ties to the existing door opening switch, does not allow you to turn on with the door closed.
    What I am trying to accomplish is to be able to turn them on with the door closed like you can the overhead lights. Old farts drop stuff whilst waiting on SWMBO.
  13. Jan 1, 2020 at 11:55 AM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Could I run a line from the "hot" side of the interior light switch to the feed of the footwell circuit, and put a diode in line to keep from back feeding the hot side of the existing circuit?
  14. Jan 1, 2020 at 11:59 AM
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    I was thinking of hooking the VLEDS to the dome light circuit, not just the single existing bulb. Just doing the front seat area.
  15. Jan 1, 2020 at 12:16 PM
    Jrharvey02
    I don’t have much experience with diodes (other than swapping my ALT fuse for one so that it sends me more voltage) but that sounds right to me. Simple t-tap from hot, dome switched wire, to footwell bulb, should give you both a switched bulb and a courtesy bulb all-in-one.
  16. Jan 1, 2020 at 12:24 PM
    Johnsonman
    Austin
    Sequoia
    What this old fart did to add better foot well lighting.
