What will Scan Gauge II monitor on 3rd gens?
Discussion in '2.5 Gen Tundras (2014-2021)' started by awq735, Dec 22, 2019.
  1. Dec 22, 2019 at 6:10 AM
    awq735
    awq735 [OP] New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    Does anyone on here run a scan gauge II on their 3rd gen Tundra? If so, will it monitor the transmission temp on a 2019 (since it uses engine coolant for cooling). I was hoping to monitor oil temp, trans temp, coolant temp, and exhaust temp. If possible. I see there is an X gauge for certain vehicles but not sure what all it covers.
  2. Dec 22, 2019 at 6:40 AM
    Blue Thunder
    Washington
    Yes, I have one. It works great, but you have to do the custom x-gauges stuff for the tranny temp. I don’t think we can monitor oil or exhaust temps. Hopefully someone can confirm/correct me on that.
  3. Dec 22, 2019 at 6:44 AM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I use the Scan Gauge II on my 2018, and I believe you will be okay monitoring the 2 transmission temperatures as I believe the temperatures are taken from points within the transmission, don't see any wires in the cooler circuit for sensors. I have not been able to come up with codes for engine oil or exhaust temperatures, and coolant temperatures is available in pre-codes. I monitor the 2 trans temps, engine coolant and battery voltage with mine.
  4. Dec 22, 2019 at 6:48 AM
    awq735
    Anthony
    Ohio
    Thanks for the quick responces guys. My main concern is transmission temps while towing. The other temps would just be "nice to have" items. Now to see if I can get it here before christmas!
  5. Dec 22, 2019 at 12:00 PM
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    yes, works on my 2019....put in a few codes and u will be good to go!
    it shows pan and torque converter temps
  6. Dec 22, 2019 at 12:59 PM
    awq735
    Anthony
    Ohio
    Is there one I should watch closer than the other? Correct me if I'm wrong, but isnt the fluid in the torque converter isolated from the fluid in the pan/vavle body?
  7. Dec 22, 2019 at 12:59 PM
    awq735
    Anthony
    Ohio
    Amazon Prime said it'll be here by Christmas Eve... Merry Christmas to me!
  8. Dec 22, 2019 at 1:06 PM
    timsp8
    NY
    Is there a list of codes for tundras anywhere?
  9. Dec 22, 2019 at 1:11 PM
    awq735
    Anthony
    Ohio
    From what I have read from their website, the x-gauge codes lets you pick vehicle specific codes for certain gauges... I'll know for sure when I install it. Speaking of installing the scan gauge, where is everyone installing theirs at?
  10. Dec 22, 2019 at 1:11 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    Here are mine, Works on 2018 and 2016, installed on flat surface above left hand side dash switches.
    Transmission Temperature 1 - pan
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 - Torque Converter output
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
    raylo, WXman, Blue Thunder and 2 others like this.
  11. Dec 22, 2019 at 1:56 PM
    Blue Thunder
    Washington
    I got mine from the Scan Gauge website. They have a list for Toyotas.
    Check out my build thread (link in signature). Post #27 towards the bottom of the first page.
  12. Dec 22, 2019 at 2:11 PM
    awq735
    Anthony
    Ohio
    How did you route your cable? I like that location... Is it easy to change gauges from that position?
  13. Dec 22, 2019 at 4:02 PM
    Blue Thunder
    Washington
    I popped out the panel on the side of the dash and the speaker cover. I think I took the speaker out and then ran the cable down from there. It was fairly easy, but a slight PITA to route. Then wrapped the extra cable up under the dash. You have to lean forward from the seat to change it, but it's easy enough if you're parked. I like having it as far forward as possible; easier to do a quick glance while driving that way.
    awq735[QUOTED][OP] likes this.
  14. Dec 22, 2019 at 4:12 PM
    awq735
    Anthony
    Ohio
    Thanks for the info. I'm not one to mess around while driving so that would be perfect for me.
    Blue Thunder[QUOTED] likes this.
  15. Dec 22, 2019 at 6:40 PM
    TTund16
    TTund16 New Member
    My ex co-worker had the exhaust temp programmed in his scangauge or maybe already preprogrammed idk. I was going to ask him for the equation before he left the company but never did since I didn't find it to be very important and nothing I could relate to ... iirc, it would fluctuate between 900-1200°F every time we went to lunch. Kind of boring. lol
    on the other hand, I like to read the engine oil temp but am told there is no sensor for it unless you install one yourself. Hard to believe Tundra ECU doesn't read oil temperature!
  16. Dec 22, 2019 at 11:04 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  17. Dec 23, 2019 at 8:56 AM
    db52282
    db52282 New Member
    Georgia
    2017 Silver Tundra Limited
    That Amazon page says the following regarding apps to use:
    OBDLink MX+ works with dozens of popular third-party apps like Torque, Dash, FORScan, DashCommand, obdCANex and Harry's Lap Timer to unlock enhanced performance, save fuel, change vehicle settings and even control door locks and remotely start the engine on select vehicles.
    Which app are you using?
    iPhone or Android?
    I'm specifically looking for something to give me trans temps.
    Thanks!!
  18. Dec 23, 2019 at 9:02 AM
    Joe333x
    Joe333x Member
    Boston
    It does work with 3rd party apps like Torque but if you use the OBDLink app it allows you to download OEM Enhanced PIDs which include the transmission temp at the pan and torque converter, I just use the pan temp since the torque converter temp changes very frequently. I am using Android.
  19. Dec 23, 2019 at 10:17 PM
    Eric32444
    Eric
    the temp at the TC fluctuates more as thats where the heat is made....but i think the pan fluid represents best reading for temp of complete system...
    the fluid circulates through everything constantly, but the friction is in the TC
  20. Dec 24, 2019 at 3:44 AM
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    I am interested in learning how to service the transmission on my 17 CM would this be a good tool for getting the fluid level correct by knowing the correct temperature range ? Not really trying to hijack your thread but the trans temp thing seems to come up for towing and servicing.
    awq735[OP] likes this.
  21. Dec 24, 2019 at 4:10 AM
    awq735
    Anthony
    Ohio
    No worries. This place is about sharing information to help each other out.
  22. Dec 24, 2019 at 3:41 PM
    awq735
    Anthony
    Ohio
    Thanks for posting these... They still work for my 2019. This helped me avoid typing the first two codes listed and getting frustrated. It is the third and fourth codes listed on the site!
    WXman likes this.
  23. Dec 24, 2019 at 3:45 PM
    awq735
    Anthony
    Ohio
    I may try to hide the cable a little better tomorrow
  24. Dec 24, 2019 at 4:58 PM
    awq735
    Anthony
    Ohio
    After reading through the codes on the website, is that supposed to be 3008 instead of 3808? I used 3808 and it is reading slightly higher than 2808, but the website only has 3008, not 3808.
  25. Dec 24, 2019 at 5:10 PM
    Blue Thunder
    Washington
    Thanks foe this...I added the torque converter to my display today. Will be interesting to see how the temps compare
  26. Dec 24, 2019 at 10:57 PM
    TTund16
    TTund16 New Member
    I'm using the one that HTGreen had posted a while back and they are correct and accurate. I think the website doesn't have the complete info.
    3808 is the TC temp and will typically read higher than 2808 (pan temp).
    if cruising and TC is locked, both temps should read the same.
  27. Dec 25, 2019 at 3:08 AM
    awq735
    Anthony
    Ohio
    I suppose if it works, it works!
  28. May 18, 2020 at 8:43 AM
    TemujinNomad
    TemujinNomad New Member
    appreicate you posting that. Works well for my 2nd gen. So which of the two would be more important regarding high temperatures? I’ve noticed TF1 (pan) shows lower temps, should I monitor that to make sure it doesn’t get over ~220 or should TF2 be the one I should be concerned about? Thanks
  29. May 18, 2020 at 5:23 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    I would be more concerned with the Pan temperature (TF1) than the Torque Converter (TF2), TF2 comes down to TF1 when the converter locks up. But, I watch both. I also pin open the thermostat when I'm going to be towing heavy for some distance, this keeps both temperatures down.
    SpooledReel likes this.
  30. May 18, 2020 at 6:40 PM
    TemujinNomad
    Thank you. Same here. Definitely pinning open the thermostat on hotter days, while towing, etc.
