Got 5100’s and 6112’s just installed with an add a leaf and now the steering feels lose?
Discussion in 'Suspension' started by jstyle, Dec 12, 2019.
  1. Dec 12, 2019 at 5:00 PM
    jstyle
    jstyle [OP] New Member
    Josh
    2016 Magnetic Gray Offroad CrewMax
    So I was hoping to get a more firm stable ride from the upgrade (5100’s in the back with a 2” add-a-leaf and coilover 6112’s in the front) but now the steering feels a good bit loose. Not horribly loose but definitely a decent bit looser than it was before the suspension upgrades. Did the shop do it wrong or is this normal behavior?
    It just sucks because I got the suspension upgrade to maybe give it an inch or two but more importantly make it tow my 6500lbs travel trailer. I haven’t hooked the trailer up but I’m not feeling really great about it being better at the moment.
    I even also put in 275/70/18’s (Falken Wildpeaks) but they’re E rated as opposed to the passenger tires on there before so I would think that would make it more firm.
    Thoughts?
  2. Dec 12, 2019 at 5:04 PM
    Rockanock
    Rockanock 21 Chevy 2500
    I just had 5100’s on the front at 2.5 lift installed today. My steering feels the same as before the lift. Also aligned after the lift so you might wanna check that
  3. Dec 12, 2019 at 5:48 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    You might want to check if they did alignment after the install
    19TundraPlatinum and 14burrito like this.
  4. Dec 12, 2019 at 6:10 PM
    timsp8
    NY
    I think I know what you mean. It’s like the wheels sink when you turn. I think it’s cause of the alignment and your tires are tilted in like a V.
  5. Dec 12, 2019 at 7:11 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I would get the alignment checked
  6. Dec 13, 2019 at 1:45 AM
    jstyle
    Josh
    Well that’s reassuring because the alignment hasn’t been done yet. I’ll get it done today.
  7. Dec 13, 2019 at 1:56 AM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    definitely I think it will clear up afterwards. Post yo your alignment sheet when your done
  8. Dec 13, 2019 at 2:18 AM
    jstyle
    Josh
    So the shop that did the lift recommended one specific guy to do the alignment. Can I take it anywhere or does it really make a difference if he’s a specialist doing alignment with lifted trucks?
  9. Dec 13, 2019 at 5:06 AM
    Rockanock
    Most likely that is a “scratch my back I’ll scratch yours” kind of deal that shop does with the guy. But chances are he’s probably fine. I’d make sure that the shop knows what they are doing. My alignment cost was 104 and they did a good job so far as I can tell.
  10. Dec 13, 2019 at 5:43 AM
    jstyle
    Josh
    I'm more saying that just a general generic place to do the alignment would that be an issue?
  11. Dec 13, 2019 at 5:57 AM
    Nailgun
    Nailgun New Member
    2016 black Tundra TRD
    TRD sway bars “3 lift, rear air bags, bumpers/winch, TRD exhaust- air intake
    I had the same steering issues after “3 lift, installed Bilstein 5100 up front helped a little, I stalled new 2019 TRD front solid sway bar yesterday-it eliminated all steering issues & mushy feel- drives great.
    Hope this helps
  12. Dec 14, 2019 at 6:23 AM
    jstyle
    Josh
    So I got it aligned and it looks like it’s in spec. It’s def not what I expected as it still feels a little loser than what I was hoping for but its WAY better than it was. Here is the spec sheet.
  13. Dec 14, 2019 at 9:31 AM
    timsp8
    NY
    When I had my 6112s installed I went back 3 times for alignments before it felt right. It was in spec every time but they made adjustments til it felt good. I don’t have my #s, but there is a thread on here about what #s to aim for with a lift.
    https://www.tundras.com/threads/alignment-specs.8126/
  14. Dec 14, 2019 at 10:15 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    funny you say that. Alignment #3 is what it took for my 6112s too. First was after install. 2nd was about 3k miles later. 3rd was after 8k miles. After the first and second everything felt great. It would slowly start to go back out. I attribute it to the 6112s needing good break in time. After the third the truck just felt “right”. Been perfect since and the truck rides and drives so damn good on long trips.
    AZBoatHauler and georgiey22 like this.
  15. Dec 14, 2019 at 10:52 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    What setting are you at and can you share your alignment numbers?
  16. Dec 14, 2019 at 11:04 AM
    Danman34
    Danman34 New Member
    Danny
    3rd setting.
    I honestly can’t tell you for sure. The shop I use is old school and doesn’t have print outs.
    but I did give them numbers to shoot for.
    camber 0-.2
    Caster 2.3-2.5L 2.5-2.8R
    total toe no greater than 0.15.
    I assume that’s where they got it set too. Haha. I don’t ask questions when I get in and it drives as good as it does. Not a bit of uneven wear even after 10k miles.
    DZ_[QUOTED] and Luckydog like this.
  17. Dec 14, 2019 at 11:52 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Awesome, thanks. Going to install my 6112s at 1.9" and add two shims left, one right. Was curious what others have gone with.
