2018 SR5 CM 4x4 Lifted Soon...
Discussion in '2.5 Gen Tundras (2014-2021)' started by back_cast, Dec 11, 2019.
  1. Dec 11, 2019 at 6:52 AM
    back_cast
    back_cast [OP] New Member
    Denver, CO
    Figured I'd start a thread to show the progress over the next couple of weeks. I spent a good amount of time sleuthing these forums and others over the months to figure out what I wanted, and at one point, I thought I was for sure sold on high $ coilovers with remote reservoirs up front and something similar in the rear (go big or go home, right?). However, after doing some soul searching…the 6112/5160 combo is more than sufficient. I don’t plan to rock crawl. 90% highway use. The rest of the time will be on fire roads here in Colorado to get to camping or fishing spots. And the ride will be much better than stock. I'll be sure to post some additional pictures of the before soon along with some measurements.
    This weekend, a buddy and I are going to tackle the following…
    • 6112 coilovers set at 2.5”
    • SPC UCA set at “D”
    • Differential drop kit
    • 5160 piggyback resis in the rear
    • Toytec shackles set at 1”
    And thennnnnn, a week from today she’ll be dropped off at Toytec for new shoes and an alignment.
    • 17” Icon Rebounds in titanium
    • 285/75/17 Toyo Open Country ATII
    What are your thoughts on loctite? Where would it be a good idea to apply some red threadlocker? Keep in mind that I may need to add shims above the coilovers if I experience enough lean to warrant it...so everything may need to be unbuttoned again. But the long UCA bolt?? The leaf spring bolts/nuts? OR could you argue that you don't need loctite?
    Toytec Lifts and Lake.Life24 like this.
  2. Dec 11, 2019 at 12:36 PM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    Blue loctite can't hurt, red is overkill, but most times I prefer just a little anti-seize and just torque to the correct spec. I've done a lot of suspension work, and don't really loctite anything expect engine crank bolts or the like.
    But always anti-seize everything lol
  3. Dec 11, 2019 at 12:39 PM
    mww982
    mww982 New Member
    2018 Tundra SRD 4x4
    I would like to see the outcome of that wheel and tire combo and if you have any rubbing issues. Really thinking about going with a similar combo.
    back_cast[QUOTED][OP] likes this.
  4. Dec 11, 2019 at 12:43 PM
    mww982
    mww982 New Member
    2018 Tundra SRD 4x4
    You in the DFW area?
  5. Dec 11, 2019 at 12:52 PM
    back_cast
    Denver, CO
    Denver
  6. Dec 11, 2019 at 12:54 PM
    mww982
    mww982 New Member
    2018 Tundra SRD 4x4
    Ah, just recognized the Texas plates
  7. Dec 15, 2019 at 3:13 PM
    back_cast
    Denver, CO
    Got it done in a buddies driveway. New shoes on Wednesday
    Hugemoose and Chucho like this.
  8. Dec 16, 2019 at 8:19 AM
    back_cast
    Denver, CO
    New lift only has maybe 20 miles on it. And obviously the measurements were taken from the ground and not the center of the hub. New wheels and tires go on Wednesday...so i'll re-evaluate what shims are needed at that point.
    Stock
    FL: 37 1/8" FR: 37 1/4"
    RL: 39" RR: 39"
    After coilovers at 2.5" setting, 1" shackles in the rear
    FL: 39 1/2" FR: 40 1/4"
    RL: 40 1/4" RR: 40 3/4"
  9. Dec 18, 2019 at 7:32 AM
    back_cast
    Denver, CO
    Stay tuned.... :stirthepot:
    TundraDude18, Ted4311 and louscrw like this.
  10. Dec 18, 2019 at 5:20 PM
    back_cast
    Denver, CO
    Chunky boi ;)
    Tundra9831 and RangerBP like this.
  11. Dec 19, 2019 at 6:19 AM
    back_cast
    Denver, CO
    Thank you @Toytec Lifts
    The truck turned out perfect. The driver side shim that was added leveled it out side to side and I have 1/2” of rake. Love it. ❤️ I’ll add more pictures when I can.
    @mww982 the tire and wheel combination couldn’t be better for what I wanted. They had to remove the mud flaps but no cutting was required for fitment up front. The spare fits underneath the bed very snuggly with about 1/2” clearance from the shackle bolts.
  12. Dec 19, 2019 at 8:15 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Just out of curiosity, what was the approx cost of your suspension upgrade?
    A level/lift is still in my long game and I haven’t chosen hardware yet. Yours sounds good.
  13. Dec 19, 2019 at 8:30 AM
    Looking good
    back_cast[OP] likes this.
  14. Dec 19, 2019 at 8:39 AM
    mww982
    mww982 New Member
    2018 Tundra SRD 4x4
    Thanks for the info, still trying to decide between 17’s and 18’s. If I go 17’s it will be the same size tire as you. 18’s would be 295/70/18.
    Just ordered my camper shell for the truck so new shoes will wait until these tires wear out.
  15. Dec 19, 2019 at 8:40 AM
    back_cast
    Denver, CO
    You realllllllly want to know? haha
    • 6112/5160s - $1k
    https://www.boss4x4s.com/stock_bilstein_6112_075_25″_front_and_5160_rear_0_15″_lift_kit_2007_2019_toyota_tundra
    • SPC Uppers - $650
    https://www.amazon.com/Specialty-Products-Company-25490-Control/dp/B004A393YC/ref=sr_1_1?crid=1B8VLG5AWMCR6&keywords=spc+upper+control+arms+tundra&qid=1576773231&sprefix=spc+upper%2Caps%2C182&sr=8-1
    • Reservoir clamps - $84
    https://www.amazon.com/Bilstein-11-176015-Mounting-Kit/dp/B009FU4ENK
    • Toytec Shackles - $220
    • Toytec 1/4" driver side shim - $25
    • Diff drop kit - $30
    • Alignment - $100
    So what's that, about $2,200 before getting into wheels and tires.
  16. Dec 19, 2019 at 8:53 AM
    Buckmark1
    Buckmark1 New Member
    2019 Cement SR5 CM - TSS Off Road 4x4
    I've got same Icon wheels with a 2 inch lift in front (Falcon sport level kit) and Coachbuilder +2 shackles in rear. What size tire you end up going with? I've currently got 285/70-17 but next set may be 285/75-17. I've have to trim front liner b/c I get a little rubbing now on right side with current set-up.
  17. Dec 19, 2019 at 8:57 AM
    back_cast
    Denver, CO
    Buckmark1[QUOTED] likes this.
  18. Dec 19, 2019 at 9:05 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    Looks great man. :thumbsup:
  19. Dec 20, 2019 at 8:46 AM
    back_cast
    Denver, CO
    Okay, now i'm done...haha
    jerzeedivr, D4x4TRD, BCSpazer and 3 others like this.
  20. Dec 20, 2019 at 1:58 PM
    panicman
    Eric
    Thank you for listing that out- it helps a lot.
    jerzeedivr and back_cast[OP] like this.
  21. Dec 20, 2019 at 2:12 PM
    AZBoatHauler
    So.Arizona
    Well done!! I love the blacked out look with the chrome up front!
  22. Dec 20, 2019 at 4:25 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    That looks really good. I like it.
  23. Dec 20, 2019 at 5:00 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Looks great!
