TSS issue with lifted trucks?
Discussion in 'Suspension' started by Boatmoney, Dec 10, 2019.
  1. Dec 10, 2019 at 8:15 PM
    Boatmoney
    Boatmoney [OP] New Member
    Mark
    2019 black platnum tundra
    I’m looking to put a small level/lift 3/1 and run 35s on my 2019 platinum CM. will I run into malfunctioning collision warnings or cruise control issues. I read mixed reviews of people having issues. Has Toyota fixed this issue?
    OR18TRD likes this.
  2. Dec 10, 2019 at 8:16 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    3 inch lift with 35s just after purchasing brand new. Nver had any issues with TSS going on over 2 years now
    Ducarius likes this.
  3. Dec 10, 2019 at 8:18 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I have talked to a local shop about installing Bilstein 5100 up front with a 2” lift to level and they have said it will not impact the TSS function
  4. Dec 10, 2019 at 8:29 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    2019; zero issues here.
    3/1 readylift. stance is clean and not over the top.
    **EDIT TO ADD** running 295/60/20 (33.94") i had to remove the front, front mud flaps / air damn (whatever you want to call it, flaps in front of tires) in order for zero rub; i will also have to modify my skid before re-install in order for zero rub.
    12.01.18 new tundra 25.jpg 12.01.18 new tundra 26.jpg 12.01.18 new tundra 27.jpg
  5. Dec 10, 2019 at 8:34 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    does it still have a slight forward rake?
  6. Dec 10, 2019 at 8:38 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    I had issues with my 2018. Bought late 2017. Dealer installed lift, this was prior to dealers saying they would no longer lift. Depending on dealer atound you to fix the issue or not. I know a few of the bigger dealers put after market kits on and recalibrate. Id check with multiple dealers in your area, just in case.
  7. Dec 10, 2019 at 8:39 PM
    shackleford rusty
    TEXAS!
    barely (exactly 1/4 inch rake on driver and 1/8 rake on passenger), my measurements from bottom of WHEEL to highest point of WHEEL WELL.
    driver front = 35-3/8
    passenger front = 35-1/2
    driver rear = 35-5/8
    passenger rear = 35-5/8
    a little OCD, i know... i had the tape measure out as 4WP was buttoning everything up.
  8. Dec 10, 2019 at 8:45 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    well my OCD picked up that 1/4” inch in the side picture. Lol
    looks good though. I am probably just going to do Bilstein in the front and lift the 2” to make it level or within that 1/4” tolerance
    Patch999 likes this.
  9. Dec 10, 2019 at 8:56 PM
    shackleford rusty
    TEXAS!
    nice!
    i call the 1/4" "within tolerance" myself. having OCD w/out an acceptable level of tolerance, i would get NOTHING accomplished, at home, or at work.
    :benchpress:
    OR18TRD and DCB500[QUOTED] like this.
  10. Dec 11, 2019 at 1:41 AM
    Zero One Actual
    3 inch front and 1.5 rear in 2019 CM. Zero issues with anything what so ever in 7000 miles.
  11. Dec 11, 2019 at 2:41 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    OME suspension and I did have TSS issues, the dealership finally got everything programed and everything works as it should. Some have the issue and others do not, its a roll of the dice.
  12. Dec 11, 2019 at 3:47 AM
    reelcracker
    reelcracker Just a squirrel trying to get a nut
    Farva
    2018 off-road d/c
    Tyger steps, 6 " pro comp lift with fox rears, 20" drop stars -25 offset, toyo m/t's 35x12.50
    6" pro comp lift installed on my 2018. With 35's pretty much level on all four corners. Installed by 4wp. No issues with cruise control or any other sensors. Installed the lift about a month after I bought the truck. Been on for about a year now. Bought the truck dec. 29th 2018
  13. Dec 11, 2019 at 5:25 AM
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    How is the ride with the Ready Lift? I have a 2020 I want to do this to but thought of going coilover route to keep from degrading ride quality.
  14. Dec 11, 2019 at 2:05 PM
    shackleford rusty
    TEXAS!
    retained very close to factory ride, especially on surface streets. bumps seem to be a tad rougher, however, i attribute most of that to the LT all-terain tires vs. the factory P-metric highway tires. i also keep my LT's aired at 50+ psi vs. the 40 psi i kept my factory.
    the 3/1 ready-lift and pro-comp kits both claim to retain factory ride; my experience = this is an accurate statement.
