  1. Dec 9, 2019 at 9:13 PM
    MauiTRDPRO
    MauiTRDPRO New Member
    2003 Tundra AC Super White 2018 TRD PRO Tacoma Calvary Blue
    BEF18422-9248-48C4-9F6C-13D4E38C0A5D.jpg New to the forum. Just picked up my buddies 2003 Tundra A/C 4x4. 48K miles and 2 owners. Mods included
    -Icon front and rear suspension
    -Camburg upper control arms
    -Volks TE37 matte black -20ET
    -Cooper M/T 285/75/16
    -AEM drop in air filter
    -Kenwood double din with reverse camera
    On the list(Parts on hand waiting for time to install)
    -Side steps
    -JBA short tube headers
    -JBA Exhaust system
    -Bedliner
    Brown Bear, abcinv, DDUNK77 and 7 others like this.
  2. Dec 9, 2019 at 9:25 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Welcome John.
    MauiTRDPRO[QUOTED] likes this.
  3. Dec 9, 2019 at 9:33 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    My mom’s family has been in the Hickory area for 300 years.
    Bubbles[QUOTED] and NUDRAT like this.
  4. Dec 9, 2019 at 9:51 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Man I’m out in LA and riverside the past 2 days. I forgot how many Toyota trucks are out here. Seen so
    Many first gen tundras and tacos, out by me that’s kinda rare
    Darkness and NUDRAT like this.
  5. Dec 9, 2019 at 9:56 PM
    Aerindel
    Aerindel New Member
    Montana
    Naw, I was just banned, it was blue. Also looking to extend my ban just to stand up to the man. Haven't figured out a good way to do it.
    bmf4069 likes this.
  6. Dec 10, 2019 at 12:13 AM
    NMR@ider76
    NMR@ider76 New Member
    Jesse
    2006 DC Tundra
    5 inch tuff country 35” coopers on mayhem wheels TRD CAM exhaust K&N JET flash
    I did not make a build thread as most of this has already been done before. I will though give a lot credit and thanks to both https://www.youtube.com/channel/UCUSy1wA80Lv7qMOgdka0aUg and https://www.youtube.com/channel/UCUT6rJnW4qT6J6uQiv7KKxA. and of course general searches both on here and youtube. Please feel free to PM me, and I will help as much as possible. I will be creating tread for most of the items I will be adding in the near future.
    oscardog86 and NUDRAT like this.
  7. Dec 10, 2019 at 12:15 AM
    NMR@ider76
    Jesse
    2006 DC Tundra
    Welcome from NM
  8. Dec 10, 2019 at 3:05 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Simply show us some TITS :D
    bmf4069 likes this.
  9. Dec 10, 2019 at 3:33 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Had another opportunity to snatch defeat from the jaws of victory yesterday. My ecgs bushing arrived so I tore the front end apart and got it back together in about 2.5-3 hrs with a break to feed the dogs and welcome the old lady and my copilot home. Everything went smoothly and I was able to inspect my suspension again for the warm fuzzies. I test drove it and it seemed good until o got home and was leaking oil out of the axle seal. It was leaking so bad that I actually had to think very hard and remember if I'd installed the new axle seal. I obviously installed it, but it was equally obvious I did something wrong. Still not sure what I did wrong so I guess I'll just tear it apart for the 30th or so time this year and play like the bear that walked up the mountain and see what I see.
    Yuge thanks to @FrenchToasty for loaning me the needle bearing removal tool. I was stubborn enough to attempt to make one and having the tool really helped me get everything figured out in a timely manner.
    New and improved drain plug now with more schmoo!
    It was Campbells chunky needle bearing soup on the floor and around the axle seal area. I picked up what I could and used an air nozzle to clean out the rest. I'm a little worried about the prospect of my diff eating some needle bearing soup, but there's nothing to be done about that now. I guess my oil recycling system (massive oil leak) will help that.
  10. Dec 10, 2019 at 4:53 AM
    Sounds about like me. I've waited a few days to see if it was where I spilled atf everywhere, but it's not. I'm leaking from somewhere. And all I did was drop the pan and reinstall. My rear wheel bearings are leaking again. My front brakes made a horrible noise after the WL swap. Oh, and I snapped a VC bolt off, and a trans filter bolt. I'm about done doing any more work/damage to my truck.
  11. Dec 10, 2019 at 5:39 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Clean really well with degreaser. Let dry. Soak the belt with the Silicone. I pulled the belt all the way out and let it retract whilst spraying. Do both sides of belt. Let dry and over the next few days the mojo comes back with a snap!
    oscardog86 likes this.
  12. Dec 10, 2019 at 5:55 AM
    Fred
    Hand Protectors
    This is disheartening to see. I hope you can work it out some how.
    KarmaKannon[QUOTED] likes this.
  13. Dec 10, 2019 at 6:01 AM
    Fred
    Hand Protectors
    Just stick with playing with your wire nuts and leave the mechanical glory for the professional hand models. Speaking of which, I’m getting nervous about this steering rack bushing install. Anyone done this? Seems like the PS hard lines won’t have the 2-3” of pull out play needed to make things work.
  14. Dec 10, 2019 at 7:00 AM
    I think you've got this. Did you already watch the videos online? It doesn't look that bad. If you can do the fuel injectors I'm confident you can do this. Much easier to see everything and a lot less stuff to move out of the way.
  15. Dec 10, 2019 at 7:05 AM
    kodyquist21
    kodyquist21 stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    It rained the last 2 days out here in AZ and due to annoying school finals i didn't get to romp in the mud. Stupid school
    NUDRAT likes this.
  16. Dec 10, 2019 at 7:06 AM
    Do you mind explaining this for me? I'm not familiar at all with the inner workings of the front diff. The needle bearing is only on the driver side? Is this where the CV axle slides into the diff? And you replaced it with a better option, the ECGS bushing? I can only assume I'll have to do this one day. Other than pulling the CV out of the diff, what else is involved?
    Aerindel likes this.
  17. Dec 10, 2019 at 7:09 AM
    That's amazing. Only 48K. Great buy. Post some better pictures in the picture thread when you get a chance.
  18. Dec 10, 2019 at 7:11 AM
    Please don't get banned. We need your expertise around here. You are the brake sensei.
  19. Dec 10, 2019 at 7:30 AM
    That’s a lot of missing needles!! Glad you got it out! I know my passenger oil seal isn’t holding but that’s because I did something to it. It’s annoying but at least it’s not to bad to put a new seal in.
    @FirstGenVol if you’ve pulled your cv before it’s not much more than that. If you look up Timmy the tool man, on YT he does a install video of this bushing on a 4Runner, i referenced it a lot when I changed mine. Mine still had needles left, unlike karma Kannon
  20. Dec 10, 2019 at 7:58 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What are you doing in Riverside?
  21. Dec 10, 2019 at 8:00 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Witnesses have seen him in his driveway dressed in a Nascar pit crew uniform, removing and replacing his lug nuts repeatedly with a stopwatch.
  22. Dec 10, 2019 at 8:03 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've done it. Be gentle but firm and you'll get through.
  23. Dec 10, 2019 at 8:09 AM
    KarmaKannon
    Utah
    Some junk
    It's just on the driver's side (short side) of the axle. There's a needle bearing that supports the diff side of the CV. If you're leveled and have miles on your truck I'd replace it with the ecgs (east coast gear supply) bushing. That way you'll avoid your diff eating needle bearing soup. The bushing is supposed to replace the needle bearing and not fail. Good luck sealing the axle afterwards haha I guess I don't know how to do that one. Pulling the needle bearing I can do, and obviously I can't set an axle seal.
  24. Dec 10, 2019 at 8:20 AM
    empty_lord
    05 rollover special
    Seeing the girlfriends family and celebrating my birthday Friday
  25. Dec 10, 2019 at 8:39 AM
  26. Dec 10, 2019 at 8:40 AM
    KarmaKannon
    Utah
    Some junk
  27. Dec 10, 2019 at 8:44 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Very nice, hope you enjoy. You should go check out the Mission Inn during the evening if you can, they decorated for the holidays.
    NUDRAT likes this.
  28. Dec 10, 2019 at 9:38 AM
  29. Dec 10, 2019 at 9:39 AM
    Thank you. Hopefully, I won't be making this repair anytime soon but I like knowing anything I can about these trucks. I see they have a removal tool and an install tool. Which one did you buy?
  30. Dec 10, 2019 at 10:03 AM
    Mr. Pink
    Mr. Pink New Member
    Ontario, CA
    06 DC 4x4
    Tint, stereo system, lift , more to come
    Round 2 of wheel bearings
