ECU chip that can increase power?
Discussion in '1st Gen Tundras (2000-2006)' started by stevechumo, Dec 7, 2019.
  1. Dec 7, 2019 at 3:03 PM
    stevechumo
    stevechumo [OP] New Member
    Is there any reliable ECU chip that can actually increase the power of the 4.7 with simple installation? If a chip that can increase 5-10 rwhp, then it's pretty good to me.
  2. Dec 7, 2019 at 7:45 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    no
  3. Dec 8, 2019 at 8:06 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
  4. Dec 8, 2019 at 8:11 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  5. Dec 8, 2019 at 8:42 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    But think of all the power you could get for the price of headers that might yield like 20hp you could gain like 100hp lol
  6. Dec 8, 2019 at 8:42 AM
    empty_lord
    05 rollover special
    If I were going to run that turbo I’d at least put better rods in. These engines don’t like boost
  7. Dec 8, 2019 at 8:44 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I'll stick with headers and exhaust. I want my tundra to at least double it's current mileage
  8. Dec 8, 2019 at 8:46 AM
    empty_lord
    05 rollover special
    I need to finish the Tacoma first. But the tundra might get a full build. Who knows.
    Or a Lexus rcf May replace my Avalon. Time will tell
  9. Dec 8, 2019 at 10:51 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  10. Dec 8, 2019 at 2:54 PM
    stevechumo
    I'm not looking to boost it, even though I thought about it. :D I'm not new to forced induction. I had built turbo and supercharger systems for Lexus SC300 SC400, LS400, worked with my friend to put 1UZ heads onto 2UZ block and supercharged it on LS400. The 2UZ of the Tundra is quite simple to play with. However, I currently don't have time to fabricate anything, so I only need some little power added quickly to make towing a little more easy.
  11. Dec 8, 2019 at 5:28 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Not me. But I fully endorse someone else doing it :D
  12. Dec 8, 2019 at 5:29 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Long tube headers, exhaust, rear gears
    revtune and imDementeD like this.
  13. Dec 8, 2019 at 8:12 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    If I were to boost my truck, I’d LS swap it first.
    Hbjeff and KarmaKannon like this.
  14. Dec 8, 2019 at 8:13 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @stevechumo
    There is Unichip which might not do anything as far as I know, and I've had it for years. At least it does probably nothing while naturally aspirated. I do appreciate the kill switch and valet mode.
    There is one other I have head of but I really don't think it's worth exploring. If it were it would be popular by now. Tuning software is better for forced induction, N/A just doesn't have much on the table.
  15. Dec 9, 2019 at 12:34 AM
    stevechumo
    So far no luck for me. Lol.
  16. Dec 9, 2019 at 2:17 AM
    Aerindel
    Aerindel New Member
    Montana
    I mean....think about it. Truck makers are always fighting for 'power' with every model. If they could get any more power from something as simple as software, they would just so they could advertise the truck having 255 HP instead of 245.
  17. Dec 9, 2019 at 12:15 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup. The only place where I have seen otherwise is in turbo applications (petrol or diesel).
  18. Dec 9, 2019 at 12:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You can’t feel a 5hp gain.
    Aerindel likes this.
  19. Dec 9, 2019 at 2:50 PM
    stevechumo
    Actually, that's not necessarily. The auto factories need to tune their vehicles within a safe range to compromise between power and reliability/safety. If they lean out the fuel and advance a few timing degrees, then they certainly will gain power. I've seen Lexus SC400 V8 gained 10 rwhp with just a tuning from a piggyback ECU. I read about guys in Australia and New Zealand gained power from tuning on their Tundra. However, it's costly. Paying for a piggyback ECU, install O2 sensor simulators, then pay for a tuner to trick the O2 sensors, then tune just to gain 10 hp may not be worth it to me. That's why I need a simple bolt-on chip.
  20. Dec 9, 2019 at 3:32 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You've done all that and you think that a "chip" will work?
  21. Dec 9, 2019 at 3:57 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    K & N and white paint is good for 20 RWHP.
  22. Dec 9, 2019 at 4:10 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Removing seats, spare tire, a/c compressor, and any other dead weight will make your Tundra more faster.
  23. Dec 9, 2019 at 10:56 PM
    stevechumo
    It's possible with limitation.
    Let it fly. Lol. I'm already putting on 275/70/17 tires, plus towing a 23 ft cuddy cabin boat with 4 people inside, along with fishing gears, so it still can't fly.
    That's my Tundra and the boat in the background.
  24. Dec 10, 2019 at 3:45 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Nice looking truck. You already have the fastest color already. If I was looking for some cheap and easy hp I'd look at freeing up the exhaust some, throwing a dry afe filter or intake on, and maybe getting the fancy 12 hole injectors. Might help you tow a little better.
    because_wumbo-truck likes this.
  25. Dec 10, 2019 at 5:42 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you have upsized tires, number one mod should be 4.56 gears before anything
  26. Dec 10, 2019 at 12:35 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    What bull bar is that?
  27. Dec 10, 2019 at 3:52 PM
    stevechumo
    It's just a cheap bull bar from Ebay. It requires the factory tow hooks to be removed. I had to weld the 1/2 rings to the base of the bull bar just in case it needs to be pulled from the front. It's just for look but not functional. Lol.
  28. Dec 10, 2019 at 5:26 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    On my 03 I had 4.56s and 33s and it helped a alot. So did load leveling air bags. All stock otherwise. My boat is a 21 foot and weighs quite a bit less I'd imagine. Yours is a tuna cruiser!
    EDIT: corrected the gear ratio.
  29. Dec 10, 2019 at 8:58 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    I would go 4.88’s instead. The 4.56 is such a small step from the 4.10 or 4.30.
    Plus the auto has such a steep 5th gear that the lower gears (4.88’s) still won’t put you at too high of a cruising RPM.
  30. Dec 10, 2019 at 9:13 PM
    stevechumo
    I don't know what gearing options available out there, but I'm interested in LSD for off roading.
