Grinding noise
Discussion in '1st Gen Tundras (2000-2006)' started by GK1952, Oct 25, 2019.
  1. Oct 28, 2019 at 12:04 PM
    Aerindel
    Aerindel New Member
    Montana
    You have to learn somewhere. Nobody is born knowing how to work on vehicles. The tundra is fairly simple and a good one to learn on.
  2. Oct 28, 2019 at 11:58 PM
    GK1952
    GK1952 [OP] New Member
    Gary
    2006 Tundra access cab
    none
    It has definitely been an experience, luckily every thing I have torn down, I have gotten back together. I am taking a couple of days off, will hit is again hopefully on Thursday. This time I am going to check everything thoroughly before I start tearing apart. I'll post when I start.
    Aerindel[QUOTED] likes this.
  3. Oct 31, 2019 at 3:00 PM
    GK1952
    Gary
    none
    Today I pulled both back wheel drums and checked bearing play. I had some horizontal play but no side to side play. And when I spun the wheel it was not grinding. I blew out the brakes good and put back together. Tomorrow I will drain the rear end fluid and check it. I also checked the ABS gear, and both were a little wet but not much? So not sure about that. Also I had to loosen up the brakes on one side to get the drum off and the ABS is going crazy now when i stop. I will have to adj. the breaks tomorrow. So, still looking for the problem.
    Any suggestions?
    When I changed the front wheel bearings I put in a cheap bearing. A big mistake. I still think I am hearing front wheel noise. Tomorrow I will pull the front wheels and really check them again.
  4. Nov 29, 2019 at 1:13 PM
    GK1952
    Gary
    none
    Ok, I have finally found the problem. The differential has a bad bearing in it.
    Any suggestions? I have looked on line and it looks to be difficult job for a DIY?
    Should I let Toyota do it or a 3rd party shop?
    bmf4069 likes this.
  5. Dec 1, 2019 at 8:43 AM
    Any time differential work is involved, it's advisable to take it to a shop.
  6. Dec 3, 2019 at 8:18 AM
    GK1952
    Gary
    none
    Fixed.
    I learned a lot of lessons here. And a mind boggling amount of service info.
    I plan to keep the truck until it dies so good for me.
    Also I have all the tools for the front bearings and the rear bearing removal, and replacement.
    The rear bearing tool I bought, had to be taken to a welder, and have some extra welds done.
    The rear wheel bearings were the hardest by far IMO.
    I had to make sure the tone ring was perfectly allied with the seal. And removal was a little tricky first time.
    Also I found a shop that specializes in Axle and gear boxes, what a wealth of info from this guy. Amazing, and honest small shop.
    Time to get the pop up, and kayak loaded and go for a MUCH deserved get away!
    I will make one more post with the kayak and pop-up attached just for grins.
  7. Mar 8, 2021 at 12:30 AM
    carsonchunk
    carsonchunk New Member
    So what was the cost? What did they do to the rear end? I'm in the same situation. I think I have a pinion bearing problem.
