Digital speedometer
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yota303, Nov 28, 2019.
  1. Nov 28, 2019 at 5:26 AM
    Yota303
    Yota303 [OP] -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Wish there was a option for a digital speedometer on the screen in my dash. I would rather have that in my display than my trip travel time, or my average mpg’s. Anyone know if there’s an option or a thread for this?
    4Runner likes this.
  2. Nov 28, 2019 at 1:52 PM
    Apinion
    Apinion New Member
    2015 Black Tundra Platinum
    I feel like I've tried and we are SOL.
    TTund16 and Yota303[OP] like this.
  3. Nov 28, 2019 at 6:58 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Yes, that data is useless to me....Crazy. I get speed and more on my Kenwood HU so it should be easy.
    Yota303[OP] likes this.
  4. Nov 28, 2019 at 7:04 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Digital speed available on 18+. Not sure if dash clusters are interchangeable
  5. Nov 28, 2019 at 9:39 PM
    Yota303
    Washington
    That would be nice if they were compatible, seems like it would need a digital signal and not sure if 18- reads off of digital or analog signal? Might have to look into this a little further when I have the time. Good to know it’s a feature on the 18+ models though
    Larmand[QUOTED] likes this.
  6. Nov 29, 2019 at 4:23 AM
    4Runner
    4Runner New Member
    Columbia, SC
    It’s all digital. Seems to me I t is just data as my 17 can display all the digits necessary. Seems like some programming is all we would need.
  7. Nov 29, 2019 at 4:36 AM
    timsp8
    NY
    I don’t think you can swap the clusters. At least I know you couldn’t when I had my 2010 cause the mileage was programmed in to it. That way people don’t do it and it looks like they have a lot less miles. I think you had to go to a dealer to get it programmed correctly and certified.
  8. Nov 29, 2019 at 6:06 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    You could install a scangauge or similar product that uses your ODBII port and mount it to your steering column or dash. I believe those give you a digital speedo readout. That's all I got.
  9. Dec 1, 2019 at 8:23 PM
    Apinion
    Apinion New Member
    I've checked with @Roman and he said it was a no go.
